Ronin 4D Joystick control
725 3 2023-11-8
Chris Davies
Flight distance : 15669462 ft
Is there any way to control settings for the joystick like on a tradtional RC.
When doing gimbal control on RS3 or Inspire 3 we can change the speed and the smoothness, I can't find these settings in the Ronin 4D, do they exist?
2023-11-8
Hi there. Thank you for reaching out. This algorithm is set in the firmware, so it cannot be enabled or disabled, and does not support setting the speed. Thank you for your understanding.
2023-11-8
Rbbrt94
Will this be updated in the future? For remote control it's quite important to be able to make adjustments to the joystick's behavior
2023-11-20
signalaudio
There is, actually. Or at least it works controlling the hand grips on the high bright monitor, so I assume it has the same effect when the grips are mounted on the 4D. It's just mislabeled.
On the 4D, open the Menu > Stabilizer > Joystick > Max Speed. This isn't just the maximum speed, it scales the overall speed at any joystick position - it should just be labeled 'Speed'. Exponential curve and smoothing are also in this menu, you just need to ensure that Speed is set to Custom in the top left.
I don't know why DJI's own people are telling you it's not there ?!
2023-11-20
