Pocket 3 connect with DJI Mic 2
11707 33 2023-11-8
Anson Li
Flight distance : 830614 ft
After around 2 week of using, I found out both pocket 3 and DJI Mic.2 need a long for making connect sometime even I tried to reconnect the mic. Can DJI fix this problem
2023-11-8
DowntownRDB
Flight distance : 1722 ft
Your MIC 2 might be having issues as my MIC 2 connects to the OP3 instantaneously when it is turned on.
2023-11-8
Hi there. Thank you for reaching out and we're sorry for the trouble. Could you please send us a short video showing the issue so we can check it further? You may refer to the information below on how to properly connect your DJI Mic 2 transmitter to the DJI Osmo Pocket 3:
1. Swipe down from the top of the camera touchscreen, tap the Settings icon, and select Wireless Mic > TX1/TX2. Then the camera is ready to link with the transmitter via Bluetooth.
2. Press and hold the power button of the transmitter for two seconds to power it on.
3. Make sure that the transmitter is in Bluetooth linking mode when it is powered on. If the system status indicator of the transmitter turns solid green, press and hold the Record button for three seconds to switch to Bluetooth linking mode. The system status indicator of the transmitter will blink blue slowly.
4. Press and hold the linking button of the transmitter for two seconds, and the transmitter will start searching for nearby Bluetooth devices. During this process, the system status indicator of the transmitter blinks blue quickly.
5. When the transmitter is successfully linked with the camera, the system status indicator of the transmitter will be solid blue. The screen will display a "wireless mic connected" message. Press the linking button on the transmitter to start recording while using the transmitter for audio. Press the linking button again to stop recording.
2023-11-8
djiuser_jH5kSM4O3ciB
I AM FACING THE SAME ISSUE ITS JUST BEEN A WEEK AND I AM UNABLE TO CONNECT DJI MIC 2 WITH OP3.
2023-11-13
Did the problem fix?
2023-11-13
Anson Li
djiuser_jH5kSM4O3ciB Posted at 11-13 07:10
I have tried to reset op3 to factory setting and seen a little bit better
2023-11-13
MarcInOz
Same issue.  I have followed all instructions 50 times and I cannot connect the Mic 2 to the Pocket 3.  This is absolutely unacceptable.  I guess I'll try calling the Support line next.
2023-11-16
marceloceara7
Flight distance : 1737208 ft
Hi everyone,
Just both the osmo pocket 3 also the mic’s and I’ve tried everything to connect the wireless audio, followed all the tutorials online but still not working. It says the light will blink blue on the mic but on mine I only see green blinking, sometimes slow sometimes faster. Does anyone know what could be?
2023-11-26
mattcl
After 2 weeks of use the mic stopped connecting as well. Talked to support for over an hour and tried everything they suggested and nothing worked. They requested the data log of me attempting to connect the mic and offered me to send the device for servicing. This has been so frustrating and really put a damper on my excitement for this camera. I'm now concerned this camera may not be as future proof as I anticipated.
2023-11-27
mattcl Posted at 11-27 17:42
Hi matt. Thank you for reaching out and we're sorry for this unpleasant experience. Once we receive the unit at our facility, rest assured that we will identify the main issue of your DJI Mic 2 why it refuses to connect to your DJI Pocket 3. We will provide you necessary warranty coverage according to the damage assessment conducted on the unit. Should you have other inquiries, feel free to contact us. We appreciate your understanding and support.
2023-11-28
rendell
just now i’m having similar issue as yours my dji mic won’t connect with my pocket 3 i tried the instructions above and still won’t connect about 40 times, reset my pocket 3 and nothing works, help dji
2023-11-29
fans2d2e3f82
Flight distance : 28002 ft
I cannot get the MIC2 to pair with Pocket 3, in any configuration after multiple efforts.  (Discosure, I am colorblind and have not yet seen anything that resembles a blue light).
Frustrated.
