New DJI Mini 4 Pro Firmware Released (04/23/2024)
50529 345 2023-9-25
Paul Lenz
Flight distance : 3740 ft
Paul Lenz Posted at 10-9 03:29
I am just switching from Mavic 2 Zoom to Mini 4 PRO.
I really like the feature that I can correct AE with the right wheel!
But I am missing two features which were possible on Mavic 2 Zoom:
Yesterday I found another stupid behaviour. I placed my big landing pad on high gras and let my Mini 4 PRO fly and return home automatically. 2 m above the landing pad it decided to stop because it found that the landing conditions are too bad. Seems that it considered only the high gras and did not consider the landing pad it started from.
2023-10-11
Mavic57Minis
Flight distance : 3772247 ft
Monkieboy00 Posted at 10-9 11:22
Thanks for the reply, here are two links to show the drone movement. One is inside the house and it wabbles and moves left and right. The second video is outdoors with a wind of 6-8 mph. The drone has been calibrated multiple times and still no change. My mini 3 was incredible stable indoors and outdoors.
https://youtube.com/shorts/BeXDN90ojsw?feature=shared
Might be a stupid reply but did you remove the thin piece of felt behind the gimbal, it seems the gimbal is not steadying the camera. Try a gimbal calibration if it's not the felt packing.
2023-10-11
Monkieboy00
Flight distance : 101188 ft
Mavic57Minis Posted at 10-11 07:48
Yeah that piece was removed and the drone has been calibrated several times. pretty sure i have a bad drone and it should be replaced under warranty
2023-10-11
Mavic57Minis
Monkieboy00 Posted at 10-11 10:18
I had a bad Mini 3 Pro, the camera was out of focus in one area, replaced by major retailer with no problem.
2023-10-12
Captain....Kirk
Flight distance : 19094 ft
Yesterday I bought a mini 4 pro from best buy canada. In setting it up and out of curiosity I weighed it on a digital scale with standard ( not. Plus or mini 3 ) battery. No strobe, camera filter nor any other add ons.
The weight return was 251 grams. Anyone else noticed this problem? Tried weighing on another digital scale same result.
2023-10-18
RobZilla
Flight distance : 1057844 ft
Captain....Kirk Posted at 10-18 05:52
Out of curiosity as well, I weighed my M4P. I bought the FMC so only the Plus batteries, no Standard. Here is what I have...
- aircraft only: 172.3g
- 3 batteries were on avg: 120.2
- Total a/c + batt: 292.7
2023-10-18
Hi, Monkieboy00. Thank you for the links. Let me forward this to our relevant team for further checking. I'll let you know once we receive an update.
2023-10-18
Hi, Paul Lenz. Thank you for reaching out and sharing your experience. We'd like you to know that we appreciate your valuable suggestions. We will forward your concern to our related department. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you for your understanding and support.
2023-10-19
Hi, Monkieboy00. Thank you for patiently waiting. Please try the steps below:
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range.
3. Please try moving to another flight environment to test.
4. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
5. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
Hope this helps. Please keep us posted.
2023-10-19
fansa908b380
Flight distance : 326818 ft
Any extensive vibration could get IMU crazy and make drone less stable, imho.
2023-10-19
him7403
Flight distance : 405262 ft
was there a new firmware today?
2023-10-30
him7403 Posted at 10-30 15:00
Hi there. No newer firmware for the Mini 4 Pro as of the moment. You can check this link for further details about the current firmware: https://dl.djicdn.com/downloads/ ... elease_Notes_EN.pdf. Have a great day ahead.
2023-10-31
ryguyMN
Flight distance : 17480 ft
There was a firmware update for the RC 2 controller. Pretty substantial in size. Biggest feature was removing height limitations for EU countries.
2023-10-31
djiuser_U2MhJzxvSZiI
Flight distance : 2132398 ft
https://www.youtube.com/watch?v=NLdIjsThZUY&t=56s
2023-11-3
Richard in Boise
Flight distance : 34721 ft
Mavic57pro2 Posted at 9-26 11:04
Batteries need to be updated at the same time. After fully updating RC and Drone, put the next battery in, switch on and check firmware update, follow instructions, ditto for any other batteries you have.
Thanks for the reminder
2023-11-4
djiuser_U2MhJzxvSZiI Posted at 11-3 08:51
Hi, djiuser_U2MhJzxvSZiI. Is there anything that we can help you with? We tried checking the video but it seems to be deleted already. Please let us know if you need assistance with the Mini 4 Pro drone.
2023-11-6
Manitobahunter
DJI Gamora Posted at 11-6 05:39
Thanks for replying, it was solved, and we were able to do the activation later in the evening after seeing some here post that they had been succesful after emcountering the same issue. My opinion is that DJI's server is just too busy, or they are uploading or changing something on their end.
2023-11-6
Steph Jant
Flight distance : 274062 ft
DAFlys Posted at 9-25 05:56
Seeing mixed reviews about the camera sensor,  some reviews are saying same as Mini 3 Pro with improved ISP others are saying same as Air3.    Tempted if the photo quality is improved.
I have both the M3P and M4P. I’ve compared photos from these drones with photos from Air 3 shared by family member. No difference in photo quality, but perhaps no surprise as they all use same sized sensor
2023-11-8
Steph Jant Posted at 11-8 03:41
Interesting you dont see a benefit from the Air3 as thats got a very different stacked sensor than the M3/M4Pros.
