DJI RC
784 7 2023-3-31
NandoDavid
Portugal
My DJI RC  every time I turn on it asks to calibrate the joisticks and buttons, I make the calibration and when tur on again  and ask for the same again every time blue light
any sugestios on this problem.
2023-3-31
FabioV
Flight distance : 980066 ft
My suggestion is to open a support ticket
2023-3-31
Hi, NandoDavid. Thank you for reaching out. When you tried calibrating the RC, does it do it successfully or are you getting any errors?
2023-3-31
Open a repair request at repair.dji.com
2023-4-1
NandoDavid
Portugal
DJI Gamora Posted at 3-31 19:04
No i calibrate an says ok, but when i use for second time again requires calibration.~
Allways on calibration.
2023-4-2
NandoDavid Posted at 4-2 08:48
Hi, NandoDavid. Thanks for the reply. If the issue persists after going to another environment, please check whether you have magnetic accessories, such as an electronic watch. If you do, try removing the accessory and see if the issue reoccurs. Please back up the existing photos/videos of the remote controller. Then go to the “System Settings” of the remote controller, and perform a factory reset. Please try to calibrate the remote controller again. Please keep us posted.
2023-4-6
NandoDavid
Portugal
Hi again I tried everything but always when I tunn on ask the same, I do the  factory reset ad the same again , I tried on other location and the same, and no I don’t have nothing magnetic closer.
The remote ask for stick calibration but it’s not possible.
Always on calibration.
2023-4-10
NandoDavid Posted at 4-10 04:21
Hi, NandoDavid. Thanks for the update. We're afraid you may have to consider sending the device back for further checking. You may submit a repair request at (repair.dji.com) or contact our Customer Support at (support.dji.com). Warranty service will be applied depending on the assessment result and the warranty status of the drone. Please reach us back here should you have other concerns. Thank you.
2023-4-11
