Mavic Air 2S Unable to Update (App or Dji Assistant)
1442 9 2023-5-5
fansf9f70cc6
Flight distance : 18012 ft
Portugal
Good Afternoon,
My MAVIC Air 2s is unable to update from V   V02.04.2500
iPhone 8 Plus - Installed and Reinstalled the APP DJI Fly, 5 times, nothing worked, only 5G or only Wifi 5.0, 6.0 and bla bla... gives timeout using the profile on DJI APP and on the actual Drone Camera Menu
DJI Assistant - Installed and Reinstalled on MAC Ventura, 2 times, nothing working, didn't go more then... 0%... and gave a "!" error in red.
Can you help please?
I really like the drone but if this continues i will sell it!!!
As an update to DJI Support... "Server exception (2-0)" error appear on the DJI Assistant software, several times
Here you have the DJI Assistant Log so you can relate.
https://1drv.ms/u/s!Ali6tWQOqGnNqET5fPxxcaRDN-qw?e=bxBkq8
Thank You
2023-5-5
bessamachado
Portugal
2023-5-5
sduck
Flight distance : 4315098 ft
Are you using the correct version of DJI Assistant - you need the Dji Assistant (Consumer Drone Series) version.
2023-5-5
fansb48e444b
Portugal
sduck Posted at 5-5 13:03
Yes I'm using the DJI Assistant 2 (Consumer Drones Series)
Support the consumer drones series products, including mavic series.
2023-5-5
Hi, fansf9f70cc6. Thank you for reaching out and we're sorry for the inconvenience. Just to verify, what is the latest version of your Air 2s? Is it v02.04.25.00? Or are you trying to update to v02.04.25.00?
2023-5-6
fansb48e444b
Portugal
DJI Gamora Posted at 5-6 21:14
im trying to update
2023-5-7
Hi, fansb48e444b. Thank you for the reply. Let me forward the logs to our relevant team for checking. I'll let you know once we receive an update.
2023-5-8
Hi, fansb48e444b. Please try to update the firmware using the DJI Fly app. After updating to the latest version, then connect to DJI Assistant 2 to obtain firmware information normally.
To update via the App, please connect the remote controller to the app then click the connection guide to choose the aircraft model from the list, thus triggering the corresponding firmware update.
If the issue persists, please provide a screenshot of the "about" page showing the firmware of the aircraft and RC.
2023-6-15
djiuser_yIxDTsMcorvo
Having problems with my DJI Air 2s not being able to start engine up or take off the ground in normal areas. I keep getting error code 30064 saying unable to take off. I have all of the firmware updated on both the drone and remote controller. Can anyone help with why this is not working? Thanks!!
2023-9-29
djiuser_yIxDTsMcorvo Posted at 9-29 13:08
Hello there. Thank you for reaching out. If I may ask some questions. Are you using the original remote that came with the drone? Was there a firmware update or Flysafe database update before the "30064 Unable to Take Off" error code appeared? And did the drone take off normally before the Error occurred?
Also please check if the battery capacity of the remote controller is enough, (50% and above), if not, please charge it and retry and if there was an SD card inserted, if yes, please ensure the SD card meets the requirements we recommended, or check If it can be resolved by removing the SD card.
( See the list from the link ) https://www.dji.com/global/air-2s/specs
Please keep me posted. Have a great day.
2023-10-7
