flashing lights error
14602 26 2022-12-13
Rseg80
Flight distance : 11765 ft
when I put power to my mini 2 the first two lights light sequencially like it's charging without even hitting the power button.  After a few seconds the right 2 lights next to the power button flash 3 times simultaneously.  Trying to figure out where the problem is so that I can replace the part.  These are not very hard to work on so I do not mind fixing it.  I checked the ribbon cables and they are all secure and completely pressed down.  Gimbal does not initialize so I was thinking it's a gimbal problem but it does not even connect to the remote or phone so I'm thinking it's a power issue.  The question is, is it the power distribution board or the main board.  If someone has some insight to this and not just send it in, please let me know.  Trying not to buy unneccessary parts to try to diagnose the issue.  Also it will not connect to the computer to connect to assistant.
Rob
2022-12-13
Hi there. Thanks for reaching out, and we're sorry to read about the unpleasant experience. This kind of LED indicator may mean a Battery Communication error. Kindly ensure that the battery is properly inserted into the drone. To cross-test, please try to insert the battery into another aircraft if available, or use another battery on the same aircraft. Additionally, please be informed that self-repair is not recommended, and it will void the warranty. Should you have further concerns, please reach back here at DJI Forum. Keep safe.
2022-12-13
Rseg80
DJI Tony Posted at 12-13 21:10
Hey Tony warranty is over on the drone.  Thank you for the reply, I used a working battery from another drone and it gave the same lights and didn’t connect or work.  I pulled and reinserted the battery multiple times too, and still no luck.  The battery plugs directly into the esc, do you think it is faulty?
Rob
2022-12-14
Sean-bumble-bee
Flight distance : 15997 ft
It is most likely that all Tony is permitted to say is that the drone should be sent to a repairer.
Note that if the problem is a defective mainboard or the gimbal then changing either of those will mean that the 'new' combination will have to be re-paired ( = calibrated to each other ).
2022-12-14
Rseg80
Sean-bumble-bee Posted at 12-14 02:46
Thanks for the reply, I understand everything you said, I’m also aware of the Linux scripts that need to be run to repair gimbal and main board.  The problem is that DJI keeps their error codes secret.  I was reading this morning and seems course of action is best
1 clean and check pins 1 and 6 on esc
2 replace esc cable
3 replace esc
I found 1 other person with this issue after I posted this.  Seems 1 person had a cable issue that posted in the comments and another replaced the esc.
Hopefully this might work
This was the insight I was hoping for here
2022-12-14
Rseg80 Posted at 12-14 02:04
Hi, Rseg80. Thanks for your response, and you are welcome. We highly recommend wiping the metal contact pins on the aircraft with isopropyl alcohol (concentration > 75%). We understand that sending the drone for repair is not ideal for you. However, if the issue remains, we strongly suggest that you send it for a proper diagnosis and repair. We appreciate your understanding and cooperation.
2022-12-14
Rseg80
DJI Tony Posted at 12-14 22:32
Here is an update on the issue.  I bought this mini 2 used so that being said, there was not full disclosure I guess.  When I opened it I didn't even realize the white dji stickers where red, as I was replacing the esc I noticed the motherboard and esc sticker were red... I guess this drone took a bath.  Either way I replaced the esc and got the same blinking lights.
I decided to clean the contacts on the main board where the power ribbon connects and now I am getting a new error code and I was hoping you could tell me what these flashing lights mean.
When I plug the battery in the first three lights light sequentially like it is charging and then it switches to a very slow first light ...then second light... then third light.  About 1 flash per second.
I was hoping you could give me insight on what these lights mean.  I'm reassessing my situation and I am starting to think the main board is not good, but maybe there is an easier fix.
Rob
2022-12-17
Rseg80 Posted at 12-17 19:58
We're very sorry to read that the issue remains. Regretfully, there is no remote solution that we can further provide other than sending it back in. If you would consider sending it for repair, our designated team will be able to properly diagnose and repair the damages. Alternatively, we hope that you can get some recommendations here from your DJI Co-Pilots. Thank you for your continued support.
