DJI RC remote dead, Black screen no power
1234Next >
24846 120 2022-11-3
eytand
Flight distance : 581043 ft
Chile
I've been using my DJI RC remote with my Mini 3 Pro for about a month. I went to turn on my remote today and it has no power (no lights flash when you click the power button) and the screen doesn't show anything. The unit is fully charged. DJI Support claims there's no combination of hardware buttons that can be used to reset the device and I'll just need to do a warranty replacement. I'm in the middle of a vacation and my drone is essentially useless because I can't use this fancy new remote.
Anyone know of a hardware reset option?
2022-11-3
RobZilla
Flight distance : 1057844 ft
Not sure of a hardware reset option but regarding the power, did you try another USB-C cable and power source to ensure the RC can charge, or is charged?
2022-11-3
eytand
Chile
RobZilla Posted at 11-3 14:24
Yeah I’ve tried 2 different power sources to no luck
2022-11-3
RobZilla
Sorry to hear that, hopefully DJI can answer and help with your issue then.
2022-11-3
Hi, eytand. Thank you for reaching out and we are sorry to read about the difficulties you are experiencing. To further assess the issue, may we know if the RC shows any sign of charging? If yes, can you describe the behavior of the LED lights? Furthermore, we also need to confirm the type of charger that you are using. DJI RC supports up to 15 W (5 V, 3 A) charging power. Please attempt to turn it on by doing a short press and then a long press. If you can share with us a video showing the RC's reaction to charging and turning on, we would appreciate it. We look forward to hearing back from you. Thank you for your cooperation.
2022-11-3
eytand
It shows no sign of charging, there’s no lights on like usual. The same cable charges the drone with no problem.
2022-11-3
Berhatz
Flight distance : 667575 ft
Hello friend! I have the same issue after their Last update, their support told me that it's ok, great? Ok having non working device for my money! Do you know when you drone was made? The quuality of Dji sucks ((
2022-11-3
eytand
Chile
I updated the firmware a couple days ago and flew the drone since then, maybe that’s the cause. What baffles my mind is there’s no way to force restart the device without sending it in.
2022-11-3
Berhatz
eytand Posted at 11-3 15:31
Got it, so awful situation. I'm going to find simple rc without screen. It's more simple. And this new rc is garbage
2022-11-3
DJI Natalia
Berhatz Posted at 11-3 15:22
Hi, there. We are sorry for the inconvenience caused.
May we know how you contact our support and could you please send us the relevant number so that we can confirm your problem with them?
You can also try pressing and holding the power button for about 15s to power on DJI RC and see if it can be powered on.
If it can be powered on then, we suggest you update the firmware to the latest version. If there are still problems, please let us know.
Thank you for your understanding.
2022-11-3
Lieutenant
Try it without the SD card in case it has a short.
Also try holding on/off button for 10 seconds or try holding any button while pressing on/off button.
2022-11-3
Berhatz
Lieutenant Posted at 11-3 18:33
Thanks for the advice, no result. I will try to sell it for spare parts.
2022-11-3
Berhatz
DJI Natalia Posted at 11-3 22:25
Hi, there.
Sorry for the late reply.
You can try to press and hold the power button for about 15s to power off DJI RC. Then power on the remote controller, and it can be powered off normally.
Our rc’s can’t turn on!!!! do you read messages?  I think you are out of touch with reality
2022-11-3
Berhatz
Hi, there.
How can it be updated without even any sign of life? No more conversation in your chat! people should see how you will solve the problem with your defects
2022-11-3
DJI Natalia
Berhatz Posted at 11-3 23:24
Hi, there.
Please don't worry and sorry for the typo, but the suggestions works, you can try to use our suggestions to see if your problem can be resolved.
If you still meet any problems, please let us know or you can send us your DJI RC via this link: https://www.dji.com/support/repair
If there is anything else that we can help with, please let us know as well.
Thank you for your support.
2022-11-3
Berhatz
DJI Natalia Posted at 11-3 23:37
Hi, there.
Also, you can update your firmware via Assistant 2.
Can the assistant see the powered off rc?
2022-11-4
DJI Natalia
Berhatz Posted at 11-4 00:02
Thanks for the soon reply and sorry for the confusion. Assistant 2 can not see the powered-off RC. You may need to try to press and hold the power button for about 15s to power on DJI RC and see if it can be powered on or not. If it can be powered on, you can update your firmware via Assistant 2.
If the above steps fail, please let us know.
Thank you again for your support and soon reply.
2022-11-4
Berhatz
DJI Natalia Posted at 11-4 02:17
Please try to press and hold the power button for about 15s to power off DJI RC. Then power on the remote controller first. And then you can update your firmware via Assistant 2.
What kind of robot are you? May be it’s better to speak another language with you?
2022-11-4
DJI Natalia
Berhatz Posted at 11-4 02:25
Thank you for the reply.
You can try to press and hold the power button for about 15s to power on DJI RC.
1.        If you fail on this step (can not power on your controller), please send us your product.
2.        If you can power it on, please update the firmware to the latest version.
Hope the above explanation can help you with your problem.
2022-11-4
SysAdm
I'm in the exact same situation. My DJI RC is dead. I tried holding the power button for about 15s to power on DJI RC but no luck.
2022-11-4
Berhatz
DJI Natalia Posted at 11-4 02:48
I went to the independent service center today.  They said that the power controller is failing due to the poor quality of the parts.  Once again I am convinced that DJI is no longer the leader.  For a couple of years we fought for the quality of DJI Fly, now it's even worse. You have completely lost me as a client.  I wanted to give you another chance by buying a new drone.  But all in vain!  you could not even answer me, although your employee in the support chat promised that they would contact me.  Disgusting service, now also disgusting drone quality.  I will turn to bloggers for help so that as many people as possible learn about your attitude!
