Error Mapbox controler Gl300E Obsidian
2352 8 2023-2-23
Mike galeano
Colombia
Buen dia tego el siguiente problema con mi Phanton Odsidian control Gl300E, mapbox no funciona  no cargan los mapas quiero saber si puedo volar mi drone asi ? ya vi que es un error que tienen ustedes deseo saber si tiene alguna solucion a esto pues debo hacer un mapa est fin de semana y me preocupa el tema gracias
No funciona la actulizacion
error de descarga
error de descarga
2023-2-23
Hi. Thank you for reaching out and we're sorry for the trouble. The HERE maps do not support offline map download at present. We are communicating with other map application providers on providing offline map downloads in future versions. If the Amaps app is used when the language settings are not set to simplified Chinese, the HERE maps app may fail to be initialized. We suggest refreshing the firmware, or restoring the factory settings of the RC and check if the issue persists. Please keep us posted. Thank you.
2023-2-23
Mike galeano
Colombia
ya lo intente de todas las formas posibles y no cargan los mapas
2023-2-27
Mike galeano Posted at 2-27 09:50
Hi there. We apologize for the inconvenience caused. Please be informed that our engineers just released a remote solution and firmware that will rectify the map issues. You may download the firmware of the remote controller with a screen (GL300E) to the microSD card and then update the firmware manually. Refer to the instructions below for detailed steps.
1. Import the file “update.zip” into the microSD card.
Path for the remote controller firmware: (https://pan-sec.djicorp.com/s/6d4759ww3Z6EZCM).
2. Power off the remote controller and insert the microSD card.
3. Power on the remote controller and tap “Install.”
Kindly keep us posted. Have a nice day.
2023-2-28
Mike B.
Flight distance : 11909 ft
Hola, ve a este foro https://forum.dji.com/forum.php? ... p;page=1#pid2995093 El administrador Tony publicó una solución para el GL300E que funciona bien para mí. Te explica como aplicarlo
2023-3-12
Mike galeano
Colombia
no funciono  la actualizacion
2023-10-5
Mike galeano
Colombia
2023-10-5
Mike galeano
Colombia
Hola DJI Tony ya instale la actualizacion pero no funciono es un GL300E phanton obsidian
2023-10-5
Mike galeano Posted at 10-5 14:53
Hello there. I replied to you from this thread: https://forum.dji.com/forum.php? ... page%3D3&page=2. Have a great day.
2023-10-6