2023-11-30
djiuser_teOMugPmAyfs
Costa Rica
I was having the same issue.
And manage to fix it.
This worked IN MY CASE.
With the green light was blinking:
The red circle button on the other side of the mic, I pressed it once to turn the light red on that side, then I holded it for 3 seconds, and it worked. Light back to blue an connected again.
2023-11-30
rendell Posted at 11-29 20:31
Hello, there. We're sorry for the inconvenience that it may have caused you. May we ask for a short video showing the linking process? You may use Google Drive or Dropbox then provide the link here. I look forward to hearing from you.
2023-12-1
fans2d2e3f82 Posted at 11-30 08:24
Frustrated.
Hi. Apologies to know about the trouble. May we ask if you could provide a sample video showing the operation? You may upload through Google Drive or Dropbox and provide the link here. I hope to hear from you soon.
2023-12-1
djiuser_teOMugPmAyfs Posted at 11-30 20:04
Hi, there! We're glad to know that everything has been sorted out. Thank you for sharing your advice here in the DJI forum. Thank you for choosing DJI!
2023-12-1
rendell
DJI Gamora Posted at 12-1 02:28
I have a video but i do not have permission to post video links it says.
2023-12-1
rendell
rendell Posted at 12-1 18:09
Figured it out, i guess i didn’t hold down the link button long enough while trying to connect the mic to the pocket.
For anyone having a similar issue, make sure you hold the red button until it turns blue then once that happens hold the LINK button hold it for a while until it connects!
2023-12-1
rendell Posted at 12-1 18:30
Thank you for your update. We're glad to hear that everything has been sorted out. Thank you for taking the time to share your experience and advice with us. Please feel free to reach us anytime.
2023-12-2
RDPhoto3
Flight distance : 90686 ft
So today 12-14-2023 after owning for two weeks myself the DJI Mic 2 could not be recognize by the Pocket 3.  You could pair it and everything but the little Green Status bar was not there at the top of the screen and when you recorded you got no sound.  Short story after many failed attempts to get it Re-Linked.  I had to do a full Factory Reset.  Seems to be working again now.
2023-12-14
djiuser_VsgEDAAkJ9mB
Hi i did everything to connect tje DJI MIC 2 with my osmo pocket 3 (factory reset) And i even bought new DJI MIC 2, and the same problem happens.
How can i connect??
2023-12-19
TSRWC72
Flight distance : 15994 ft
MAYBE A SOLUTION TO THE PROBLEM - PLEASE LET ME KNOW WHETHER THIS ALSO WORKS FOR YOU
Hi All,
same issue here! All of a sudden my Osmo Pocket 3 did not correctly connect to the Mic 2 anymore. The camera showed though that mic is connected, but I didn't get the volume bar on the top of the recording screen. Very frustrating, since I wanted to get some recordings done today.
I disconnected the Mic 2 and connected it again to TX1 => same issue ... seems like connected, but no audio in the recording
I disconnected the Mic 2 and connected it to TX2 this time => works w/o any problems (!!???!!)
I was able to replicate the issue. Disconnected and connected to TX1 => doesn't work. Again connecting it to TX2 => works!
Please try out and reply if this solves your issue as well
2023-12-28
Addy Overbeeke
Flight distance : 764869 ft
Frustrated.
Looking at the Mic 2 from the front side with semi-clear cover and big white "dii" letters (opposite of clip attachment side), the right side of the Mic 2 has the Blue Light Side. below that is the Link Button (Icon on button looks like the number "8" as a symbol).
Follow instructions for fast flashing blue light followed by pressing the Link Button....
2023-12-29
DJIRIDOO
Same issue, brand new DJI OSMO Pocket 3 and DJI MIC 2 set kit, bluetooth pairing mode does not work (when holding record, there's no blue light display, even after one minute), holding link does not bring up a blue light. Only seeing green lights. Is this a bug? What's going on? Do I need to return a broken product?
