Help! DJI go app for zenfone 2
8727 18 2016-1-10
slavilanda
Israel
Hi I try to run the application with my new Asus Zenfone 2 unsuccessfully.(ran with android 5.0 Latest Version)
The app indicates normal but I can not get the camera view.
It's a bummer because I can not fly the Phantom
Please help if you have any solutions for me?
2016-1-10
DJI-Ken
Flight distance : 1515312 ft
Have you tried another device, it's probably because your device does not have the processing power to run the app.
Here are the approved devices. And you can fly the Phantom just fine without the app, you just don't get the video and features of the app.
If you cannot fly at all then read in the manual on how to relink the aircraft to your RC.
iOS Version v2.4.3. Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, and iPhone 6 Plus.
Android Version v2.5.0. Requires Android 4.1.2 or later. Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
2016-1-10
slavilanda
Israel
ok,
so i corrected the problem by upgrade the rc to 1.3 version and it work after this. later i upgrade to new version from go app by using the phone.
it all work for now, but i have a small bag when i go to map view it very likely that i lose picture vibw it will be black
asus zenfone 2 with 4 ram and 2.3 ghz  it will be shame if it will not work
2016-1-12
DJI-Ken
slavilanda Posted at 2016-1-12 19:07
ok,
so i corrected the problem by upgrade the rc to 1.3 version and it work after this. later i upg ...
Take a screenshot, I don't know what you mean by "small bag"
2016-1-12
rodolfovaz
DJI-Ken Posted at 2016-1-13 01:06
Hi there, Slavilanda.
I had the same problem with my Phantom 3 Standard and Asus Zenfone 2. It seems to be related to hardware issues, as Zenfone 2 is not listed as a "compatible device" at DJI website.
I tried the same Phantom 3 Standard linked to my other mobile, a Samsung Galaxy S5, and everything ran smoothly (S5 is listed as a "compatible device" at DJI website).
Another user had the same problem and posted a video on Youtube at It´s the same problem you report.
DJI-Ken, you can watch the video to check the problem Slavilanda reported.
I hope they´ll fix this for Zenfone 2, as the screen is bigger...
Cheers.
2016-2-12
DJI-Ken
rodolfovaz Posted at 2016-2-13 02:25
I had the same problem with my Phantom 3 Standard and Asus Zenfone 2. It seem ...
Ok, I think they may have meant "small LAG" and I see in your video that the app is not working with your device. You really need a different device, yours does not have the processing power to make the app work correctly.
You can try to turn off all background running apps, use airplane mode, lower the transmission quality in Video transmission setting of the app.
BUT, overall you need a device from the list I posted earlier.
An inexpensive device that works well and not on the list is the NVIDIA Shield K and that is $200 and it has a GPS/GLONASS so you can use Follow Me.
2016-2-12
rodolfovaz
DJI-Ken Posted at 2016-2-13 02:40
Ok, I think they may have meant "small LAG" and I see in your video that the app is not working wit ...
Thanks, DJI-Ken. I solved my problem flying with Galaxy S5 (my other mobile). I also have an iPad Mini, but it doesn´t have GPS, so I use it only when I´m sure I´m not going to fly under F-mode (and it´s a bit hard to use, because the mobile holder doesn´t fit it).
2016-2-12
DJI-Ken
rodolfovaz Posted at 2016-2-12 12:03
Thanks, DJI-Ken. I solved my problem flying with Galaxy S5 (my other mobile). I also have an iPad  ...
Sounds good, glad you figured out a solution. There are aftermarket tablet holders out there that may work for you.
2016-2-12
Rodolfo Vaz
DJI-Ken Posted at 2016-2-13 04:33
Sounds good, glad you figured out a solution. There are aftermarket tablet holders out there that  ...
I just got a tablet holder to use iPad Mini with P3 Standard.
Moving the subject a little bit, is it possible to use Samsung VR SM R322 with P3 Standard in any way? Have you heard anyone coming up with this configuration?
2016-2-17
Rodolfo Vaz
Rodolfo Vaz Posted at 2016-2-17 17:41
Moving the subject a little bit, is  ...
By the way, is there any goggle that works "right out of the box" with P3 Standard? Like Fatshark or any other brand?
2016-2-17
DJI-Ken
You should be able to use those goggles because all they do is use the phone and put it in the goggles.
Since you have the Standard, there's no cable connection so it may work.
2016-2-17
DJI-Ken
Rodolfo Vaz Posted at 2016-2-17 17:53
By the way, is there any goggle that works "right out of the box" with P3 Standard? Like Fatshark  ...
No, you would need a Pro or Advanced and get the HDMI module then use a goggle that accepts HDMI.
2016-2-17
JUAN MARTIN
Portugal
Help! DJI go app for zenfone 2 no conection
I NEED HELP ABOUT THE CONTROLS CONECTION AND THE PHONES
i Buy a Brand New Mavic Pro <- Such a NICE toy (y)
and also i have a BLU Advance 4.0L phone <- chip brand 50 dollars with Android 4.4.2 this is the link with the info about it->http://www.smart-gsm.com/moviles/blu-advance-40-l
It Works but SLOW.... VERY SLOW... i can see the camera with a TON of lag and use the touch screen... but not Safe for fLy... TO LAG
So i get a brand new ASUS ZenFone2 --> http://www.smart-gsm.com/moviles/asus-zenfone-2 with Android 5.0 lollipop 4 ram and 2.3 ghz and i CANT connect it to the DJI GO App or any conection with the camera
And i don´t use Watsup or Facebok or any other  APP in the Phone... JUST the DJI GO APp..... because im just buy it yesterday night
SO?... What can i do.... ???? it MUTCH MORE power than the BLU shit phone and it doesn't work. how is this possible???
2016-11-21
JUAN MARTIN Posted at 2016-11-21 20:24
i Buy a Brand New Mavic Pro  http://www.sma ...
It has all been explained above, your phones are not powerful enough to do the job. Select a device from the approvedl list.
2016-11-21
larez2
I realize this is an older post but wanted to add some current information about using this device. I have a Zenfone 2 running on android 6.0.1 and it works fine. I've had several flights with it, no problems. No issues switching between map and camera modes like in the video in rodolfovaz's post below.
There is a slight lag with the video, but it's otherwise smooth and not bad when compared to my newer iphone or older galaxy handsets.
P3S
Asus Zenfone 2, 4gb RAM 16gb ROM, Android 6.0.1
DJI GO v.3.1.5
2017-5-11
Hijitus
Argentina
hola tengo el mismo problema pero con un mavic air, zenfone 2, no funciona. Pudiste arreglar el problema? / hello I have the same problem but with a mavic air, zenfone 2, it does not work. Could you fix the problem?
2018-3-22
Hijitus
Argentina
2018-3-22
Hijitus
Argentina
larez2 Posted at 2017-5-11 11:01
hola entonces funciona con el zenfone 2? como cambiaste a android 6? hello then it works with zenfone 2? how did you change to android 6?
2018-3-22
Muffato
Flight distance : 286506 ft
Hijitus Posted at 2018-3-22 15:47
My Zenfone 2 Worked with my Phantom 3 Standard and Mavic Pro but it´s not working with Mavic Air
2018-4-12
