Really disappointed with this Mini 3
1881 31 2023-9-27
Ph3onix
Flight distance : 2341886 ft
Hello to all of you, it's now been almost 2 months since I took the Mini 3 and I really don't know what to think of it, because not only does it quickly lose the connection (compared to the Mini 2) but what is really the most What's really disturbing is this sharpness problem which is a real nightmare. I also managed to make a decent video (after 2 months).
Edit : A little message for Dji to give you an update not for minor bugs but for major bugs, because this sharpness problem is a major bug.
THANKS.
2023-9-27
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please upload the original (unedited) footage that has the issue using Google Drive and send the link to us so we can check it? We will coordinate this with our relevant team for attention. Please keep us posted. Thank you.
2023-9-27
Ph3onix
DJI Paladin Posted at 9-27 17:47
hi, thank you for your response I'm traveling at the moment so I don't have the original file of this video, but as soon as possible I will make another video so that you can see the excessive sharpness problem of the Mini  3 which when flying over a roof, water, gravel and any other environment of this style the images are simply unusable in the state.  THANKS
2023-9-27
Ph3onix Posted at 9-27 22:58
Sure. Looking forward to your update. Once we get your reply, we will further check with our engineer team. Thanks.
2023-9-28
relaxosmo
Flight distance : 180604 ft
Hungary
DJI Thor: what do you want to check?
ALL Mini 3 videos are oversharpened, which hurt our eyes.
Visible at diagonal lines, patterns, roofs, etc. Moire effect.
Please let us change the sharpness level.
thanks
2023-9-28
Blériot53
Flight distance : 6269839 ft
Maybe I'm not as critical as you, but I'd be quite pleased to have produced such a piece of video.
Even clipping a screen-grab from a scene, and blowing up a detail from it 500%, you can still see that it's a tractor I've copied it for comparison. Blurred at 500% of course. But the original looks fine of my HD screen.
2023-9-28
Ph3onix
Blériot53 Posted at 9-28 09:56
Hi, the result is not bad now but I had to spend a lot of time to get there, because with the reflection of water for example, the video was impossible to use as is.
2023-9-28
Blériot53
Ph3onix Posted at 9-28 10:57
That's a real pity, because what was shown was quite pleasing.
2023-9-28
Ph3onix
Of all the drone videos I have made, these were the most complicated to make in terms of calibration.
2023-9-28
Ph3onix
DJI Thor Posted at 9-28 00:34
hi, I just found a video of the Mini 3 on my smartphone that I made some time ago, it is in portrait mode but in landscape mode the result is the same.
https://drive.google.com/file/d/ ... view?usp=drive_link
2023-9-30
Ph3onix Posted at 9-30 03:28
https://drive.google.com/file/d/1bgadhkrKoGU7tpeC2-a4AgkCTY_sUdbW/view?usp=drive_link
Hi Ph3onix, sorry that we could not access the link. Would you please help to set the permission as public? Thanks.
2023-9-30
Ph3onix
DJI Thor Posted at 9-30 03:56
Sorry I forgot, but it's good now.
2023-9-30
Ph3onix Posted at 9-30 04:00
Thank you and we will forward to our engineer team to further check, thanks.
2023-9-30
Intergames
Flight distance : 348455 ft
Mexico
It is undeniable that sharpness control is necessary, I don't see why they don't implement it... and even worse is that with the last update, many of us have stopped working with quick shoots and panoramic shots, it is worrying that they abandon us so much in terms of to the most important needs and not just minor changes... I guess the mini 4 pro has kept them very busy
2023-10-3
Ph3onix
Intergames Posted at 10-3 22:26
Hi, yes I agree, especially since it is not a whim to add an additional functionality, but to correct a bug implemented from the beginning. Dji no longer follows these drones (at least the cheapest ones) as it followed their products in the past.
For Dji, it's just business to the detriment of customers unfortunately.
2023-10-4
Ph3onix Posted at 10-4 06:47
Hi Ph3onix, thank you for your patience.
