MiliMedPy
Flight distance : 121198 ft
Paraguay
Hello everyone.
I had an event with a MAVIC AIR 2.
I was doing some aerial shots in a field and in flight I get a "gimbal overheating" alert or something like that.
As it worked well, I continued the flight until it had to return due to lack of battery.
Unfortunately the battery did not give me time and upon reaching the landing zone, the drone fell from a height of approximately 10 meters. Luckily nothing happened to the drone, nothing broke, it was intact, but the gimbal stopped working, after that I get error 40011 and the gimbal does not respond or stabilize, but when the drone is turned on it manages to calibrate and move (typical DJI movement) also when it is off it has free movement on its axis.
Visually it does not seem broken or loose. What could have happened to the gimbal? Should I replace it entirely or just replace the wires? I clarify that there is transmission from the camera to the APP.
I would appreciate everyone's help