2023-11-8
Steph Jant
DAFlys Posted at 11-8 03:54
According to DJI M4P sensor is stacked. Anyway, the photo quality is the same between the 3 drones IMO. Glad I didn’t spend all that extra money buying the Air 3
2023-11-8
Steph Jant Posted at 11-8 04:28
According to the reviewers who confirmed with DJI the Mini 3 and Min 4 Pro camera is the same and just a now ISP was changed on the Mini 4.  DJI here confused it as the same only due to their sensor size.
2023-11-8
Steph Jant
I’m confused. DJI has just issued aircraft FW v01.00.0210 and all it does is fix some known issues (whatever that means). But then in the same thread they list in detail the updates for an older aircraft FW update - v01.00.0200 - issued in September. Why?
2023-11-8
Mavic57Minis
Steph Jant Posted at 11-8 06:16
They just change the title when they issue a new firmware and post it before the previous update, it means all firmware updates can be seen in the same place, same in the Air 3 firmware thread. Why the confusion ?
What was annoying there was a RC2 firmware update a few weeks ago, which was only showing in the Air 3 thread, Why they did n't post that in the Mini4 thread as well. Probably many did n't know there was a RC2 update for the Mini 4 pro.
I think they rely on users getting the pop up on their remote.
2023-11-8
ArcaneXVI
Flight distance : 499951 ft
I would have loved a bit more clarity as well and honestly a separate thread but their company, their rules.
2023-11-8
Mavic57Minis
No update for my RC2, however the drone did need an update. Tried another a battery to see if all the batteries needed updating, they did n't trigger a further update.
2023-11-8
KnNLmS
Flight distance : 119967 ft
Turkey
No goggles? wow!
2023-11-8
djiuser_d3Bi7bZgYQga
Too bad metric to imperial units weren't fixed yet.
2023-11-8
H3llo Posted at 9-25 08:23
Why can't we buy the Mini 4 Pro only (Without RC) ??? I have already the RC-2 and RC-N2 controller!
https://forum.dji.com/forum.php?mod=viewthread&tid=298229
Are you kidding?  That's how they make money.
Just tell dji to exclude remote & you'll still buy for $759
2023-11-8
Malakai_UK
Flight distance : 536115 ft
I can confirm the Aircraft Firmware: v01.00.0210 released on 08/11/2023 doesn’t fix the issue where importing content to iOS using the Apple SD card reader doesn’t show any content on the micro SD card. It can still be viewed when using the Files app and saved to the camera roll this way.
2023-11-8
Manitobahunter Posted at 11-6 08:10
Hi, Manitobahunter. Thank you for the update. We're glad that the drone has been activated already. Should you need further assistance, please don't hesitate to reach us again here at DJI Forum. Happy flying!
2023-11-8
Hi, Steph Jant. All firmware updates for DJI Mini 4 Pro will be posted on this thread thus you will see the date on the title changing. Fixed some known issues are issues that the users usually report.
2023-11-8
Mavic57Minis Posted at 11-8 08:20
Hi, Mavic57Minis. Thank you for reaching out. Please make sure that the RC or mobile phone is connected to a strong internet connection. If the issue persists, please use DJI Assistant 2 (Consumer Drones Series) to update them. Thank you for your kind understanding.
2023-11-8
We're sorry for the inconvenience, KnNLmS. Currently, no Goggles are supported with the Mini 4 Pro but I will take it as a suggestion of yours and will forward it to our designated team for attention. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you.
2023-11-8
djiuser_d3Bi7bZgYQga Posted at 11-8 14:13
Hi, djiuser_d3Bi7bZgYQga. Thank you for reaching out. Are you using an android phone? If so, we're sorry for the inconvenience as the units setting in "Control Settings - Units" cannot influence the distance units in Flight Data Center for Android DJI Fly App but I will take it as a suggestion of yours and will forward it to our designated team for attention. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you.
2023-11-8
Steph Jant
DJI Gamora Posted at 11-8 19:41
Thanks for your message. I’ve not noticed that before. I assumed that only details relating to the most recent FW update would be in the thread, but looking at the Action 4 page (another DJI product I own) I note that the FW update posted on 18 Oct also included details of an earlier FW update released in September
2023-11-8
Malakai_UK Posted at 11-8 15:04
Hi, Malakai_UK. Thank you for reaching out. The DJI folder and file naming convention we currently use extends the JEITA & CIPA standard DCF naming convention, mainly to facilitate users' material organization and selection by optimizing the user's material presentation sorting, such as
1. Support custom directory/material naming.
2. Intuitively distinguish pano, timelapse, hyper-lapse, and other advanced function mode materials.
3. Added timestamp information directly in the naming.
4. Can directly distinguish materials shot by different cameras, such as lenses with different focal lengths.
However, due to the extensive expansion of the DJI folder and file naming conventions, there are a few compatibility issues (such as the Apple camera SD card adapter), so it may not be possible to directly use the system's built-in media library to browse and import materials. If you encounter this kind of problem, it is recommended to connect the storage medium to the target device "by file transfer" and enter the system "File" -> "SD card" -> "DCIM" to browse, download, and process materials. Thank you for your kind understanding.
2023-11-9
DJI Gamora Posted at 11-8 19:57
Yes, have android phone.
It seems like this would be standard protocol for all drones, especially knowing that imperial units is main measurement unit in usa.
2023-11-9
ArcaneXVI
djiuser_d3Bi7bZgYQga Posted at 11-9 07:26
Freedom units work correctly in most places. They just need to clean up the last outliers.
2023-11-9
ArcaneXVI Posted at 11-9 08:41
Then, why don't they?  Never heard term freedom units used before but understand what you mean, i guess.
2023-11-9
What does the new prop guard do in this release?  Keep obsticle avoidance active?
2023-11-9