2022-11-4
Berhatz
SysAdm Posted at 11-4 07:27
Hello!  Dji save on the quality of parts, it will be easier for you to buy another drone, or try to return it under warranty.  The problem is massive in new versions from September, but DJI will never admit it
2022-11-4
fans73d93c47
Faced same sitiation today. Went for a vaction to mountains. Came on the top of the mountain. Take out my DJI Mavic 3 Classic. And...DJI RC did not start. At all. Black screen. Nothing happens. Vacation is ruined!!!
2022-12-18
Berhatz
fans73d93c47 Posted at 12-18 04:07
Did you buy this remote together with the drone? I noticed that people have a problem only in such kits
2022-12-20
shishkaby
Same issue, rc died after 6 days of using it
2023-2-3
DJI Natalia
shishkaby Posted at 2-3 00:14
Hi, there.
May we confirm if your DJI RC cannot be powered on?
Thanks in advance.
2023-2-3
shishkaby
DJI Natalia Posted at 2-3 04:12
Hi, there.
Right, I try different charges, cables - totally dead. RC was fully charged.
2023-2-3
shishkaby
Berhatz Posted at 2022-12-20 02:50
I bought RC separately
2023-2-3
DJI Natalia
Hi, there.
Hi, there. Sorry for the belated reply.
1. Please try again by short pressing and then long-pressing the power button.
2. Please replace the charger and charging cable to try.
3. You can also try to press and hold the power button for 15 seconds to force power off the DJI RC, and then restart and try.
(Note: *The USB cable must be disconnected before pressing and holding the power button for 15s to power off the DJI RC.);
4. Connect to the DJI assistant 2 (Consumer Drones Series) for firmware upgrade & refresh.
If you tried above steps and still can not solve this problem, we recommend that you send it back for testing, here is the link to start a repair case: https://repair.dji.com/repair/in ... =brandsite&from=nav
2023-2-7
shishkaby
DJI Natalia Posted at 2-7 05:31
i try all this things
rc was just replaced for a new one by warranty
but quality is horrible, n1 remote that comes with my mavic 3 pro start to loose image and rc signal randomly in 1 month after buying it.
it so strange that remote with expensive mavic 3 pro same that with cheap and old mavic 2 mini
2023-2-9
DJI Natalia
shishkaby Posted at 2-9 01:17
Hi, there. We are sincerely sorry for the inconvenience caused. May we confirm if you still meet problems after replacing the RC? And may we know if your RC-N1 has a problem too?
2023-2-9
shishkaby
DJI Natalia Posted at 2-9 01:38
RC is fine
I'm still have a problem with n1 and should send it to Germany and pay all taxes, but drone was bought in Swiss and Swiss no services to change it, look like cheaper to throw it away
2023-2-9
DJI Natalia
shishkaby Posted at 2-9 01:52
RC is fine
Hi, there. Thanks for your update, we noticed you sent us an email about this problem, we will ask the relevant team to check it asap and reply to you.
2023-2-9
Adrian Illare
Maldives
SysAdm Posted at 2022-11-4 07:27
I have same problem. No sign of life of RC. Fully dead. I will accept any suggestions what to do?
2023-2-25
luc13137
Flight distance : 276880 ft
Received my mini 3 pro Tuesday, activated, did not try to fly because of winter here in Quebec, open RC controller today, in the living room to see if there's an update to do, controller fully charge screen stays black, do not see the DJI logo on white screen, I know it is open because of led lights and controller said " home point updated" brand new and already broken.
Now I hope there will be no assle to return it.
2023-2-25
djiuser_ABfhl9aTYb88
Flight distance : 12549 ft
Maldives
Hello All, please help!!!!
I have the same issue, my dji rc remote is not power on after full charge and latest firmware version... I fly 5,000 km to my vacation and just before going out to shoot tried my drum and found out that I am not alone.... Is there any resolution????
2023-2-27
Jivan Moulandi
Flight distance : 61030 ft
Hello I am in the same boat, I received the Mavic 3 classic yesterday, I just managed to power up the DJI RC as the mavic 3 battery was completely flat. While charging I set up the controller and it worked fine.  I I charged up today led working and the remote look like it was charging. When I unplagged it  and tried to power it up to set up the drone, RC seemed dead no LED light no screen working nothing. I amcompletely ruined and even if I ask for a replacement no way I will receive one by Sunday the day I leave for hiolidays.  Seriously DJI I was wary of upgrading from the Mavic 2 Pro but I was like nah this product are good! aaargg frustration at 100%
2023-3-1
Adrian Illare Posted at 2-25 09:29
Hi there. Thanks for reaching out. We're sorry for the inconvenience. Have you tried the suggestions posted by DJI Natalia in post #38? If yes and the issue remains, you may consider sending the remote controller back for further checking. You may contact Customer Support at (support.dji.com) and arrange a repair request. Should you have other concerns, please reach back here at DJI Forum. Thank you, and have a nice day.
2023-3-1
djiuser_ABfhl9aTYb88 Posted at 2-27 11:42
Hi there. We're sorry you're experiencing the same concern. Kindly perform the troubleshooting steps posted in post #38. If the issue persists, kindly contact our Customer Support at (support.dji.com) for more details about the process. We apologize for the inconvenience. Thank you, and stay safe.
2023-3-1
Alexey_mavic3c
Flight distance : 122060 ft
Faced exactly same issue. Bough it in other country. In my country there is no dji service. No idea what to do. I am disappointed.
2023-3-3
1234Next >