For your reported issue, an error might occur in the autofocus feature, resulting from a low write speed or other abnormalities of the SD card. You could please check the current firmware version of the drone and ensure that its firmware is updated to V01.00.0300, which has addressed the issue.
At the same time, please also confirm to use with the recommended SD card, thanks.
2023-10-5
Ph3onix
DJI Thor Posted at 10-5 04:16
Hi, thank you for the feedback but the first thing is that I still use Sandisk exteme A2 V30 so it does not come from a card problem because testing on other drones (Dji I specify) plus I am on the last firmare and the problem and still present.
I don't understand your problem at Dji to admit that some of your drones have problems, but I am not the only one to say it, far from it. Listening to you, it’s always our faults.
“Only he who does nothing doesn’t make a mistake.”
So take into account what your customers tell you.
Damn it.
2023-10-5
Ph3onix Posted at 10-5 04:45
We feel terribly sorry for the unpleasant experience that you came across. It is not our intention in any way to add more frustrations to our customers.
We will collect these voices and feedback to our relevant team to review on it. We will also improvide and provide better products and service in the future. Thank you for your tolerance and understanding!
2023-10-5
I agree, but they never implemented this in the 'entry level' category.
2023-11-24
Ph3onix
Montfrooij Posted at 11-24 12:37
Okay so why sell us a drone with 4k which is practically unusable, in this case they should have limited the Mini 3 to 2.7k but usable as they did with the Mini Se?
The choice would have been simpler for the customers and above all more honest on their part. Because there I have the impression of having been well taken advantage of, in fact I don't even fly with this drone anymore because I don't have I don't want to spend hours and hours editing a three-minute video sequence that cannot be used directly.
2023-11-24
Ph3onix Posted at 11-24 13:05
My first drone was the Mavic Pro.
(bought 2nd hand) and I loved it a lot.
Then came the EU rules and I bought the Mini 2.
Man, was I disappointed with the video quality because of the color profile that they used.
(too much contrast, too much sharpness)
But I decided that 'a' camera in the sky was better than no camera, so I made the best of it.
Now recently I stepped up to the Mini 3 Pro.
What a difference that makes.
Really night and day!
So yeah, it's just what it is.
Most consumers like their footage contrasty and don't care about the loss in quality this brings.
So DJI provides that with the entry level drones.
And to make it worth to upgrade, they only add the option to change this in the pro level drones.
(just like many tech companies do)
So get a Mini 3 Pro and sell the 3 before the 4 (no pro) comes out
The 3 is quite cheap right now, so you might be able to find a good deal.
2023-11-24
Joel King
nice video
2023-11-24
Ph3onix
Montfrooij Posted at 11-24 13:09
It's not a question of colorimetry but of sharpness.
If you can download the video from the link, watch it in 4k and tell me honestly if you would buy a drone that produces an image like that or if you wouldn't be disgusted if you did?
2023-11-24
Ph3onix Posted at 11-24 13:20
The file is not there.
2023-11-24
Ph3onix
2023-11-24
Ph3onix
Sorry
2023-11-24
Alain Basstard
Yeh After owning a mavic  pro the mini 3 is garbage. signal loss after 300mtr and thats with an unobstructed view, rc2 controller cannot connect to wifi or hotspot no way of plugging into computer . you would think  the technology would have improved Only had it for a week and close to throwing it in the bin.
6-7 23:09
Sean-bumble-bee
Flight distance : 15997 ft
I suspect you are wrong on all accounts and that you would be better served by spending  sometime googling the problems that you are encountering.
If you are inclined to bin it I am sure someone would happily take it off your hands rather than waste it.
6-7 23:14
CHARZ
not a real hdr, oversharpened video, noisy 48mp photo mode  - chinese quality
6-8 00:25
Ph3onix
Yes but this time Dji gave us a big ... and what's more they made an update which is useless instead of correcting this sharpness problem which everyone is full of. They're really good for nothing
6-11 11:32
Texas-Mark
Flight distance : 23002 ft
None of the video links work for me.
6-12 10:49
Sean-bumble-bee
Texas-Mark Posted at 6-12 10:49
If you are talking about the google drive links, did you notice the dates on the posts ?
6-12 22:08
