New DJI Air 3 Firmware Released (04/23/2024)
39042 237 2023-7-25
BlairAir
Flight distance : 16780791 ft
franceslup Posted at 8-29 10:59
After updating to firmware version v01.00.06.00 for the RC 2, every time I turn it on with SD in it, it ask me to go in profile, memory to set SD card as current memory. Is it a new bug?
I have the exact same issue - worse, it does NOT save the setting, and next restart of the RC-2 I have to perform it again, time after time. Please fix this urgently - this is a serious usability bug. Its not good when a firmware update that  only lists "Fixed Some Bugs" - doesn't give ANY information about WHAT bugs, and yet, I had no usability issues before this update and now I HAVE BUGS. Please correct and issue a patched version of this flawed update. Absolute worst update - and, I cannot revert to the previous update with DJI Assistant for Consumer Drones - the previous code was erased, so I cannot roll back. I have reset the controller and the Aircraft BACK to Factory settings, formatted the SD Card, Tried another card and everything else I can think of. Please. I cannot be dealing with this every flight.
2023-8-31
itsalbertZ
Flight distance : 988310 ft
Hopefully we can know what bugs are fixed
2023-8-31
MavGuido
Flight distance : 338793 ft
I have the same SD onscreen info, bad!
2023-8-31
franceslup
Flight distance : 307602 ft
BlairAir Posted at 8-31 10:18
I confirm, tried to switch SD with a new one, to restore firmware… nothing changed and quite boring
2023-8-31
rpsd
Flight distance : 1240 ft
Confirmed. Mine is doing the exact sam thing as you guys are describing.
Did anyone test this release? I think having a SD card in your controller is quite common.
2023-8-31
RappeFiets
Flight distance : 139642 ft
rpsd Posted at 8-31 17:28
Same here, also the sd message at every startup.
2023-8-31
Rob.01A
Flight distance : 128888 ft
BlairAir Posted at 8-31 07:17
Same here - I believe they (DJI) were working on an SD Card issue some had, where they could NOT save to the card, regardless of settings. I did NOT have that issue, But I SURE HAVE THIS ONE. Every Restart of the controller, and does not save settings. I have tried:
* Multiple cards
Too bad there is no response from a DJI admin right now.
2023-8-31
kan76
Flight distance : 9270666 ft
Bulgaria
DJI please add digital zoom to photos mode in Air 3 please and also HDR mode like Air 2
2023-9-1
djiuser_RjsRw6g1kxaq
My Air is behaving weirdly on active track mode and POI mode.......it just wobbles at the same place instead of tracking (I have a video don't know how to post here) I'm suspecting it happened after this update. How to fix this...
2023-9-1
BlairAir
Same problem.  I had no issues until upgrading with this FW Package that includes V01.00.0400 for RC-2. I now get a dialog EVERY RESTART OF RC-2: "SD Card inserted - go to Profile, Settings, Storage to switch current storage.
This does not save, nor does it WORK. I do it every restart - no files save to SD Card. I have tried over 20 cards, including brand new from Sanddisk, Samsung, Lexar. I have reset the controller to factory settings, i have REFRESHED THE FIRMWARE with DJI Assistant 2 for Consumer Drones (multiple times) - also my previous firmware was erased by this update, so I cannot uninstall and apply V.01.00.0300. WHY?
ALSO - Why is DJI Not fixing this? This is a MAJOR BUG  that was INTRODUCED with this firmware..
Please help. I own every DJI Drone Product,  yet rarely if ever do I see BUGS CREATED by new Firmware. Cpuld DJI issue a a changelist readme, of the type every technical company in the world uses for firmware update documentation?
Really disappointed.
2023-9-1
Outlukgh
Ghana
my camera is no longer transimitting to the RC2 after this update and I'm helpless!! This is quite disappointing DJI
2023-9-1
H3llo
djiuser_RjsRw6g1kxaq Posted at 9-1 11:05
Can you record it with your phone and upload it to YT or VIMEO and share the link?
2023-9-1
H3llo Posted at 9-1 19:13
Can you record it with your phone and upload it to YT or VIMEO and share the link?It is Air 3 with RC2
https://youtu.be/cH8rS6LiQeQ
https://youtu.be/3et74qk49UQ
2023-9-2
BlairAir Posted at 9-1 11:19
Same issue
2023-9-2
KLRSKIR
Flight distance : 28650751 ft
djiuser_RjsRw6g1kxaq Posted at 9-2 06:03
Very odd indeed. I would try to refresh the firmware of both the aircraft and the controller and see if that fixes the issue.
2023-9-2
H3llo
That's looks bad. Is it only wobbling on POI mode?
2023-9-2
H3llo Posted at 9-2 06:40
Yes. on POI it wobbles.  On active track it says there...it won't follow at all
2023-9-2
KLRSKIR Posted at 9-2 06:19
Did refresh couple of times and calibrated as well....same thing
2023-9-2
And is it normal that vision sensors turn on ONLY when I box a target....rest of the time all sensors show unavailable even in bypass or brake mode
2023-9-2
Thomas Chen
Flight distance : 3058848 ft
Taiwan
My Air 3 with RC2 can't upload fly data to cloud automatically after I upgraded FW & DJI fly.
