Total height Action 3 with magnetic mount
599 7 2023-10-4
Borre_DJI
I a looking for a action cam to put below my viser.
Something like the positions on image below.
Need the cam including the mount to be as smal as posible, so the cam does not block the view.
I notice the dji action 3 has a height of 44mm (gopro 11 is 55mm)
but the dji needs the magnetic mount, I can find sizes of the mount combined with the action 3
some owners that can measure it for me?
best way would be top of the dji to center of bolt hole.
2023-10-4
lutzmix
I think it is 70mm
2023-10-4
osmonauta
Hungary
About 75.8mm from top of camera to the very bottom edge of the mount.
About 68.8mm from the top of camera to the center of the mounting hole.
2023-10-4
Hi there.Thank you for showing interest in our product. The total dimension of the DJI Osmo Action 3 with the magnetic mount attached is 8.4x5.5x3.6cm. Kindly please note that there are some errors with manual measurement. Have a nice day ahead.
2023-10-5
Borre_DJI
Great, thanks for the answers.
this helps a lot.
2023-10-5
osmonauta
Hungary
@DJI Paladin: "The total dimension of the DJI Osmo Action 3 with the magnetic mount attached is 8.4 x 5.5 x 3.6cm."
In China the gravity is stronger so the camera can be 8mm longer there...
2023-10-5
Borre_DJI
osmonauta Posted at 10-5 04:53
Maybe china measure it with the protective case around it.
osmonauta thanks for the picture
2023-10-5
osmonauta
Hungary
In that case they should say "the camera dimensions with the magnetic mount and the protective case are XYZ". But he didn't say that.
2023-10-5
