Anyone used Night Fly LED Landing light?
523 7 2023-9-12
Ranjan
I shoot real estate video in cine mode & in my testing at night I find that inspite locked to 30+ satelite the VPS sensor are not able to keep the drone stable on the path I intend to fly. The drone drifts away while I am wanting it to go in a straight line forward or sideways. To compund the problem I have to fly either over the swimming pool (house reflecting in pool) or the garden which has constant thick green grass (IR sensor fails to work on green evenly grown grass)
SO I am thinking to get one of these LED light which has slow/fast flashing mode & a constant light mode so the VPS sensor can recognize the below surface & remain on the path I am flying. Has anyone used such LED light for night flight?
2023-9-12
Potato mini
Flight distance : 7275348 ft
No but I would be interested to see what everyone else says
2023-9-12
I don't, but we are not allowed to fly at night here in NL.
2023-11-11
Sean-bumble-bee
Flight distance : 15997 ft
I would go with a white light only version ...... as DJI do on some drones.
2023-11-11
Flight distance : 2354357 ft
Coloured LED are not as bright as white, you don't really need it on the drone though, get a bright LED for the actual landing area, stick it on an el'cheapo tripod aimed at the landing point
2023-11-11
Mobilehomer
Flight distance : 18150351 ft
ANY add-on light will put you overweight!
2023-11-11
Ranjan
Thanks Guys for all the suggestions, I have decided to update to mIni 4 pro sometime next year which has white landing light that should be ideal to keep the drone from drifting away while I am wanting it to go in a straight line forward or sideways.  The VPS sensor needs bright light to keep it on the path even with 32 satellites locked when you are flying low (1-3m height) in darkness.
2023-11-11
Sam654
Flight distance : 132667 ft
"The drone can not take off in low light."
Is this even true? I've not yet tried a night flight, but I know others have.
Doesn't make sense, as the downward vision isn't even active until after you take off. I'm not inclined to trust this ad.
The downward vision an d IR does have a limited effective range, but if you are only flying low, you may be within that range.
2023-11-12
