Air 3 Remote ID
10923 22 2023-8-4
noob1957
Hi, I can't seem to find the remote ID for my drone.
I bought the drone in China and are planning to fly it in the US during a holiday, and so I am trying register it. I looked in the about section of settings and can't find remote ID under SN.
Thanks for any and all help.
2023-8-4
Hi there. Thank you for reaching out. Please note that all new drones produced by DJI now include these capabilities or the Remote ID-compliant drone. If you bring a RID-compliant drone to the US from a non-US country, the drone will surely broadcast an FAA Remote ID signal after taking off in the US. You may click the link below for more information about Remote ID. Thank you for your valued support.
https://forum.dji.com/thread-293343-1-1.html
2023-8-5
fans20b63dac
DJI Paladin Posted at 8-5 01:18
Hello, thanks for the reply. I understand that the drone has remote ID capabilities and will broadcast its position after takeoff, but I would like to know where can I find my drone’s remote ID serial number as registering it on FAA’s dronezone requires the remote ID.
2023-8-5
fans20b63dac
fans20b63dac Posted at 8-5 19:09
I’ve actually just found the remote ID serial number is the same as the drone/controller serial number, and it seemed to have worked!
Thanks for the help nontheless
2023-8-5
fans20b63dac Posted at 8-5 20:30
Thank you for your response. You may check this information on the DJI Fly app. Go to DJI Fly app > Settings> About> Remote ID SN. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2023-8-7
KLRSKIR
Flight distance : 28650751 ft
DJI Paladin Posted at 8-7 05:06
"Remote ID" is not listed in the list as it is on other aircraft in the About menu. As stated above, the Aircraft and Flight Controller SN's match and start with "158."
2023-8-7
angeloffate
how do you find what is your RID?
2023-8-7
angeloffate Posted at 8-7 12:54
Hello there. If the drone has a 20-digit alphanumeric serial number (always prefixed with 1581F, also mentioned above by KLRSKIR), the Remote ID serial number is the same as the aircraft serial number. If the drone has a 14-digit alphanumeric serial number, the Remote ID serial number is not the same as the aircraft serial number. You can refer to DJI Paladin's Reply #5 to check the drone's RID. Thank you and have a great day ahead.
2023-8-8
angeloffate
thanks, understood
2023-8-8
KLRSKIR Posted at 8-7 09:21
Thank you for your response. Yes, for an aircraft with a 14-digit SN, Remote ID SN=1581F + 14-digit flight controller SN + 0, and the total number of digits is also 20. Thank you for your valued support.
2023-8-8
You are most welcome. Please don't hesitate to reach us if you have other inquiries. Have a nice day ahead!
2023-8-8
fans33f480c2
I have just purchased DJI Air 3. I live and work in UK but am looking to go on a holiday to USA later this year
I am looking to fly the drone recreationally and hoping to capture some great holiday footage
I have been researching on what I need to do to fly a drone in USA and have succesfully obtained my TRUST certificate and have installed B4U app
I have been trying to register my drone with the FAA and it seems that DJI Air 3 is not listed on the FAA site so I cannot register
Is this correct? Does this mean it is illegal to fly DJI Air 3 in USA?
As soon as I start typing my serial number which begins with 1581F6N8* I get a message which says invalid serial number
Can someone please help
Thank you
Jaymin
2023-8-27
noob1957
fans33f480c2 Posted at 8-27 01:30
Hello, Jaymin
I was in a similar situation as you (just not from the UK), and I got my drone registered by entering the Aircraft SN/Flight Controller SN (in the About menu in the 3 dots menu at the top right in camera view) when prompted to enter the Remote ID number. The SN should be 1581******... if I'm not mistaken.
After that I got my drone registration number and that seems to be it.
Hope this helps
noob1957
2023-8-27
djiuser_KDLvqhQSjHFm
I’m so tired of government overreach on everything, especially for what equates to a toy for guys with a little bit of money. I’m all for safety but is there a way to disable remote id, specifically on the air 3?  I feel like big brother has just gone way too far!  And how do I change my username?  Lol
2023-9-6
djiuser_KDLvqhQSjHFm Posted at 9-6 21:37
Hi there. I understand the inconvenience. According to the Remote ID rule, the Remote ID system cannot be disabled by any person, and once the drone is upgraded to RID-compliant firmware, it cannot be downgraded. You can change your username in your settings under your personal homepage section. I appreciate your patience. Have a great day ahead.
2023-9-7
DJI Tony Posted at 9-7 01:51
Can you avoid upgrading the firmware forever And still be able to use the drone like normal?
2023-9-7
djiuser_KDLvqhQSjHFm Posted at 9-7 07:48
Hi there. It is recommended to update your firmware to the latest to ensure optimal performance and flight safety and also to catch up with the newest features. Thank you for your understanding.
2023-9-7
undersky
Flight distance : 3727 ft
same problem but bought it in USA. can't find remote id.
2023-10-3
djiuser_sq8iz61KIkBl
Flight distance : 39921 ft
undersky Posted at 10-3 14:15
in the battery compartment there is a 20-digit S/N which is your remote ID as well
2023-10-3
Hello there. If your drone has a 20-digit alphanumeric serial number (always prefixed with 1581F) the Remote ID serial number is the same as the aircraft serial number, and generally the same as the flight controller serial number. Have a great day.
2023-10-7
JodyB
Flight distance : 322005 ft
As DJI Tony stated, the RID number you are looking for is the aircraft serial number. It isn't listed as RID in the settings of the DJI Fly software, just the aircraft serial number. Thats how I got mine registered on the faa dronezone website. And if you fly in the US and I'm sure it's like this in other countries with their air authorities, a drone equipped with standard remote ID can not be turned off as this is mandated by the FAA regulations.
2023-10-7
djiuser_aAPIhYgPeeHf
Flight distance : 345118 ft
DJI Paladin Posted at 2023-8-7 05:06
Hola buenas tardes he estado buscando la manera de activar mi remoto ID y no he podido ya q mi drone dji air 3 no tiene la opción en el control remoto de UAS remote identification q puedo hacer.
5-3 10:53
djiuser_aAPIhYgPeeHf Posted at 5-3 10:53
Hi there. We're deeply sorry for the trouble. Please make sure to update the latest firmware of both aircraft and remote controller via DJI Assistant 2 software. After that, if you are using a controller with a mobile device, please make sure to update the DJI Fly app to the latest version and check whether the issue persists. Please keep us posted.
5-6 01:27
