Metric vs imperial
970 7 2022-8-24
fanse0f68750
Flight distance : 239672 ft
Im using a DJI RC Pro with an Air 2S. In the fly app menu you can choose between metric and imperial, and in deed while flying it displays FT and miles, however in the flight logs it reverts to M and KM. It there a way to change this?
Using my mini 2 NC1 and iphone it displays imperial in both the fly app AND the flight logs.
2022-8-24
This seems to be a bug on all android platforms,  on IOS it actually works correctly.
2022-8-24
Hi there. Thank you for reaching out. We will forward this to our designated team for further clarification. We will keep you posted once we have an update. Thank you for your understanding and support.
2022-8-24
DowntownRDB
Flight distance : 1722 ft
I have the same issue with Air 2S and RC Pro controller.  Haven't found a way to change it and chat with DJI Support revealed no way to change it.
2022-8-24
ALichty
Flight distance : 3977520 ft
I am in the same boat with the RC Pro controller linked to a Mavic 3. If I go to the DJI Fly app on my iPhone the uploaded logs show in imperial.
2022-8-24
gulfpre
Flight distance : 2885656 ft
iPhone that flew the Mini 2 shows logs in imperial  - as desired.
The RC controller shows in metric.
iPad, that’s never flown, only syncs into the DJI fly app also shows in metric…
2022-8-24
djiuser_qEDIjdvvHEjR
This is still an issue. Flight logs in meters regardless of settings. While flying it does show in feet. But flight logs are recorded in meters only. Using iPhone interesting because there was a point in time where about a year ago I was able to see in feet
2023-9-27
Burt37
Flight distance : 4009 ft
djiuser_qEDIjdvvHEjR Posted at 9-27 14:52
Depends on which side of the pond you are on... To some is an issue but considering that China does use metric for their evaluations... Well...
2023-9-27