2022-12-18
Rseg80
DJI Tony Posted at 12-18 22:00
So those 3 lights don’t mean anything? 1.. 2..3… about 1second per light.  Thanks
2022-12-19
Johnny_J
Tony (the "expert") forgot to ask for a video showing the remaining LEDs that does not light up!
2022-12-19
Rseg80
Johnny_J Posted at 12-19 05:43
I’m suspecting that this is standard DJI waste your time jargon.  I think he just gave up.  It would be nice if they could at least tell you what the light codes mean.  Give a direction to what parts to test.
2022-12-19
Johnny_J
Rseg80 Posted at 12-19 08:33
They are "administrators". Hence they have no clue whatsoever what a DJI Mini 2 is!
Their wet dream is to be Influencers so they can push their zero-knowledge to the people!
2022-12-19
Rseg80 Posted at 12-19 01:55
Hi, Rseg80. We understand that you would like to check this further, and we'd like to help you with it. To further investigate, we'll need a sample video of the behavior of the LED lights to forward to our engineers for confirmation. We will be waiting for your update. Thank you.
2022-12-21
Rseg80
DJI Tony Posted at 12-21 00:25
Here are the lights
https://youtube.com/shorts/v-Kzm8K4H8o?feature=share
2022-12-21
Rseg80 Posted at 12-21 02:02
Here are the lights
Thank you for sharing this. We have reported your concern to our related team for feedback. We'll update you the soonest time possible. Have a nice day.
2022-12-21
Here are the lights
Hi there. We just need to ask some follow-up questions regarding the issue with your DJI Mini 2. May we know if the battery charges when the official charger is used? We'll wait for your confirmation. Thank you.
2022-12-25
Johnny_J
DJI Tony Posted at 12-25 22:32
Incredible! You cannot find a solution even with a video! Thus you have to hide your incompetence by asking irrelevant questions!
2022-12-26
Rseg80
Johnny_J Posted at 12-26 06:54
Seriously, silly question.  I’ll comply though
2022-12-26
Rseg80
I’ve tried different batteries.  I’ve tried that battery in different drones.  As soon as the battery is plugged in the lights start so it doesn’t matter if I plug it in or not.
I have tried with the original charger and the same result.
However, if I don’t use the battery with the original plug I get the old light sequence error
2022-12-26
Rseg80
2022-12-26
Hi, Johnny_J. During an investigation, all variables must be considered. Our DJI Engineers need the details posted above to further confirm the issue. We welcome and appreciate all suggestions and feedback that contribute to the progress of the said investigation. Hope you have a nice holiday.
2022-12-26
Rseg80 Posted at 12-26 07:31
Thanks for the confirmation, Rob. We'll have this relayed right away. Happy holidays!
2022-12-26
Rseg80 Posted at 2022-12-26 07:31
Hi, Rseg80. We apologize for the late update. We just received an update from our related team. We regret to inform you, as initially suggested, our related team has advised you to send the drone back for repair. We understand that this is not the answer you look forward to hearing, but there is no other remote fix for this kind of issue. We really hope that you would consider this recommendation so you can get to use the drone after. Thank you for your understanding and support.
2023-1-10
Rseg80
DJI Tony Posted at 1-10 00:33
So what you are saying is the lights have no meaning.  I just wanted direction.  So I didn’t have to waste money buying parts until I found the problem.  I’m guessing it’s the main board.  I’ll try a couple cables first.  I have an extra gimbal to try too but I’d have to swap the camera.  I was trying to avoid that.  I do have an extra main board but it’s in a working mini 2 and I didn’t want to take it back apart because I finished repairing that one and it’s up and flying.  Your tech support stinks btw.  I was just trying to get meaning from the lights so I could plan my attack.  I was never really interested in sending it back since the cost to repair is really high through DJI.  Thanks for nothing.
2023-1-10
Rseg80 Posted at 1-10 02:07
We completely understand where you're coming from, and we're sorry that only a repair from DJI can fix this. We respect your decision. We can only hope that you would consider our solution. Thank you, and have a nice day.
2023-1-10
djiuser_vP1piTN1DL9U
Flight distance : 18527 ft
Rseg80 Posted at 2022-12-21 02:02
Here are the lights
Seems you never got this fixed
5-27 21:15
arptrag
Thanks team
5-30 20:53
