DJI Go4 and Android 14?
123Next >
26882 104 2023-10-6
papa_uwe
Flight distance : 1395984 ft
Hi there,
I updated my Google Pixel 7a to Android 14 these days and now tried to start DJI Go4 again to fly my Mavic Air. But it keeps crashing immediately, the splash screen does not even show up. I also tried deleting the cahce, restarting the phone, stopping all apps on the phone, I even de-installed Go4, booted the phone and re-installed the APK from the DJI server, but no change.
The combination of Go4 and Android 13 worked quite well before.
Are there any plans to support DJI GO4 on Android 14 soon?
Or does anyone have a workaround to get it started?
Any help appreciated!
2023-10-6
Hi, papa_uwe. Thank you for reaching out. Please try the steps below:
(1) Please clear the mobile phone cache and ensure that the mobile phone has enough storage available (10G or more is recommended). Hard restart the mobile phone.
(2) Check the App version, if the app is not the latest version, then it is recommended to update the app to the latest version.
(3) Download from the official website.
If the issue persists, please provide the following information for us to further check:
(1) App version, aircraft model, and relative firmware version.
(2) The mobile device model and system version.
(3)What is the operation that caused the crash? Please provide an abnormal screen recording.
(4) Provide the time when the crash occurred (to locate the log).
(5) Exported crash log.
(6) Please export the bug report.
DJI GO 4’s crash log position: Local folder/DJI/dji.go.v4/LOG/CRASH
How to export the Bug Report from Android devices?
Note: The path may be slightly different for different device models, the main path is around this: mobile phone system settings-system/about-developer options-bug report.
2023-10-6
papa_uwe
DJI Gamora Posted at 10-6 19:40
The App ist DJI-v4.3.54_221028-1164-36655_official_sec.apk. This should be the latest available version as of now.
M phone is a Google Pixel 7a with Android 14, UP1A.231005.007.
I did deinstall, reboot, install several times, no effect. I also renamed the existing DJI folder (from the previous Android 13 version) to get it out of the way - no change.
I also added all necessary permissions to the Go4 app, no effect.
Unfortunately the app is not even able to create the DJI folder, so I don't have a CRASH folder.
Looks like the App does not start at all.
2023-10-6
fanse2fce227
Flight distance : 693596 ft
papa_uwe Posted at 10-6 21:45
Same problem here, Pixel 7, android 14 :/
2023-10-6
djiuser_8NpLo4hlecHe
Same with my pixel 7 on Android 14. Very unsatisfied as every time a new android version comes out
2023-10-7
Thank you for the reply, papa_uwe. Can you please provide us with a screen recording showing the issue as well as the bug report if there is one? Thank you.
2023-10-7
fanse2fce227 Posted at 10-6 22:21
Hi, fanse2fce227. Thank you for joining the thread and we're sorry to read that you're having the same issue. Please follow the steps provided in this post.
2023-10-7
djiuser_8NpLo4hlecHe Posted at 10-7 00:12
Hi, djiuser_8NpLo4hlecHe. Thank you for joining the thread and we're sorry to read that you're having the same issue. Please follow the steps provided in this post.
2023-10-7
DJI Gamora Posted at 10-7 01:34
I already did without success
2023-10-7
djiuser_uJLywi2ifYqG
Seychelles
Same issue with pixel 6 pro. Was already a nightmare to get it working on Android 13 as the newest release has been broken and only an older one worked...
2023-10-7
Do I understand you correctly. Older version of go4 is working with android 14 und Pixel 6? If so, where can I get the older version?
2023-10-7
papa_uwe
DJI Gamora Posted at 10-7 01:33
Sorry, no crash or error report.
I am using a Magic Air (1) by the way. But the issue appears even before connecting the aircraft. So it is independent of the drone.
I recorded a video, starting from the installation, starting the app several times and then showing the file explorer: the app did not even create the DJI directory.
By the way: Great that DJI still cares about this issue, thanks for that! I'm a professional software developer and I know what it means to maintain software which is older than 7 years!
