Mini 4 in EASA will be capped to 120m no matter what
123Next >
9841 116 2023-9-26
gnirtS
Flight distance : 5712575 ft
Japan
From Philip Blooms initial impressions:-
Philip Bloom - Following on from yesterday’s post… DJI MINI 4 PRO... | Facebook
EU HEIGHT RESTRICTION
In April 2024 in the EU any drone under 250g needs to be labelled C-0 and is banned from going over 120m for anything. DJI has decided to do this early for the Mini 4 Pro.
From April 2024 every new Mini 3 Pro will also have this restriction, and they will also bring out firmware for current Mini 3 Pros to add this restriction ALTHOUGH you do not have to update your drone. It's optional; you just won't be able to get any new features if they add any.
This info is direct from my DJI guy.
So forget flying higher if next to cliffs, hills, obstacles.  Its a flat 120m.
2023-9-26
SeehawerB
Flight distance : 5414203 ft
That's very bad. They do not have to do that to the Mini 3 Pro. This means firmware freeze for me. Hopefully it hasn't been done in yesterdays update V01.00.0700.
2023-9-26
SeehawerB
Just checked it, height limit still is 500m.
I will now opt out on any future firmware updates for the M3P.
2023-9-26
greg_p
Flight distance : 243865 ft
He needs to go more in details :
120m AGL or 120m Above takeoff altitude makes a huge difference.
https://www.easa.europa.eu/en/do ... tegory-civil-drones
Applyable from 1st Jan 2024 is 120M AGL, and now if above takeoff height. It makes a great difference.
2023-9-26
gnirtS
Japan
Which, if you could be bothered (were the words too long for you?) to read you'd see is (i) exactly what he said and (ii) an official DJI employee confirmed would be introduced for C0.
2023-9-26
greg_p
sorry for being a bit rude, actually I corrected.
2023-9-26
I bet yesterdays Mini 3 Pro firmware included this and its date bound,  so as soon as we reach April it will activate.  If someone has updated already perhaps you could change the date to next April and see what happens.
2023-9-26
Mavic57pro2
Flight distance : 3772247 ft
I visit northern Norway reguraly, their drone code is clear, see infographic, its keep within 120m from the earths surface. You could be 300 metres up from your take off point as long as your less than 120 metres from the earths surface.
No mention of changes on their websites.
2023-9-27
Steph Jant
Flight distance : 276542 ft
Mavic57pro2 Posted at 9-27 11:58
No mention of changes on their websites.[Image]
But you won’t know if you are 120m AGL if flying up a mountain or hill because altitude is measured from the take off position
2023-9-27
Mavic57pro2
Its how I read it, it does say in the rules "Earths surface".
2023-9-27
Hi there. Thank you for reaching out. In accordance with the new European Drone Regulation that will come into effect on 1 January 2024, DJI's Mini 4 Pro will be launched with a C0 class identification label and therefore be restricted to an altitude limit of 120m that cannot be increased to any scenario (https://eur-lex.europa.eu/legal- ... ri=CELEX:32019R0945 - ANNEX, Part 1). This measure has been introduced by the European Union Aviation Safety Agency (EASA) to allow safe flight operations for drones weighing less than 250 grams. In accordance with the same European Drone Regulation, all other currently-available drones of the DJI Mini series (e.g. Mini 2 SE, Mini 3, Mini 3 Pro) will be restricted to an altitude limit of 120m later this year via a DJI firmware update. Customers of the above-named, currently-available DJI Mini-series drones (before Mini 4 Pro) will be able to apply retroactively for C0 class identification labels in Q4 this year via a process we will share in due course. Thank you for your understanding and support.
2023-9-27
Ms Ivy
Flight distance : 21888163 ft
DJI Paladin Posted at 9-27 19:17
Will The Air 3  be capped at 120m as well?
2023-9-27
Bigplumbs
Flight distance : 620164 ft
SeehawerB Posted at 9-26 21:25
If it ain’t broke don’t fix it. If your drone is doing all you want don’t update it.
If this 120 height is true that is a reason that I won’t buy it. DJI are not the policemen in this and should not act so
2023-9-27
Bigplumbs
gnirtS Posted at 9-26 22:49
What on earth is an official DJI employee. Cos DJI never get it wrong or give bad advice do they
2023-9-27
Bigplumbs
You don’t say where the 120 m is measured from
2023-9-27
Bigplumbs
Another very good reason not to buy new drones and not to update.
DJI please be aware that the U.K. is not an EASA country and stop being the drone police it is not your place to do that
2023-9-27
Burt37
Flight distance : 4009 ft
SeehawerB Posted at 9-26 21:28
You said that the last time as well...
Good willpower...
https://forum.dji.com/forum.php? ... 016&pid=3072387
I know how hard it is to resist to a new firmware...
2023-9-27
LV_Forestry
Flight distance : 4726654 ft
Latvia
Bigplumbs Posted at 9-27 21:17
Go read the text he linked. DJI didn't invent anything, the law imposes a maximum restriction of 120m from the takeoff point for category C0. That's all !
2023-9-27
Burt37
So where do we go from here? If the smallest drone is only allowed to 120 metre and you already have all the other limitations for the bigger drones, does it mean the game is over?
2023-9-27
LV_Forestry
Latvia
Burt37 Posted at 9-27 22:29
In reality this doesn't change much, except in special cases in the mountains for example where it can become restrictive.
