Charger
547 10 2023-10-8
adisaputra
Flight distance : 1274583 ft
Indonesia
Dear guys,
Can the DJI Air 2S charger be used to charge a cellphone?
Thank you
2023-10-8
dreamtuner
Flight distance : 2068376 ft
Bangladesh
Which cellphone model on earth has the same charging connection point as an Air 2S charger?
2023-10-8
adisaputra
Indonesia
dreamtuner Posted at 10-8 22:48
I mean, use type C cable for remote charging will be used for cellphone.
2023-10-8
FabioV
Flight distance : 980066 ft
adisaputra Posted at 10-8 22:55
Why not ? I'm always charging the remote using the iPad USB-C charger, then I assume you can charge an USB-C phone with the DJI charger. Depending on phone's specifications, maybe the charging speed could be lower than expected.
2023-10-9
Shawgod
Flight distance : 5173104 ft
I can't see why it can't.  I know you can charge off the batteries.  The phone should charge as normal.
2023-10-9
adisaputra
Indonesia
FabioV Posted at 10-9 05:01
Thank you very much
2023-10-9
adisaputra
Indonesia
Shawgod Posted at 10-9 06:21
Yes, thank you
2023-10-9
Hello there. DJI drones normally can be used with USB-C type of interfaces such as those for Android phones. As also mentioned by FabioV, charging using DJI provided charger may work depending on your phone's required specifications. Have a nice day.
2023-10-9
adisaputra
Indonesia
DJI Tony Posted at 10-9 22:34
Thank you very much
2023-10-9
You are most welcome, adisaputra. Please reach back if you have further concerns. Have a great day ahead.
2023-10-9
dreamtuner
Bangladesh
Oh, I see. Sure you can use it for your phone.
2023-10-10
