SOFTWARE UPDATE REQUEST - SNAPSHOT WITH CUSTOM MODE
1661 22 2023-4-24
Italo Grossi
Austria
Hi all and DJI team,
I can't be the only one with this difficulty.
I love the Customs Modes (C1, C2...) avaialble in the OA3. Much better than the GoPro.
However!, and that's a big one, how on earth is it possible that a custom mode can't be used as a Snapshot mode?!
I'm limited to using the Snapshot function with presets modes (video, video HDR, picture...).
The whole point of Custom Modes is too have a quick access to the user presets. If in order to access the presets I must first turn on the camera, choose the mode, then press record it kills the whole point of a quick capture.
Specially if you are actually doing sports and trying to record a moment there is no time to stop what you are doing to go choose the recording mode.
Can DJI please release an update so the snapshot function can be assigned to a user mode?
thanks
2023-4-24
johansenfoto
Flight distance : 1173379 ft
You have to go into menu and make them available for quickswitch
2023-4-24
osmonauta
Hungary
I don't understand where the problem is?
"However!, and that's a big one, how on earth is it possible that a custom mode can't be used as a Snapshot mode?!"
Of course you can.
  • Define your presets. Set your resolution, frame rate, manual mode, white balance, color, shutter speed, etc and save it as a custom preset (eg C1).
  • Assuming you have added the custom presets to the QuickSwith mode, select your custom preset (C1).
  • Power off the camera.
  • Press the camera shutter (record button).
  • The camera will start recording at the last mode selected. Since you have selected (using the above example) C1, the camera will start recording whatever custom presets you have set in C1.
  • If you have 3 custom preset, use the QuickSwith function to select your preset (C1-C3). Or simply swipe on the screen to select it.
  • Press the shutter (record button). The camera will start recording using the parameters saved in your currently selected custom preset (C1-C3).
2023-4-24
DJ DJ
I totally agree. I find myself using the snapshot function very often lately (not to be confused with the quickswitch, totally different story).
Yes, it is just one click more, but that is exactly the time I sometimes lack and so miss a shot when not using the snapshot function.
The cam picks up the last used setting in video or photo mode, but not the custom preset. It always defaults to the standard video or photo mode.
I would prefer the cam to use the last used mode, no matter how I switch it on.
It does so when using the regular power switch but it does not, when using the snapshot function. Imho, that is strange user experience for no reason.
@osmonauta: My cam does behave different than yours. I experience what I have decribed above and that bothered me a while now. No deal breaker, because I simply dial in a general setting in standard video mode that is more or less compatible with the custom preset I use at this moment. Just needlessly awkward when I switch custom presets fast.
2023-4-24
Italo Grossi
Austria
johansenfoto Posted at 4-24 09:14
That's not what I mean. See below my reply with pictures.
2023-4-24
Italo Grossi
Austria
osmonauta Posted at 4-24 09:54
Hi Osmonauta,
thanks for the reply and I'll explain in detail what I see and what I would like to achieve.
I would be glad to find out it's a user mistake.
Screen 1
I swipe down / I choose the top left icon person silhouette / in there I have defined 3 settings: C1, C2 and C3.
Screen 2
I swipe down / Choose QS Quick Switch / In there I have toggled on C1, C2 and C3.
In other words, I have chosen the quick switch function to exclusively work with the defined presets mentioned before.
Screen 3
I swipe down / Choose the nut icon (settings) / Choose the first option Snapshot / In here I can only choose 3 options defined by the system: Video, HDR video and Hyperlapse.
The problem is on screen 3. I don't want my Snapshot to be defined by the system. I want to set my Snapshot button to be either C1, C2 or C3.
You see, I'm using to OA3 while riding a motorcycle and the camera is attached to my helmet.
When the camera is off but I see a good moment coming, I would like to simply press the record button and straight up turns the camera on and starts recording on my predefined customs modes C1, C2 or C3.
As of now the Snapshot function is fixed to what the system has defined.
Let me know if that makes it clear.
thanks again!
2023-4-24
Italo Grossi
Austria
DJ DJ Posted at 4-24 10:21
Precisely! I've just switched from GoPro to OA3 and went on my first motorcycle trip to find this issue .
I'm surprised this hasn't been considered. The whole point os letting the user set its custom modes(C1, C2,...) is to speed things up. But then the customs modes are excluded from the Snapshot menu .
In my case I use the OA3 for motovloging, I simply can't afford while riding to turn the camera on(with thick motorcycle gloves), wait 1-2 seconds to boot up, then press the quick switch button the required amount of times, then finally press start recording. All of this could just be a one button press and instead it has become a 3 button with proper timing while riding a motorcycle.. no chance to make it .
2023-4-24
Italo Grossi
Austria
One comment:
"The camera will start recording at the last mode selected. Since you have selected (using the above example) C1, the camera will start recording whatever custom presets you have set in C1."
This is not correct. I just tested on my camera now. The Snapshot does not take into account the last selected mode.