The altimeter has always been set to zero when the drone starts, then when it reaches 120m we know that we have reached the limit.
You must use third-party software like UGCS which integrates a 3D model of the terrain to know the true AGL height.
It's just whining, that's all.
2023-9-27
Burt37
LV_Forestry Posted at 9-27 22:35
I was under the impression that we just went from a warning to a real limitation...
2023-9-27
LV_Forestry
Latvia
Burt37 Posted at 9-27 22:58
It is what it is. C0 = no need for an exam.
2023-9-27
Sean-bumble-bee
Flight distance : 15997 ft
Paladin, will "all other currently-available drones of the DJI Mini series (e.g. Mini 2 SE, Mini 3, Mini 3 Pro) " also apply to the Mini 2 and Mini SE which, at least in theory, appear to still be available from DJI ?What about the Mavic Mini? Which is no longer available from DJI.
2023-9-27
Burt37
LV_Forestry Posted at 9-27 23:00
Perhaps we are not communicating correctly here...
Is it a simple warning on the screen or a hardware limitation for the drone???
Is it better?
EDIT
It's all good. I have already found the answer...
https://forum.dji.com/forum.php? ... 334&pid=3139362
2023-9-27
LV_Forestry
Latvia
Burt37 Posted at 9-27 23:03
Ahhhh! Got it
Its a limitation.
Then in addition if you use bigger battery there is a warning message.
2023-9-27
Burt37
LV_Forestry Posted at 9-27 23:06
Ahhhh! Got it
Its a limitation.
Thanks mate but that seems the opposite of what DJI Paladin just replied in the other thread...
2023-9-27
LV_Forestry
Latvia
Burt37 Posted at 9-27 23:07
He refer to the law 2019/945. Which in category C0 mentioned that the max altitude is 120m from take off point.
2023-9-27
Burt37
LV_Forestry Posted at 9-27 23:13
Not really...
Quote:
"Hi there. Thank you for reaching out. Yes, we can set the maximum altitude of the DJI Mini 4 Pro to 500m under the DJI Fly app > Safety > Flight Protection when flying your drone in the UK."
2023-9-27
Steph Jant
I think this EASA-imposed restriction is a red herring for most drone pilots.
Who would want to fly a drone up the slope of a hill or mountain anyway unless you wanted to film yourself climbing up a cliff face or you wanted to track yourself driving a car through the mountains or riding a bike uphill?  I cannot think of a single scenario where you would want to do this.
I concede you might want to fly a drone higher than 120m to clear an obstacle or clear the top of a hill, but in doing so you then run the risk of losing VLOS and/or you could lose connectivity between the drone and the RC.
I have been flying drones for years and have never needed to fly above 120m, even when flying in the French Alps (where I take my drone every year).
So I really do think this 120m restriction in the EU is irrelevant to most drone pilots (unless you’re doing the things I have listed above).
2023-9-27
Space Dream
Better to stay with no further updates but i believe DJI will seduce us with some new features
of 120m later this year via a DJI firmware update !
2023-9-27
LV_Forestry
Latvia
Burt37 Posted at 9-27 23:16
Not really...
Quote:
In the UK yes. Not in EU
2023-9-27
Burt37
LV_Forestry Posted at 9-27 23:36
Thank you mate... I knew I was missing something there...
2023-9-27
fansf2406672
Flight distance : 13902074 ft
It's obviously a slip of the tongue, due to conflicting wordings.
2023-9-28
LV_Forestry
Latvia
fansf2406672 Posted at 9-28 06:53
It's obviously a slip of the tongue, due to conflicting wordings.[Image]
There is no confusion possible. For DJI the rules to apply is in the 2019/945 (left side on your screenshot)
2023-9-28
djiuser_AszqW3FCy3iq
Flight distance : 1294626 ft
LV_Forestry Posted at 9-28 07:11
But the rules in 2019/945 are not really precise and contradict the rules in 2019/947.
2023-9-28
greg_p
The right is to apply from 1st Jan 2024. The left is now. Just read all the page (I know how confusing an  EASA page can be).
2023-9-28
LV_Forestry
Latvia
djiuser_AszqW3FCy3iq Posted at 9-28 08:15
945 is the technical part, manufacturer, importer, sellers.
947 this is the part which concerns the operations (use) of the drone by its end user.
So there should be no contradiction.
For example in the 945 the manufacturer is obliged to set a limit of 120m from the take-off point for category C0. ANNEX Part 1 (3)
In 947, ANNEX UAS.OPEN.020 (5) c), category A1 in which C0 drones can operate is described as achievable with a drone that meets the requirements of the point mentioned above.
It is as simple as that.
2023-9-28
Ms Ivy
120m restriction  would effect my flying greatly, because i do fly the mountains and even with ATV's we can only get half up these mountain terrains the drones the only way to reach the tops and explore them ranges without a helicopter.
This new policies is very bad . no more updates for me including my mavic3
2023-9-28
LV_Forestry
Latvia
Ms Ivy Posted at 9-28 09:12
Yes I understand.  But drones other than the Mini series are not impacted if we refer to what the DJI Paladin admin ruled in this thread or another on the same subject.
  So, no worries.
2023-9-28
Sean-bumble-bee
Ms_Ivy, apart from LV_Forestry's point about the drone models concerned, the discussion relates to drone usage in the EU and not USA so there's a second reassurance for you.
2023-9-28
123Next >
