djiuser_HYf4VYIYAZbk
While these are interesting posts I think most are failing to realize some important information. 1st is the fact that drones are light weight and requires enormous power to go beyond 1700 feet, 500 meters, not to mention the wind will be much stronger the higher you are which could pull your drone farther than intended. Additionally, most of your battery would be used up if you did actually manage to go beyond this height and should it run out of battery it would drop like a rock into someone or thing.
Then there is the issue of other air traffic in the form of planes. I, for one, would not want to know that my drone was the cause of an air disaster!
Maybe, after hearing this I guess remote ID is a good thing after all!
Lastly, for all who do not know about this, if you are in a higher elevation you can still fly 400 feet higher, or those who give the finger to obeying the law, 1600+ feet! |
