How do you register your Mic with DJI?
4496 7 2023-2-6
Kravex
Flight distance : 42618 ft
It says in the manual you can register the Mic for an extra years warranty but I can't find anywhere to do it, am I missing something?
2023-2-6
DJI Diana
Flight distance : 2408 ft
Hi there, Kravex. Thank you for your inquiry. Please follow the instructions below on how to register your DJI Mic. Hope this helps.
1. Visit the registration entry for device extended coverage at: https://service.dji.com/product/device-registration
2. Enter the device serial number
3. Click [OK] to confirm registration.
4. The login is successful.
[Notes]
1. Be sure to fill in the serial number on the bottom of the charging station when registering for device extended coverage.
2. The parts under extended warranty are the DJI Mic receiver, DJI Mic transmitter, and DJI Mic charging case.
3. The other parts are still under the original warranty with no extension.
2023-2-6
Kravex
DJI Diana Posted at 2-6 07:17
Thanks for that, I've got it done now.
2023-2-6
DJI Diana
Kravex Posted at 2-6 09:30
Great to know that, Kravex. Should you need to contact us for any reason, please know that we're always here to help.
2023-2-6
djiuser_TNSLcCwZRuf4
Flight distance : 134777 ft
Austria
Hello, I just done it for my 2 DJI Mic Systems. But I didn't get any Mail Answer or confirmation if it was successful. Is this normal?
2023-7-16
KaWo Schu
Ich habe meinen Transmitter registriert über den QR-Code auf der Verpackung mit Eingabe der Seriennummer. Auf dem Handy hatte ich dann folgende Rückmeldung bekommen - siehe Foto. Aber keine Extrabestätigung und bei meinen Geräten bzgl. meines DJI-Kontos ist der Transmitter auch nicht aufgeführt. Wo finde ich den Transmitter als mein neues DJI-Gerät? Z.B für den Fall einer Reparatur-Anmeldung?! IMG_2208.PNG
1-26 09:03
djiuser_Fbp4holIiGxH
Flight distance : 74485 ft
DJI Diana Posted at 2023-2-6 07:17
I think it worked but  i can only see the mini 2 in my account? How can i confirm the warranty extension for the mic 2 '2x transmitter pack. What are the QR codes for on the devices as neither samsung or apple recognise the QR codes.
2-23 03:14
DJI Diana
djiuser_Fbp4holIiGxH Posted at 2-23 03:14
Hi, there. Thank you for bringing this up. Please be sure to fill in the serial number on the bottom of the charging station when registering for device extended coverage. Please visit the registration entry for device extended coverage at: https://service.dji.com/product/device-registration, then enter the device serial number. The serial number of the DJI Mic 2 can be found at the bottom of the DJI Mic 2 Charging Case. I hope this helps.
2-23 17:18
