Late Twilight -Night Flights
712 8 2023-8-23
fans97668abb
When landing my Air2S during late twilight/evening, I noticed the unit provides a bright landing light located from the drone's bottom illuminating the ground underneath. I did not see this light during flight. Is there a way to turn on the light on during flight?
2023-8-23
Mobilehomer
Flight distance : 18150351 ft
In a very short answer RTFM!!! There is a lot in there you need to know!
2023-8-23
Brad Bilger
Flight distance : 14843274 ft
https://youtu.be/QL3sOhgS8b4?si=eB6u22yLxhWKiZ6e
Search YouTube. Very helpful. And do read the manual.
2023-8-23
The Saint
Flight distance : 6260171 ft
I have had DJI drones where you can turn the light on underneath; the setting says "Always On."
2023-8-23
Brad Bilger
The Saint Posted at 8-23 13:12
The fn key (function key) can be programed to manually turn the light on and off asking with several other actions. Dji fly app. 3 dots upper right,  control,  scroll down to function button and set it up. Makes it a whole lot easier to spot at twilight.
2023-8-23
Hi there. Thank you for reaching out. The Bottom Auxiliary light can be set in DJI Fly. If you set it to Auto, it is automatically enabled when the environment light is too weak. Note that the Vision System camera performance may be affected when the Auxiliary Button Light is enabled. fly with caution if the area has a weak GPS signal. Please don't hesitate to reach us if you have other inquiries. Have a nice day ahead!
2023-8-23
dreamtuner
Flight distance : 2068376 ft
Bangladesh
Yes. But keeping it on continuously will add heat to the already hot heatsink in flight, and impact the battery (flight time) a little more.
2023-8-23
fans97668abb
Brad Bilger Posted at 8-23 13:52
it worked  and thks for the help
2023-8-24
fans97668abb
Mobilehomer Posted at 8-23 08:29
very helpful -NOT
2023-8-24
