Terra 3.7.0 Multispectral problem
12
3174 74 2023-5-31
DJI Wanda
intocarlogmail.com Posted at 6-18 02:17
Hi Wanda,
I also have the same problem with the Terra 3.7.3 version on Windows 11 Pro, I attach two screenshots, the first with Terra and the second with the same dataset but processed with a different software:
Hello, there. Sorry for the inconvenience. Please refer to #19 and #37 and send us the required data so that we can consult with our engineers.
2023-6-19
DJI Wanda
erwan lb Posted at 6-15 21:38
I just sent you the link. the processing is done with dji terra 3.7.0 but the problem remains the same with version 3.7.3
Hello, sorry for the inconvenience. Our engineers analyzed the data and would like to confirm whether you used a calibration board with known reflectivity.
2023-6-25
erwan lb
on the flight I sent you I used a parrot sequoia calibration plate with the values ​​recommended for sequoia. they are wrong for the mavic 3 but dji still does not make a calibration plate.... i will have to receive a micasense plate in the next few days and work with a photonics specialist to try to refine the settings. I restarted the dji terra processing of the same flight without using the calibration plate, letting terra "autocalibrate" the data and the problem remained the same
2023-6-26
LV_Forestry
Flight distance : 4726654 ft
Latvia
erwan lb Posted at 6-26 00:34
I find it hard to grasp this facination for reflectance targets.  The drone is natively equipped with a sun sensor which does its job very well, provided that the flight plan has the right trajectory and the flight is made at the right time of day.  You are free to invest in a Micasense target, but what else will you do with it?
I mean, what result do you expect?  My best advice, rather invest in a serious software.  Terra is more of a development thing than a quality platform.
2023-6-26
Rodrigo ASR
Same Issue here with Mavic 3ME and version 3.7.3
*Oversaturation is caused by HDR screenshot in W11
2023-6-26
DJI Wanda
Sorry for the late response. Kindly understand that we will not receive a notification unless you reply to our post directly.
For your issue, please tell us the calibration icon and the corresponding reflectance information used by the reflectance calibration plate;
Also, may we know what language you used in DJI Terra?
2023-6-28
erwan lb
terra is in french. here are the reflectance values ​​but I repeat anyway that if I do not use the calibration plate the problem is the same
green: 0.186
red: 0.199
rededge: 0.229
black: 0.263
2023-6-28
ryuh
DJI Wanda Posted at 6-25 00:00
I am also facing the same issue with M3M and Terra 3.7.0/3.7.3. Terra 3.6.8 didn't have this issue, so I was using it for M3M data process, but since the recent update on the certificate verification service, it does not allow me to use older version of Terra anymore, as I am using the 3-months trial license.
Please do something as soon as possible, otherwise I can not evaluate the software.
I tried both with/without the reflectance calibration, but the result was same.
2023-7-4
DJI Wanda
erwan lb Posted at 6-28 01:21
green: 0.186
Got it. We will let them know.
Kindly reply to our post directly so that we can receive the notification.
2023-7-4
DJI Wanda
ryuh Posted at 7-4 06:26
Sorry for the late response. I will consult your issue with our teams first.
2023-7-4
DJI Wanda
green: 0.186
Hi, would you please change the language to English and try again?
2023-7-4
DJI Wanda
May we know if you choose the language in English? If not, please change the language to English and tell us your feedback.
2023-7-4
erwan lb
DJI Wanda Posted at 7-4 23:25
I just did the test in English, the problem is the same
2023-7-5
DJI Wanda
erwan lb Posted at 7-5 01:51
If so, you are advised to use DJI Terra v.3.6.8 first. We will optimize the issue in the later version.
2023-7-5
erwan lb
DJI Wanda Posted at 7-5 02:04
yes but when a functional version will be released. since terra 3.0 the reconstructions are catastrophic and 3.6.8 does not escape the problems encountered systematically since the arrival of version 3. (see pictures below, in first 2.3.3 in second 3.6.8) .the microplots are systematically distorted (in multispectral, in rgb it's good) on all versions 3 which was not the case with 2.3.3
2023-7-5
ryuh
DJI Wanda Posted at 7-4 23:27
Thank you for your reply.
