Air2s unfixable horizon level tilts
1626 8 2023-2-12
equilibrio
Flight distance : 525433 ft
I've noticed that horizon on my Air2s deviates a lot from the appropriate level when using pitch/roll (basically right stick on my RC) and I can't fix it myself. After some time when drone is not moving the gimbal is autoleveling itself, but the issue occurs when the drone moves again. I've already performed:  1) IMU calibration, 2) gimbal calibration, 3) compass calibration. The drone have not had crashes or hard landings. Here's a link to a video showing a problem:  https://www.youtube.com/watch?v=qS4anJkZnO0
The logs are attached to this post.
I will highly appreciate any help in this matter.
DJIFlightRecord_2023-02-12_[13-17-25].rar
591.56 KB, Down times: 6
flight log
2023-2-12
Mobilehomer
Flight distance : 18150351 ft
Try switching from FPV to Follow mode under the Control tab.
2023-2-12
equilibrio
Tried both. The posted video is in follow mode and it is not working properly.
2023-2-12
BladeZ
Flight distance : 1111969 ft
I would check your propellers.  Take them off and reseat them.  I had this happening a few months ago and found that one of my propellers wasn't seated properly.  Sounds corny, I know, but it did help mine.
2023-2-12
equilibrio
I would never have come across this myself. I changed the propellers to new ones, however they were not the cause of the problem. In addition, I performed the following steps to solve the problem:
1. Ensured that the aircraft and the remote controller signal are good, i.e., there is no freezing and gray screen on the image transmission.
2. Pressed and held the image transfer screen on the APP. After the blue circle appeared, I dragged it up or down to control the gimbal. The gimbal moved accordingly.
3. Calibrated the remote controller and rotated the gimbal dial to fill the progress bar. Checked whether the dial can be moved to the max limit - it worked just fine.
4. Restored the gimbal settings to initial settins.
5. After applying the above advices, I noticed during the test flight that the problem was still present. Gimbal was still tilting counterclockwise while flying on side (as seen for example at 0:24 of a movie attached before) and tilting up when flying forward (as seen for example at 0:45 of a movie attached before).
The drone worked fine before with the 'old' phone and the 'old' remote controller but the problem started after the changing the set. I just wonder if there is any chance that this is the cause of the problem.
2023-2-14
Mobilehomer
Take a screen recording with the radar showing instead of the map.
2023-2-14
Hi, equilibrio.  Thank you for reaching out and we're sorry for the inconvenience. We have forwarded the information you provided on this thread to our relevant team for further checking. We will let you know once we received an update. Thank you for your understanding.
2023-2-15
equilibrio
@Mobilehomer
I am posting a link to today's video including radar on screen: https://youtu.be/TiMoMOxT-Ig
You can clearly see the problem in e.g. 0:17, 0:52, 1:25. In 2:10 I changed the mode to FPV to compare with the previously set follow mode.
The flight record is attached to this post, please take a look.
@DJI Gamora
Thank you for your interest in the matter and I look forward to an update from you.
DJIFlightRecord_2023-02-15_[15-44-26].rar
712.6 KB, Down times: 0
Flight record2
2023-2-15
equilibrio Posted at 2-14 12:11
Hi, equilibrio. Thank you for patiently waiting. I sent you a PM, kindly check. Thank you.
2023-2-22
