M30T Battery Station Wattage BS30
2624 8 2023-7-5
PilotCOE1
I am looking to run the BS30 intellegent battery station off an inverter from a pickup truck. I am having difficulty locating the wattage that the battery station needs to run. Would a 2000w running /4000 peak watt inverter be able to charge all 4 of my M30T battery pairs (8 total) without issues?
2023-7-5
GsquaredAerials
Wondering the same thing.
2023-7-31
LV_Forestry
Flight distance : 4726654 ft
Latvia
GsquaredAerials Posted at 7-31 07:48
Keep in mind that an inverter never provides "clean" alternating current. This is a solution that can work but that brings a lot of problems with these "smart" stations.
The best solution is the portable gasoline or diesel generator. I have a 2kW mounted on the back of the pickup on silentblock. Perfect in all conditions.
2023-7-31
GsquaredAerials
Good news. I'm assuming dual fuel will work as well? Just looked up a random 2000w one on Amazon and it stated this: "1700 running watts and up to 11.5 hours run time on gasoline, and 1530 running watts and up to 34 hours on propane."
2023-7-31
Hoarfrost
Flight distance : 705974 ft
The Battery Station uses 100-240V at up to 8.0 Amps. That's 800 watts. Quite a load for a truck battery - but doable with the engine running.
2023-8-18
patiam
Flight distance : 32808 ft
Make sure you have pure sine wave not square wav output. It's not just about wattage/amps. You want something that duplicates A/C mains current.
2023-8-19
GsquaredAerials
patiam Posted at 8-19 16:41
Will this work?:
https://www.amazon.com/dp/B08JRVLB7C/?coliid=I1ZR2MYG6YMAFM&colid=1APYSL1CCP9C4&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
2023-8-19
AR_AirPrecision
Flight distance : 2660509 ft
GsquaredAerials Posted at 8-19 20:06
Will this work?:
Check those guys : https://us.ecoflow.com/products/ ... iant=40127469781065
We are using some batteries they have, nice products.
ps: we run a Honda generator https://powerequipment.honda.com/generators/models/EU2200i
2023-8-19
PilotCOE1
Update, while generators do work well, I purchased this inverter and had no issues running the battery station, realistically if the battery station is all you need , a 2000 w is more than enough
https://www.amazon.com/gp/product/B0B5NMDR1G/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2023-8-21
