Explanation of cause of crash
1267 13 2023-8-23
Ashley Ogilvie
Hi All,
My Drone crashed and here is the explanation recieved from DJI
This accident is caused by user error. Below is the analysis result for your reference: The aircraft was piloted under GPS mode. T=02:36, h=-11.1m, d=99.6m, battery 81%, the pilot pushed up the pitch stick, pulled down the throttle stick. T=02:37, h=-12.4m, d=87.2m, battery 81%, the aircraft crashed when flying to the down front. Incident -32.6975037, 25.7517713 Ambient light too low. Vision system and obstacle sensing unavailable. Fly with caution.
Can anyone help me understand this explanation better?
My RC disconnected from my drone and I thought my drone flew away, I found it a few days later.
2023-8-23
Pleomax
Flight distance : 835725 ft
Hi, better to post flightlog.
If you do not know how to retreive your flightlog goto this link for instructions
https://www.phantomhelp.com/LogViewer/Upload/
Then share the link to the uploaded log here on the Forum.
2023-8-23
Hi there, may I ask if you have any objection to the data analysis results? Or is there something you don't understand? Can you provide us with your case number or the serial number of the drone to check it?
2023-8-23
Ashley Ogilvie
DJI Mindy Posted at 8-23 07:19
Yes I object. I not agree with or fully understand the response, If my drone disconnected from the RC and I lost the control of it, why would the report state that I caused it to crash? I do not believe I caused the drone crash.
Secondly, there was enough light so I do not understand why it says there was not enough ambient light.
Is the report saying the drone crashed because there was not enough light or user error. It is not a clear or proper explanation.
Serial Number:3YTBK9D003067X
If you can please assist?
2023-8-23
Ashley Ogilvie Posted at 8-23 22:25
Upon checking, the case is created by your dealer. We recommend you contact the dealer for further explanation and assistance. If they refuse to help, you can contact us and provide the corresponding screenshots.
2023-8-23
JJB*
Flight distance : 12566335 ft
hi,
Just share your flightlog to get more info about what happend to your drone.
With more details you can argue with the dealer.
cheers
JJB
2023-8-23
Ashley Ogilvie
Pleomax Posted at 8-23 06:53
I only have a .DAT file which is 3.3GB and cannot open it or extract it in order to get the correct Flight log for the crash incident. I have the file on a google drive link if that helps?
I've tried opening it with different apps or converting it but I am not winning.
2023-8-24
Ashley Ogilvie
JJB* Posted at 8-23 23:32
hi,
2023-8-24
JJB*
Ashley Ogilvie Posted at 8-24 00:38
Flightlog.txt are om your mobile device or on the RC.
If you can replay the video in the fly app than there is a flightlog.txt.
how to find a flightlog, see link in post #2.
cheers
JJB
2023-8-24
djiuser_0PdWA1aoITie
Flight distance : 621565 ft
Argentina
Good afternoon, I have a similar case today where after 3 minutes it directly fell to the ground, flying into view at a moment the legend Transmission signal blocked and that's it. After a couple of hours I was able to find it, unfortunately it was damaged. Downloaded the flight log and it does NOT indicate any problem
2023-9-24
Argentina
djiuser_0PdWA1aoITie Posted at 9-24 14:13
        Flight time        Altitude        Home Dist        Type        Notification
A        00m 00s        0.0 ft        0 ft        Mode        Mode changed to Motors Started
B        00m 00s        0.0 ft        0 ft        Tip        En vuelo
C        00m 00s        0.0 ft        0 ft        Tip        This is a normal message with no risk and no impact on safetySetting new Return-To-Home altitude to 40m (131 ft). This is a normal message with no risk and no impact on safetyData Recorder File Index is 90. This is a normal message with no risk and no impact on safetySetting new Maximum Flight Altitude to 500m (1640 ft)
D        00m 01s        0.0 ft        0 ft        Mode        Mode changed to AutoTakeoff
E        00m 03s        2.0 ft        1 ft        Tip        This is a normal message with no risk and no impact on safetyPunto de origen actualizado. Altitud de RPO establecida en 40m (Code: 3000001)
F        00m 04s        3.3 ft        1 ft        Mode        Mode changed to P-GPS
G        00m 30s        194.6 ft        4 ft        Mode        Mode changed to PANO
        00m 57s        195.2 ft        2 ft
90% Battery
H        01m 39s        195.5 ft        3 ft        Mode        Mode changed to P-GPS
I        03m 10s        141.4 ft        345 ft        Tip        Señal débil. Ajusta las antenas. Aeronave no conectada al control remoto
J        03m 10s        141.4 ft        345 ft        Warning        La señal de transmisión de imagen puede estar bloqueada. Orienta el control remoto hacia la aeronave y ajusta las antenas para lograr una intensidad de señal óptima o vuela a una mayor altitud (Code: 80004)
81% Battery at maximum distance
2023-9-24
Staffydog33
Flight distance : 1348881 ft
DJI Netherlands will screw you right over.
If you are In UK - Use Heliguys!
Matt
2023-9-24
Wyldwestaz10
Flight distance : 1099068 ft
I have been using Airdata for over three years. It is well worth the cost per year for my Gold Membership. A lot of information and several ways to download the fight logs in different formats as well as an HD flight player with information. I can even download the file and convert into a Dronelink mission and run the DL Virtual Mission viewer and/or run it in Goggle Earth Pro. It would at least have the flight up to the point of disconnection. The free version does give you CSV and KML downloads. You may want to look into it. Enjoy.
2023-9-24
If you want help with analysis of the flight data, you'll have to post it.
To do that ...
Go to: https://www.phantomhelp.com/LogViewer/Upload/
... where you'll find instructions.
That will give a report you can post a link for the report here.
Or just post the .txt file.
Or post a link to the summary report that Airdata gave you.
2023-9-24
