Hi there. Thank you for reaching out. Below are the conditions for the DJI Mini 3 Pro to enable Activetrack function.
If a person is set as a tracking subject, the distance between the aircraft and the subject should be 4 to 20 m, and the altitude is 2 to 20 m. (Note: The recommended distance is 5 to 10 m and the recommended altitude is 2 to 10 m.)
If a vehicle/boat is set as a tracking subject, the distance between the aircraft and the subject should be 6 to 100 m, and the altitude is 6 to 100 m. (Note: The recommended distance is 20 to 50 m and the recommended altitude is 10 to 50 m.)
If the aircraft starts to follow the subject, but the distance between the aircraft and the target is not in the range of the above-mentioned distance or altitude, the aircraft will automatically fly into the supporting range. If the aircraft flies within the range of recommended distance and altitude, you will have a better experience of tracking.
If you manage to follow these steps and still have the issue, please provide us a video recording showing the issue for us to check. Please keep us posted. Thank you.
