osmonauta
Hungary
Yes, you should be able to. As an example, this is my first try doing night sky photos and timelapse. Keep in mind, I'm in the city so there are some lights around (which is not the best for night sky photography).
The timelapse was captured using a 30 second interval for 2 hours. Pro mode, using manual exposure, ISO 100 and 25 second shutter. Make sure to watch it in a (close to) dark room or else the stars will be kinda faint. Next time I prolly should pump up the ISO to 200 or 400. Just make sure to do a single ISO setting as opposed to a range when you do timelapse (or a photo).
I have also captured some photos. The photos are Pro mode, manual. The end of the filename contains the settings. There's one at ISO 100 and 30 second shutter. This is the cleanest. You can see the Orion towards the left if you watch it at full 4000x3000 size. I left the White Balance on Auto. You'll get prolly better results setting it to a correct value (...whatever "correct" would be in this case).
There are three ISO 800 test shots as well using 30, 20, and 10 second shutters. You can see they are not as clean as the ISO 100 one, but you can see a bunch of stars even with city lights around.
So yes, I think you could capture northern lights using the right manual settings especially if you are outside the city limits. I suggest make some practice shots beforehand with the night sky.
https://drive.google.com/drive/f ... V3tRkVH?usp=sharing |
