Hi there. Thank you for reaching out. Setting a larger value in the parameter will result in a better performance in sharpness or noise reduction. For instance, you may need to increase the iSO value for exposure in the night shooting environment. Since the higher iSO setting amplifies the amount of noise in the image, you can set a larger value in noise reduction parameter in order to reduce the noise levels. A higher value of sharpness increases the contrast between edge pixels, giving a clearer appearance of the image. Hope this helps. Thank you for your valued support. |
