Pocket 3: Car Hyperlapse Test.....
842 35 2023-11-8
Testing out my 3d printed Pocket 3 clamp,,   seems more stable than I was expecting,   next test will be to increase from 2X to 10X.
Now the only downside Ive found with hyperlapse so far is the file sizes,    a 12 minutes clip was 10 GB.
Created with Osmo Pocket 3.
          [See My Other Content...]
2023-11-8
Depp
Flight distance : 1868796 ft
I guess you'd have to speed this up quite a bit in post...
2023-11-8
Depp Posted at 11-8 22:39
I was sure how the speed settings would work so the first go was at 2X,  I'll post a 10X later if it works out better.
2023-11-8
Depp
DAFlys Posted at 11-8 22:43
Would be interesting to see if 2x plus 10 x in post looks better or worse than 20x in camera.
2023-11-8
Depp Posted at 11-8 23:15
Just posted the 10X test results.
2023-11-8
Blériot53
Flight distance : 6269839 ft
No apparent wobble from the clamps.
2023-11-8
Blériot53 Posted at 11-8 23:35
So far Im quite pleased with the clamp,  its not too easy to insert but they it would be too sloppy if that was the case.
2023-11-8
Blériot53
DAFlys Posted at 11-8 23:47
2023-11-9
Im thinking of a slight redesign to include a hotshot mount on the side of it for my new W64RGB light.
2023-11-9
Blériot53
DAFlys Posted at 11-9 00:59
Well you're already a hotshot in the photography world
2023-11-9
Blériot53 Posted at 11-9 01:04
bloody auto correct.  Grrr
2023-11-9
Blériot53
DAFlys Posted at 11-9 01:06
I knew what you meant
2023-11-9
DowntownRDB
Flight distance : 1722 ft
Wow, very stable test DA.    Great results for your prototype.
2023-11-9
DowntownRDB Posted at 11-9 03:10
Im just 3d printing another one that will be mounted to the strap on my waist hiking bag,  so I can test hyper lapsing walks. And at waist level it may not be as noticeable.
2023-11-9
DowntownRDB
DAFlys Posted at 11-9 03:16
That's a great idea.  Now you just have to practice your gimbal/ninja walk.
2023-11-9
DowntownRDB Posted at 11-9 09:47
Lol. I was trying to get SWMBOd to do that the other night.
2023-11-10
DowntownRDB
DAFlys Posted at 11-10 03:41
It looks a little strange but it does seem to help.  I've seen a couple of recent how to videos on the gimbal/ninja walk.
2023-11-10
DowntownRDB Posted at 11-10 04:34
Im hoping for hyperlapse that it wont be that nessisary as it seems to remove a lot of the car bumps when Ive tested it so far.
2023-11-10
DowntownRDB
DAFlys Posted at 11-10 04:48
Please let us know how the testing goes.
2023-11-10
DowntownRDB Posted at 11-10 11:14
I think I figured out my 2.7K issues.  It only happens if I rotate the screen to power it off.  It sets the resolution because it portrait and never sets it back to 4k.   Shame but Im not sure I can call that a bug.
2023-11-11
DowntownRDB
DAFlys Posted at 11-11 01:25
So are you saying if you turn if off via the power button and then rotate the screen afterwards that it retains the last used setting?
2023-11-11
DowntownRDB Posted at 11-11 08:42
Yes exactly,     Use the button and its fine, rotate screen to power off and it resets to 2.7k
2023-11-12
DowntownRDB
DAFlys Posted at 11-12 00:14
That definitely seems like something that can be fixed in a FW upgrade.
I keep seeing more and more overheating issues with OP3 and 90% of the users seem to be in the EU or UK.  Seems like a bad batch got through QA.  So far, knock on wood, I've not seen mine overheat.
2023-11-12
DowntownRDB Posted at 11-12 08:40
I had one over heat so far,   it was on charge and I was trying to download over wifi 12gb.    Not that I knew that at the time
2023-11-13
DowntownRDB
DAFlys Posted at 11-13 01:17
No doubt that generated an excessive amount of heat.
2023-11-13
DowntownRDB Posted at 11-13 08:51
So far its the only time but then the temps here where Ive been using it have been under 20c.
2023-11-14
DowntownRDB
DAFlys Posted at 11-14 00:26
For its really small size I think it does dissipate heat very well.
2023-11-14
DowntownRDB Posted at 11-14 08:48
I see theres a txt file you can put on the SD card that will allow it to get hotter before it shuts down.  Seems that its set to max temp based in EU rules.
2023-11-15
DowntownRDB
DAFlys Posted at 11-15 00:05
That must be the "hack" a couple off posters were referring to on the Reddit forum.
2023-11-15
DowntownRDB Posted at 11-15 09:31
Could be,  I saw it on YouTube first.
2023-11-16
DowntownRDB
DAFlys Posted at 11-16 01:12
I wonder what the long term effects will be on the OP3 with using that hack.
2023-11-16
DowntownRDB Posted at 11-16 11:00
It seems it's just to keep it in the EU regulations so probably no issues at all.  but as Im not having a problem I haven't used it just in case.
2023-11-17
DowntownRDB
DAFlys Posted at 11-17 04:50
Good to know.
2023-11-17
Nice and smooth!
2023-12-24
Not bad for a home designed and made 3d printed mount.
2023-12-24
DAFlys Posted at 12-24 06:46
Not bad at all!
2023-12-24