Updated
The Air 3 & RC2 upload fly data to cloud automatically are normal now after I reset both.
2023-9-2
djiuser_5TilqcF0PqbL
Flight distance : 151135 ft
Hello, the DJI RC-2 seems to have dual band selection issues and does not pick the right transmission band according to the right environment. Causing the drone to loose signal quickly. It seems that at time where the drone is flown in a rural environment a setting fit for a 2.4ghz transmission band, the RC remote selects a 5.8ghz band and at time when flown in a heavily dens location the RC remote picks a 2.4ghz band instead of the proper 5.8ghz band.
If you are able to try and find a sulotion to improve the transmission picking it would be highly appreciated, as at the moment I manually choose the transmission best suited for the environment I am flying in.
2023-9-2
franceslup Posted at 8-29 21:51
I tried to switch sd card with no result.
I prefer to don’t refresh firmware because it works, just this pop up every time I turn on the RC.
Hi, franceslup. Thank you for the update. We'll forward it to our relevant team for further checking.
2023-9-2
Rob.01A Posted at 8-29 22:03
I have refresh the firmware versions of the drone and RC using the DJI Assistant 2 (Consumer Drones Series) but the pop up stays every time when starting the RC.
Hi, Rob.01A. Thank you for the cooperation. We'll forward it to our relevant team for further checking.  We'll keep you posted.
2023-9-2
* Multiple cards
Hi, BlairAir. Thank you for reporting. We'll forward it to our relevant team for further checking. We'll keep you posted.
2023-9-2
Hi, franceslup. Thank you for patiently waiting. We have confirmed that the meesage that appears after turning on the DJI RC 2 is just a reminder and not a bug. It is just there to remind you if you would like to switch the present storage location. If you don't want to switch the stroage location, just tap "OK" under this message and it will disappear. Hope this helps. Thank you for your kind understanding.
2023-9-3
Hi, Rob.01A. Thank you for patiently waiting. We already received feedback from our relevant team, please refer to our reply from this post. Thank you.
2023-9-3
BlairAir Posted at 8-31 07:35
Here is another report - happens EVERY RESTART and happens to several dozen friends I have on YouTube. I had no issue before the update - Here is a description of the new bug that some are experiencing. One of the packages released; v01.00.04.00 for RC-2 -once installed, causes a dialog to pop up on every restart of the RC-2 Controller.
The message is via a dialog stating "SDcard inserted - Go to Profile, Settings, Storage to switch the current storage location." The choices made are not saved. You must repeat this on every restart. I am linking a thread that shows what the popup looks like. I have no idea how prevalent this is, but I have been unable to resolve it by reformatting the SD card, or by resetting the RC-2 to factory settings. I've wiped, reset, replaced the card, and tried multiple SIZE cards and other variables, The issue persists. I do suspect DJI was working on an issue with saving to an SDcard that I know of. I did NOT have that issue, but I sure have this one!
Hi, BlairAir. Thank you for patiently waiting. We already received feedback from our relevant team, please refer to our reply from this post. Thank you.
2023-9-3
MavGuido Posted at 8-31 12:32
Hi, MavGuido. Please refer to our reply from this post regarding this concern. Thank you.
2023-9-3
Hi, rpsd. Please refer to our reply from this post regarding this concern. Thank you.
2023-9-3
RappeFiets Posted at 8-31 18:03
Hi, RappeFiets. Please refer to our reply from this post regarding this concern. Thank you.
2023-9-3
kan76 Posted at 9-1 04:18
Hi, kan76. We will take it as a suggestion of yours and will forward it to our relevant team. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you for your understanding and support.
2023-9-3
Outlukgh Posted at 9-1 14:10
Hi, Outlukgh. Thank you for reaching out and we're sorry for the inconvenience. Are you getting any error messages? If yes, please provide us a screenshot for further checking. We'll wait for your reply. Thank you.
2023-9-3
MavGuido
DJI Gamora Posted at 9-3 07:43
No that did not help, while the same message comes back after each booting up the RC!
If it cames once and i check OK and then it gones forever, that is normal and understandable, but not everytime i turn on the RC! No one need that and in the past DJI did not have some hint like that.
2023-9-3
Rob.01A
MavGuido Posted at 9-3 14:00
I agree on that, it comes back after each booting up the RC.
And that is no normal!
2023-9-3
franceslup
Ok but it happens also after i switched.
Why remind me that if i alredy did it?
2023-9-4
KLRSKIR
franceslup Posted at 9-4 02:15
It's going to happen every time now. Just hit "OK" and everything will stay as you set it up. Annoying? Yes!
2023-9-4
Rob.01A
Issue has been solved with the latest firmware v01.00.07.00
2023-9-5
virtual
Flight distance : 4897142 ft
Czechia
Rob.01A Posted at 9-5 07:29
Thanks for notification!
2023-9-5
Mberger Drones
Flight distance : 3901165 ft
Very good, now release the firmware update for DJI AIR 3 compatibility with DJI RC PRO, DJI, have respect for your users.
2023-9-7
Flormo2002
Flight distance : 13686729 ft
Mberger Drones Posted at 9-7 12:24
Agree 100%. Come on now....
2023-9-7
