anaka
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
DJI Susan Posted at 3-18 22:52
Hi there, there is an update on your issue. There is a bit of information.
1. Regarding the customized vibration-absorbing head and arm:
1) Please help to confirm the design payload of them;
as you can see my setup is well minded and developed, i don't have to compare with any other product on the market, i have my porevious gimbal results that proof whay i say, the rs3 pro needs more work on the firmware and add more settings to tweak in the app
i'll give a try to your suggested settings on the app, this had to be one of the fiorst answers from you but i keep discussing here about my setup, you are really stressimg me with this story, i gave you all the proofs you want but you keep telling me that my problem is in my setup or bicicle, they work fine, they are well balanced and they did a good job before of rs3
now about the alexmos, it is heavier, bigger, i was loading more weight on it than now on rs3 pro, it was linked to the arm with the same logic, the arm has springs and idraulic absorber on all the axis, nothing has more range of improvement, the bicicle is full springed front and back with air absrobers set to the smoother level possible, the tires are fat 4.4 inches set to the softer pressure prossible, all is well done, there are no super shakes coming from bike or arm
you saw my latest video, the gimbal has poor stabilization even on the asphalt!!! you have to watch the video in 4k on a big screen or you could beleave that on asphalt it works fine, but it's not, i feel that you are not considering me seriously, on the asphalt i have poor results anyway, more stable than on dirty road but shaky anyway
in the small video in the corner you can see how one of the absorption layers work, please consider that the camera for this little video was linked to the bicicle without absorption so you see how much my system is working, it does the job well, but small shakes happens anyway on the gimbal side
the reason for this could be the firmware that is meant to work mainly in handheld in portait mode and not in underslung mode
another cause could be that this gimbal is not well tested in underslung mode in a shaky situation on a spring arm, few people online use it in undeslung on a car with other spring arms on clean asphalt so super perfect conditions but this is just a very rare condition, usually there are shaky grounds to afford, if my old gimbal is more stable this one have to do the same, i biult my gimbal in YEAR 2015!!!
basing on my long experience with gimbals the cause is software not hardware, i can keep try testing rs3 with different settings but i need more focus from you in that direction instead of on my spring arm or bicicle or setup or whatelse you want to invent next time