2023-10-7
djiuser_KNslNPXz3JZg
Pixel 7 , Android 14 crashes the app, won't even open
2023-10-10
horztisgreat34
djiuser_KNslNPXz3JZg Posted at 10-10 19:02
Same here: Pixel 7, app crashes on startup
2023-10-10
papa_uwe
@DJI Gamora: Did you find the time to review my video? (See my previous post.) Since other users report the exact same issue, I am sure it is easy for you to reproduce it on any Android 14 phone. So, can you please report any status or even progress?
2023-10-11
djiuser_RHgn8EZ3zRlZ
I have just updated my phone to android 14
The app dji go4 crashes ad startup.software.
Please fix.
I did try al the options in the post.
Greetings Frank
2023-10-12
fansfc771078
Same issue, Pixel 6a and Android 14. App crashes on launch, no logs.
-- DJI Go 4, version 4.3.54
- Android 14
2023-10-12
Peter_
Same problem here, Google Pixel 7, android 14, instant crash
2023-10-13
papa_uwe
DJI Gamora Posted at 10-7 01:36
Hi, we provided all requested information and the thread gains a lot of attention. Could you please post some status update here?
2023-10-13
Nicolò8
Pixel 6a with Android 14, same issues as everyone else... App keep crashing at launch
2023-10-14
Bobbydrone
Exactly the same problem as all those above - instantly crashes when started. No logs can be found.
Mavic Air 1 running latest official app version on Pixel 7 Pro on Android 14.
It was running fine few weeks ago (before upgrading to Android 14).
This should be easy to reproduce given the prevalence of the reports from those that upgraded.
Can you please provide an update?
2023-10-14
BogBeast
Same with me. Pixel 7 pro worked fine on Android 13 and now does not work after 14 update.
Also installed on my new pixel 8 pro and same issue.
Latest APK installed from DJI site
2023-10-14
djiuser_QZ9Ys44Bi8IY
Same. Pixel 6a android 14 latest APK from site. Please help. Need for work!
2023-10-15
Fredisco
Flight distance : 71043 ft
Same here doesn't work, constant crashes at launch, cleared, reinstalled nothing helps. Pixel6 (I did have the transmission issues with Android 13 so in theory it didn't work before either). I will probably never purchase a DJI Product again, this is silly.
2023-10-16
djiuser_6SFT67uRjZme
Same here on Pixel 8 Pro, Android 14. App crashes instantly, no log available.
logcat logs the following output when trying to launch the app.
2023-10-17 18:25:40.291 15893-15893 dji.go.v4               pid-15893                            W  Accessing hidden field Landroid/view/LayoutInflater;->mContextandroid/content/Context; (max-target-p, JNI, denied)
2023-10-17 18:25:40.296  1727-7987  ActivityManager         pid-1727                             I  Flag disabled. Ignoring finishAttachApplication from uid: 10453. pid: 15893
2023-10-17 18:25:40.300 15893-15924 vulkan                  pid-15893                            D  searching for layers in '/data/app/~~zcj7L0-DuqF-FY5QJcqDrg==/dji.go.v4-PdUlz-Y0yxXJc4WBLGWXcA==/lib/arm64'
2023-10-17 18:25:40.301 15893-15924 vulkan                  pid-15893                            D  searching for layers in '/data/app/~~zcj7L0-DuqF-FY5QJcqDrg==/dji.go.v4-PdUlz-Y0yxXJc4WBLGWXcA==/base.apk!/lib/arm64-v8a'
2023-10-17 18:25:40.345 15893-15893 AndroidRuntime          pid-15893                            D  Shutting down VM
2023-10-17 18:25:40.345 15893-15893 AndroidRuntime          pid-15893                            E  FATAL EXCEPTION: main
        Process: dji.go.v4, PID: 15893
        android.util.SuperNotCalledException: Activity {dji.go.v4/dji.pilot.main.activity.DJILauncherActivity} did not call through to super.onCreate()
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3768)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3922)
        at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:103)
        at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:139)
        at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:96)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2443)
        at android.os.Handler.dispatchMessage(Handler.java:106)
        at android.os.Looper.loopOnce(Looper.java:205)
        at android.os.Looper.loop(Looper.java:294)
        at android.app.ActivityThread.main(ActivityThread.java:8177)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:552)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:971)
2023-10-17 18:25:40.346  1727-15951 DropBoxManagerService   pid-1727                             I  add tag=data_app_crash isTagEnabled=true flags=0x2
2023-10-17 18:25:40.347  1727-7987  ActivityTaskManager     pid-1727                             W    Force finishing activity dji.go.v4/dji.pilot.main.activity.DJILauncherActivity
2023-10-17 18:25:40.347  5272-5328  WindowManagerShell      pid-5272                             V  Transition requested: android.os.BinderProxy@ccdccd7 TransitionRequestInfo { type = CLOSE, triggerTask = null, remoteTransition = null, displayChange = null }
2023-10-17 18:25:40.349  1727-1812  ActivityManager         pid-1727                             I  Showing crash dialog for package dji.go.v4 u0
Android Developer Previews are available quite early. It's a shame that a company as big as DJI does not run those basic checks on their apps: Even if it's not longer the newest product.