Yes, I use English for the setting from the begining.
2023-7-5
LV_Forestry
Latvia
Can we know the verdict of the photonics specialist?
2023-7-5
djiuser_fWDzrYKUDin1
Colombia
Hi same happen to me... I used 3.6.8 but there is no license on this version. so again Im on 3.7.3 and there is again the problem....
2023-7-5
DJI Wanda
erwan lb Posted at 7-5 03:49
It seems this issue is different from the beginning. Would you please upload the data of the second picture for us? It requires to do a separate analysis.
2023-7-6
DJI Wanda
ryuh Posted at 7-5 07:42
Would you please wait for the new version? After release, please test it again and tell us your feedback. Please attach the screenshot so that we can better understand your issue.
2023-7-6
erwan lb
DJI Wanda Posted at 7-6 02:04
I just emailed you a link. the problem is probably different, but here is the answer given to me by dji support a year ago
Our engineers performed reconstruction with your dataset and reproduced the same misalignment problem. After analysis, they found it is due to the change of algorithm of DJI Terra v3.0 and later, in which the accuracy is lower than v2.3.3 if the overlapping rate is not high enough in some cases. They have received some similar feedback recently and are stepping up to fix this issue in the future version. Please visit https://www.dji.com/downloads/products/dji-terra for any updates. As a temporary workaround, kindly increase the overlapping rate to avoid the misalignment. Pardon us for the inconvenience caused.
I haven't seen any improvement since, regarding overlapping rate I'm usually 80% frontal and 80% lateral
2023-7-6
erwan lb
erwan lb Posted at 7-6 21:44
I have just tested with 3.7.6 the multispectral processing works again with a rendering very close to 3.6.8, therefore with deformation
2023-7-7
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know if this issue has been resolved with the new released version?
2023-7-8
erwan lb
DJI Wanda Posted at 7-8 01:34
new version corrects the problem that appeared on 3.7 and 3.7.3 but continues to curve the microplots like all versions3, 2.3.3 remains more efficient
2023-7-11
DJI Wanda
erwan lb Posted at 7-11 04:32
Got it. I still can not open the link and access the data you uploaded.
2023-7-12
DJI Wanda
Hi, we have produced the issue from our side. We will escalate your issue to our R&D departments. It will take a longer time to analyze about 3-5 weeks. If we have any updates, we will copy the information here.
2023-7-20
djiuser_0lOR3hGwAwHk
DJI Wanda Posted at 7-20 03:57
Just a quick update from my side is that version 3.7.6 seems to work fine with the same computer I was having issues with before.
So what ever you did there worked for me!
2023-8-3
DJI Wanda
djiuser_0lOR3hGwAwHk Posted at 8-3 05:18
Thank you for your feedback. We are glad to hear that. Please let us know if you have any questions.
2023-8-4
erwan lb
and now with version 3.8 I can no longer do a multispectral mission, it asks me to reactivate an old license from 2021 while I have a permanent license that is activated
suddenly I can do rgb reconstruction but no multispectra
2023-9-5
erwan lb
DJI Wanda Posted at 8-4 04:18
2023-9-5
DJI Wanda
erwan lb Posted at 9-5 12:54
it asks me to reactivate an old license from 2021 while I have a permanent license that is activated.
Hello, there. Can we have a picture of this?
2023-9-6
erwan lb
DJI Wanda Posted at 9-6 04:17
hello wanda
2023-9-6
DJI Wanda
Thank you. We are consulting with them.
2023-9-7
erwan lb
I just did a test again and it doesn't work in RGB either
if I click on multispectral, the licensing problem appears immediately, if I click on visible light I can download the photos but when I click on start reconstruction the license request also reappears
2023-9-7
DJI Wanda
erwan lb Posted at 9-7 02:14
Hi, we will recommend you contact our support to unbind the current license on your computer.
Here is the link: https://www.dji.com/support/repair?site=brandsite&from=footer
2023-9-7
12