1-12 16:29
DJIRIDOO
djiuser_VsgEDAAkJ9mB Posted at 2023-12-19 08:58
How can i connect??
It feels like a defective product. Same issue for me. I'm going to return it.
1-12 16:41
DJIRIDOO
DJI Gamora Posted at 2023-12-1 02:28
I have the exact same issue but I cannot solve it. Can you help me?
1-12 16:42
DJIRIDOO
marceloceara7 Posted at 2023-11-26 17:03
Hi everyone,
Following, I have the exact same issue. Seems like defective product.
1-12 16:43
DJIRIDOO Posted at 1-12 16:42
Hello, there. Sorry to hear about the inconvenience. May we ask if you managed to perform the firmware for the DJI Pocket 3 and DJI Mic 2? If so, you may provide a short video showing the operation for further checking. You may upload thru Google Drive or Dropbox then provide the link here. I hope to hear from you soon.
1-14 02:42
DHW
Flight distance : 1063596 ft
Argentina
TSRWC72 Posted at 2023-12-28 17:18
Hi All,
Thank you for this solution.
I've bought the 1 transmitter + 1 receiver and paired it with my Pocket 3 under TX1. The green volume bar appears once and then it disappeared. No matter how many times I unpaired and paired the mic 2 to Pocket 3, the green volume bar is never there and no volume recorded.
Until, after reading this post, I paired it under TX2 on my Pocket 3 and everything worked for me.
Thanks for this solution. Was about to go into a DJI store and return.
1-21 02:51
Duca Simone Luc
DJI Paladin Posted at 2023-11-8 17:38
Unfortunately, I have the same problems and I tried ALL procedure more times: no ways. I also tried to update all Firmaware (RX and TX) but both update nothing..., simply doesn't happen anything.
I now send back my DJI Mic 2 and ask for  a new one, hoping there will be a way to update them and to pair them to the Osmo Pocket 3.
However, it is incredible that despite numerous reports, this problem has not yet been resolved.
Best regards,
3-21 11:07
Duca Simone Luc Posted at 3-21 11:07
Hello. Thank you for reaching out. We're sorry to know that you came up with a decision to send in the unit for replacement. Hope that you'll receive the replacement unit as soon as possible. Please note that we can confirm an issue by sending us a video showing the problem, that way, we can coordinate it with our engineers to identify the main cause of the issue and devise troubleshooting steps to isolate it remotely if possible. If you experience the same issue again with your new unit, please record a video and send it to us so we can check it further. We appreciate your valued support.
3-23 05:21
djiuser_ibUGdeWSDBVH
Hey there,
My problem is one i haven't come across online yet.. Literally just bought the pocket and wanted to link the mic for the first time. Now it keeps connecting and disconnecting on and off... After i tried to factory reset it and update the mic 2 to the latest version, it did the same thing for a while and now doesn't even connect at all... Putting it in linking mode and everything, but it doesn't work...
Really hope someone can help..
Many regards,
-Mike Hardy
5-26 05:06
Fishycomics
SUggest to write al lsettings down, and factory reset the Pocket 3. then go in to the Pocket 3 again and to the Tx1 or tx 2, press one, and  DJI Mic 2, Stand alone  turn on,   the Blue is lite that is  camera mode, and Long press the link till rapid flashes, and within 5 seconds it should  connect.
5-26 05:19
Hey man!
Thanks a lot for the response!
I was about to try your way, but i read that someone fixed their problem by just trying the TX2 instead of the TX1. And for some reason that worked for me aswell.
So for anyone that needs it in the future, what worked for me was turning the pocket off for a while so you get the DJI logo when it boots up. After that i just clicked on TX2 and made sure the microphone was on the "blue LED" mode, and i held the link button until it started blinking. And indeed after a couple of seconds it just connected, and stayed connected this time.
Hope DJI finds out what causes these problems because it can be really frustrating, especially because the OP3 is such a fun and useful product, and i just couldn't wait to get it started hahaha
All the best!
-Mike
5-26 07:36