2023-10-17
djiuser_iGnjdX1FAHr8
Cambodia
Same Problem on My Pixel 6 Pro
2023-10-17
Subtext43312
Same problem with Pixel 7 after Android 14 update. App fails to load.
2023-10-18
Can_I_Fly
Flight distance : 669 ft
Same issue as most of the above posts.
Pixel 7 pro... on Android 13 it seemed to work ok but after the Android 14 update, the app will not even open, just crashes immediately.
A bit of a let down as I learned of this issue while on site trying to capture the roofing of a future project.
Hope this is fixed or at least a work around is found, *fingers crossed*
2023-10-19
papa_uwe Posted at 10-7 04:57
Hi, papa_uwe. Thank you for the It has been confirmed that your mobile device is not currently compatible. It can be preliminarily determined that the issue is caused by a compatibility error. Since there are many device models awaiting testing, this issue cannot be resolved in the short term. If you have an urgent flight mission, it is recommended that you use the app with one of the supported mobile device models listed on the DJI official website to avoid a flight mission failure. We apologize for the inconvenience. Thank you for your understanding and support.
2023-10-19
Perezq
Colombia
Pixel 6a. Same issues.
2023-10-21
fans66b7b2b1
S23 ultra with the same issue running android 14. Embarrassing to have an expensive paperweight due to lack of software updates
2023-10-21
fans66b7b2b1 Posted at 10-21 13:26
Hi there. It has been confirmed that your mobile device Samsung S23 Ultra is currently not compatible with the DJI Go 4 app. Since there are many device models awaiting testing, this issue cannot be resolved in the short term. If you have an urgent flight mission, it is recommended that you use the app with one of the supported mobile device models listed on the DJI official website in order to avoid a flight mission failure. We apologize for the inconvenience. Thank you for your understanding and support.
2023-10-23
BogBeast
DJI Paladin Posted at 10-23 01:54
Any update on when a working version of Go 4 will be available?
2023-10-23
djiuser_f8Cv28d5LRX5
Using a pixel 6 on android 14, DJI go 4 will not even open, this is incredibly frustrating to have to mess around SO much every time an app is updated, definitely will never buy a drone again. Please fix this issue
2023-10-23
djiuser_VrB9Mq5oopn0
Pixel 7 Android 14. DJI Go 4 not working. Very annoying  Hopefully DJI will provide an update soon.
2023-10-24
BogBeast Posted at 10-23 13:39
Hello, BogBeast. Can you please confirm what mobile device are you using with the DJI Go 4 app? Please let us know so we can provide you an accurate resolution. Thank you.
2023-10-25
rainerT
Flight distance : 1463 ft
I can confirm this. DJI GO 4 crashes immediately after starting the app. There is no error log. The DJI Logo appears for half a second, than it's over. I also would like to know when DJI GO 4 ist ready for Android 14. It worked fine with Android 13.
2023-10-26
RodrigueElHajj
Flight distance : 17264 ft
Same issue here pixel5 android 14, djigo4 not working. Doesn't even open just crashes
2023-10-26
gogokehayov
Bulgaria
DJI Gamora Posted at 10-19 16:49
This is ridiculous! I have Mavic2Pro -this is not a cheap dron, you take the money and after that not provide any support.
2023-10-26
SP8RHR
I confirm that after updating the system to Android 14, DJI Go4 stopped working.
The application does not start.
My phone is -> google pixel 6a
2023-10-27
123Next >
