Osmo Pocket 3 Overheating
10280 44 2023-11-6
SteveMavZoom
Flight distance : 331473 ft
Just tried hyperlapse on my pocket 3, spare battery connected on the tripod, it recorded 2 minutes of playable video whatever that is in minutes recorded, it overheated and turned off. Anyone else had that problem? Got on to DJI support chat, they said factory reset which i have, just trying another one to see what happens
2023-11-6
fansfe82067d
Ah.  Yet another overheating thread.  Have a look at the existing ones (though off the top of my head they don't mention hyperlapse).  The key piece of information required is whether this is a camera in the EU, or elsewhere.  EU cameraa are required to stop working at lower temperatures than elsewhere in the world.   In the previous threads there is information about choice of memory cards, and also some pointers to one or two other things you could try to minimise this problem (if you are in the EU).  Broadly speaking you problem is likely to be either that you are encountering the EU temperature limit and there's nothing actually wrong with the camera, or that the camera is defective and should be replaced.
2023-11-6
DJI Diana
Flight distance : 2408 ft
Hello, there. We're sorry for the inconvenience that it may have caused you. May we confirm the firmware version of the DJI Pocket 3? Also, would you be able to tell the camera parameters that were used during Hyperlapse? I hope to hear from you soon.
2023-11-6
Yanncd FrenchStreetMedic
fansfe82067d Posted at 11-6 07:09
I would agree with you IF we had this information about temperature limit by region.
I already post to DJI many photos taken with my thermal camera. It stops at around 53c°Location : France.
What are the limits ? Can we be informed about them ?
Does DJI even knows them ?
I doubt.
2023-11-6
fansfe82067d
The problem may partly be that the camera has so many operating modes and colour modes and tracking modes etc etc that a comprehensive overheating chart might be a rather large document.  I confess that when I started a thread asking DJI to provide comprehensive information, I had not fully realised the complexity of the camera and the resulting large number of potential heat-affecting settings.
2023-11-7
SteveMavZoom
fansfe82067d Posted at 11-7 04:16
I spoke to DJI Support on the app, told me to reset the camera so I took the SD card out reset to factory settings on the camera and did a very very long time lapse this morning and it worked okay so maybe just a glitch
2023-11-7
Hi there, sorry for the issue that happened. Regarding the overheating issue, kindly refer to the information below:
1. It is essential to ensure that the heat dissipation area (gimbal) is not obstructed and that there is enough ventilation space. Additionally, please exercise caution to avoid touching the gimbal.
2. Before starting recording, make sure the device is not in a high-temperature state due to accidental power-on.
3. When a "Device overheated. Recording stopped " message appears, promptly place the device in a well-ventilated area. Allow sufficient time for the temperature to decrease naturally before attempting to capture again.
4. When using the device in Europe, it might experience shorter recording time because of the potential overheating issues:
Osmo Pocket 3 is designed to automatically update its country code based on the current location. Different country codes correspond to specific temperature control strategies to meet local requirements.
It is good to hear that the overheating issue did not exist in your latest recording, if it happens again, kindly refer to the information above. Thank you for your attention.
2023-11-7
Japan Potato
DJI Susan Posted at 11-7 05:18
Thanks for the clarification. Regarding 4)
How can we change the country code? Do we need to set the MIMO app and our DJI Profile to another country or do we need to change the whole phone to another country (and disable location services)? Both things are easy. And how can we check what country code the camera is currently using? Thanks in advance.
2023-11-7
Aavis
Flight distance : 328 ft
Finland
4. Except since it is sold as video camera it cannot overheat in normal video modes in any EU Country when temperature requirements are met.
Other vice you violate the Consumer Protection Law of EU.
2023-11-7
Japan Potato Posted at 11-7 06:57
Hi there, I am deeply sorry for the belated reply, the Osmo Pocket 3 will adapt itself according to the current country/region when it is connected to the DJI Mimo app and internet. We may not suggest changing the country code manually, thank you for your understanding.
2023-11-9
IftiBashir
DJI Susan Posted at 11-9 22:55
Although you may not suggest changing the country code manually, there are some of us who may wish to do so on our own devices that we have paid for and are now our property - so please elaborate and advise?
Thank you
2023-11-10
Jonatan.N
Flight distance : 170627 ft
hacking method on youtube
2023-11-10
SteveMavZoom
I factory reset the camera as suggested by DJI next day left it on Hyperlapse for nearly half an hour and it was OK no overheating so its ok now.
2023-11-10
Hi there, I received an update from our engineers, they will release a firmware soon to optimize the issue, please wait for the update. Thank you for your patience.
2023-11-11
Rishio
Taiwan
By the way guys, I set my screen to auto turn off after 10 minutes, so I get more battery live when recording interviews and less chance of over heating since interviews can run for about an hour.
2023-11-11
jean Claude Bigaut
DJI Susan Posted at 11-11 01:30
Bonjour,
Sur le point d'acquérir la poche 3 ; ce problème de surchauffe m'inquiète car je capte parfois des pièces de théâtre ou danse et je ne peux arrêter la caméra. Ce problème semble se produire à 50I/S or je travaille en 4K à 25 I/S qu'n est il à ce régime ? merci
2023-11-11
hehe2
jean Claude Bigaut Posted at 11-11 09:28
Bonjour,
Jean-Claude, you should speak English there
Je vais te répondre en français, en gros le problème de surchauffe survient dans toutes les résolutions et à tous les framerates mais si tu peux tenir à peu près 1h en 1080p@60, tu tiendras 15 minutes en 4k@60 et probablement moins de 30 minutes en 4k@25.