2023-4-24
Italo Grossi
Austria
Here you can see my QS 3 defined modes:
Here you can see the Snapshot menu:
Snapshot
Snapshot
Ideally the Snapshot Menu should give me the option to choose C1, C2 or C3.
QS
QS
SnapShot
SnapShot
2023-4-24
osmonauta
Hungary
Italo Grossi Posted at 4-24 10:37
Hi Osmonauta,
Ah, ok! Thanks for the explanation! Yes, sorry, I misunderstood.
So let's say you want to record 4K/60fps using 200 ISO on 4000 WB and 1/500 shutter. Why don't you set these parameters before riding? And once you attach the cam to the helmet, you just press RECORD and it will record on those settings. You just have to set it once.
But yes, I hear you, it would be more convenient if the camera would record on the saved custom settings.
2023-4-24
Italo Grossi
Austria
osmonauta Posted at 4-24 10:54
Hi Osmonauta,
it's really not like that haha. I'm sitting in front of the computer with the camera testing everything as I type you.
Let's suppose my C2 mode is 25fps, 4k, Rocksteady.... Let's keep it simple.
I turn on the camera, choose C2 mode and I record a few seconds.
Now I turn off the camera.
Now the camera is OFF and I press record. The Snapshot function is set to "video". I can guarantee you that this video will not have the settings of C2. It will start recording with the pre-defined settings by the factory. It does not take into account the last settings.
Such first world problems but this is driving me nuts.
I just sold all my GoPro equipment and jumped full on on the DJI wagon... 2 OA3 + DJI wireless mic to find out I can't use the way I intended haha.
This is obviously fixable via a Software update. If you get my point please give it an upvote to hopefully DJI can see it.
thanks again for your time.
2023-4-24
DJ DJ
Yes, at least an option in the settings to always start in the last used mode - just as many other cameras or smartphones offer as option.
I tend to use custom presets for my few prefered shooting occasions - one for walking/running with HB, one for action with RS+, one for low light with EIS disabled and other iso settings.
The standard video mode is my playground for any other occasion. So I really would prefer the cam to stick to its setting, no matter how I switch it on
I sometimes happen to hit the other button than intended if it has to go fast and then get a setting I possibly did not want.
2023-4-24
osmonauta
Hungary
Italo Grossi Posted at 4-24 11:07
Hi Osmonauta,
Ok, I understand. But my question was why not just set the parameters manually before riding? In other words, forget the custom settings. I assume  you don't switch shooting modes during a ride, so once you set the parameters, you can turn the camera off and when you press RECORD it will record as you set it.
I use it on my bike. And before riding, I just set my fav recording option and just record away. If I turn the camera off, then later press RECORD, it will start recording as I left it. Of course my settings are not stored in a custom mode that's why I can start shooting where I left off.
2023-4-24
Italo Grossi
Austria
osmonauta Posted at 4-24 11:32
!!! that would definitely help. Let me just test to see if it is really like that
2023-4-24
Italo Grossi
Austria
thanks for the tip!
That will work. I'll just ignore the custom presets and stick to manually setting the settings.
Would be nice to have an update in any case but glad there is a solution for now.
cheers!
2023-4-24
Hi there. Thank you for your feedback. We really appreciate the time and effort you have invested in providing this suggestion to us. Your feedback will be definitely cascaded to the concerned team for further review. Thank you for your understanding and support.
2023-4-24
djiuser_rIHvPvgLuBeO
Would be great if it can get included soon!
2023-4-25
djiuser_xm5s06cGQkmU
Indonesia
Thank god I’m not the only one! This was driving me nuts and I thought I must miss something obvious but it like like DJI missed the obvious. Please give us the option to start snapshots with the last used settings. I have 4 custom modes and me too I would like to use snapshot with the currently set custom mode and not the default video mode.
2023-5-15
Indonesia
2023-5-15
djiuser_nqJy4dbcpzOG
This is a bug. Hoping it'll be fixed soon.
2023-6-26
Nerdworld
Flight distance : 645144 ft
And again... for the very same reason half of my videos are completly ruined because i dared to change the settings for video and "forgot" to switch back to my dashcam settings...
It's just super stupid and hilarious, that this isn't working the same way as on the very first Osmo Action ( ! ) where you could have a "default setting" for the snapshot mode. At this point i'm just super frustrated (as i requested this "feature" now a lot of times) and will now stop using the Osmo for other videos and use my Insta360 instead.
2023-6-28
djiuser_CMc8dpstbFQf
Portugal
Nerdworld Posted at 6-28 11:35
The funny thing is, like you've mentioned this is something that dji had in the first osmo action.. my colleague bought an action 3 and i was struggling to find the same setting mine has.. can't understand why they removed this setting...
2023-8-23
Nerdworld
djiuser_CMc8dpstbFQf Posted at 8-23 11:08
The worst part is, DJI states that "they will communicate this to the devs" and even in the new Osmo Action 4 this is exactly the same. But hey, atleast the ND filters aren't compatible anymore.
2023-9-26
