DJI Goggles Integra channel mode always in "AUTO"
2976 13 2023-6-15
KnNLmS
Flight distance : 119967 ft
Turkey
Finally i find and bought Integra+MC2 for my Mavic 3. I put the "ham_cfg_support" file to the root of SD and connected everthing. All equipments in latest FW.
I tried to check if the goggles in FCC mode while all running (video transmission working and M3 flying) but the channel mode in AUTO and grayed out, no-way to change it to the manual mode.
Any idea?
integra channel select
2023-6-15
Hi, KnNLmS. Thank you for reaching out. Kindly check if the DJI RC Motion 2 is disconnected, if yes, pls reconnect it. Please remove the SD Card and kindly remove the "ham_cfg_support" file and reinsert then have a try. Please keep us posted.
2023-6-16
KnNLmS
Turkey
Nothing changed, still same.
2023-6-16
KnNLmS Posted at 6-16 08:51
Thank you for keeping us posted and we're sorry for the trouble. I already sent you a PM, kindly please check. Thank you.
2023-6-16
AirVetra
Flight distance : 1096601 ft
Hello, I had the same problem now - can you help me please?
2023-6-22
KnNLmS
Turkey
DJI Paladin Posted at 6-16 20:14
I don't see any PM from you? you can mail me if you like. The problem still exist.
2023-6-23
KnNLmS Posted at 6-23 00:05
Please check your inbox under your profile to check my messages. I will resend it today. Thank you.
2023-6-24
KnNLmS
Turkey
I have made several restart of remote and goggles so i finally done to change it to the manual mode. But the FCC still does not active even after i put the file to the SD card's root.
I have one question; Does FCC hack works only for Avata? Because i'm trying to use it for mt Mavic 3 and doesn't work.
2023-6-29
AirVetra
Any news? What do you do to solve the problem???
2023-7-4
KnNLmS
Turkey
Restart all equipment solved.
But ham_cfg_support doesn't work for M3.
2023-7-5
AirVetra
KnNLmS Posted at 7-5 23:08
And how to restart them?
2023-7-6
KnNLmS
Turkey
AirVetra Posted at 7-6 05:41
power off devices and power on again.
2023-7-6
djiuser_qOXfUtGc6to6
I have the same problem.
Mini 3 Pro,
Integra tested on both v1.02 and v1.03
FPV Motion controller 2
Formated two different SD cards, with and without ham_ file.
Transmission is always greyed out and stuck in Auto. I can not view or set Manual settings regardless. Not even without SD card in Integra
How can I use Manual Mode?
Regards
Edit, restart doesn't work for me
2023-8-25
AirVetra
So, no still no solution?
2023-10-7