Heureusement, tu as une solution consistant à créer un petit fichier à la racine de ta carte SD qui va appliquer les paramètres internationaux concernant la surchauffe et pas ceux plus limités qui sont appliqués aux européens.
La méthode est simple et décrite dans la vidéo ci-dessus ou dans les autres sujets "overheating".
J'ai moi-même écrit un petit "tuto" pour décrire une façon hyper simple de créer ce petit fichier soi-même.
Enjoy.
2023-11-11
dfenton
Dear DJI, so if I am in a non-EU country and I purchase, activate my Pocket 3, and install the latest firmware in my non-EU country, and then I go to a EU country for a trip, should I make sure not to update the firmware until I return to my non-EU country? Otherwise, I may loose my non-EU settings?
2023-11-12
OviOptiK
Flight distance : 828323 ft
Romania
Hi! I have Pocket 3 Combo Creator in Europe, and at 4k 60fps, it stops (due to overheating) duup 8, maximum 12 minutes. It doesn't seem normal to me at all! Too little, with all the EU legislation. Very little!!!
2023-11-12
OviOptiK
Romania
2023-11-12
OviOptiK
Romania
Jonatan.N Posted at 11-10 03:53
https://www.youtube.com/watch?v=jHbmaTxaKoA
This method did not work for me. after 22 minutes it stopped...
2023-11-12
IftiBashir
OviOptiK Posted at 11-12 13:39
Something wrong with your unit - contact DJI or have it replaced if you can! You should get more then double that easily.
2023-11-13
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
China
Hi, SteveMavZoom please upgrade v01.01.08.70 firmware. We optimized this issue, espcially with battery handle plugged.
2023-11-13
brusa69
Flight distance : 3362251 ft
Thank You, installing
2023-11-13
Aavis
Finland
DJI-ytao Posted at 11-13 06:41
What v01.01.08.70 does differently than earlier version? What tests did you performed within this firmware and what was the effect? Especially for EU customers.
2023-11-13
Hallmark007
Flight distance : 11959747 ft
Aavis Posted at 11-13 08:06
It’s a bug fix, i have just started recording 4k60fps am at 28 minutes indoors on a tripod with battery handle and no problem so far. Hopefully this will help extend 4k 60fps recording . It’s was very quick to come which shows that dji are taking the matter seriously .
2023-11-13
dfenton
DJI, I agree with this question. What's the difference you observed in the behavior after the new update versus the previous version. Please provide specific durations with the settings used and don't just say something vague like "extended recording time".
2023-11-13
Aavis
Finland
dfenton Posted at 11-13 11:24
They might be able to limit CPU Mhz power to lower heating when standstill has been detected. Just like phones and computers are using variable CPU speeds. This method comes to mind and ofc optimizing software to eat less calculations.
2023-11-13
Hi there, I am deeply sorry for the belated reply. The new firmware optimizes the issue, could you please try to update the firmware and test it again to see if it is the same result? Look forward to your reply.
2023-11-14
OviOptiK
Romania
DJI Susan Posted at 11-14 22:34
It seems that the ultium firmware update for Pocket 3 solved the heating problem for devices sold in Europe. I filmed 54 minutes of 4k 60fps D-log and I still had 10% battery and it was still filming. Respect, DJI!
2023-11-14
Rishio Posted at 11-11 07:09
How do you know it is still recording?
I'm used to checking my Pocket 2 regularly to see if it is still recording.
(other than the gimbal hanging down because of it shutdown)
2023-11-17
OviOptiK Posted at 11-14 23:30
That is good to hear!
2023-11-17
OviOptiK Posted at 11-12 23:15
Did you do the latest FW upgrade? (sorry if I missed it)
2023-11-17
Hallmark007
Montfrooij Posted at 11-17 02:14
It’s all sorted now, the poster also mentioned his problem on another thread.
2023-11-17
Hallmark007 Posted at 11-17 04:04
Good to hear. I'm saving for a P3
2023-11-17
Hallmark007
Montfrooij Posted at 11-17 04:24
It’s really good, a real upgrade from 1 and 2 , a bit heavier but very sturdy an strong. Hopefully it will continue to get improvements by firmware.
2023-11-17
OviOptiK
Romania
After the last firmware upgrade it is ok now. It no longer heats up and films until the battery runs out
2023-11-17
Hallmark007 Posted at 11-17 05:25
Nice.
It's just the price that I did not like too much
But I will just have to save longer.
2023-11-17
OviOptiK Posted at 11-17 08:30
That is good to hear. Thanks for confirming!
2023-11-17
jean Claude Bigaut
hehe2 Posted at 11-11 11:10
Merci beaucoup et je réponds tardivement, il semble que depuis la situation a évoluée dans le bons sens, désolé, je n'ai pas trouvé le tuto dont tu parles concernant le fichier ou plusieurs ? à la racine de la carte
Merci
2023-11-20
