Osmo Mobile 6 and Google Pixel 8 Pro
3346 8 2023-11-26
fplanglois1
Flight distance : 130105 ft
The Pixel 8 Pro is not in the list of smartphones compatible with the Osmo Mobile 6.
Do you have any information regarding what works or not with this mobile?
I wanted to buy it during Black Friday, but without this information, I'm hesitant.
2023-11-26
Hello, there. Thank you for raising this query with us. Osmo Mobile 6 is compatible with most smartphones on the market. It is recommended to use smartphones with a width of 67-84 mm, thickness of 6.9-10 mm, and weight of 170-290 g. However, since the mobile device mentioned hasn't been tested, we encourage you to visit your local dealer to test your device with our DJI Mimo app and Osmo Mobile 6. You may visit this link to check your local dealers: www.dji.com/where-to-buy Thank you for your understanding.
2023-11-26
fplanglois1
DJI Gamora Posted at 11-26 22:07
In France, the closest DJI seller is 800 km from me. It's going to be very complicated ;)
2023-11-27
fplanglois1 Posted at 11-27 10:39
Thank you for your follow-up. It's unfortunate to point out that this device hasn't been tested at the moment, therefore, some functions may not be available and the stability of the app can't be guaranteed. Thank you for your understanding.
2023-11-30
djiuser_DuMA5kIvAChP
Turkey
hi there. I bought a Dji om from amazon on June 6, 2023. the serial number of the device I bought: 5W3VM2292626201T1X
I sent the device to the technical service named 'karfu karacasulu fatih/istanbul' in september 2023 because it was not possible to shoot videos due to noises coming from the upper connection point. however, although I sent videos to them, they said there was no problem with the device and sent the device back. On 21.11.23, I returned the device to the service again as the same problem persisted. however, this time I was informed that this problem was a 'consumer fault' due to 'rusting-oksidation' and no intervention was made. of course, I will use my rights through legal means to the end.
2023-11-30
djiuser_DuMA5kIvAChP Posted at 11-30 08:03
Hello, there. We're sorry to hear about this situation. We'll communicate your concern with our relevant team for further checking. I appreciate your patience.
2023-12-1
DJI Wanda
Hi, there. We left messages in PM. Would you please check and reply to us? Thank you.
2023-12-1
djiuser_hcRzLinoQhHv
Hello, I purchased a Google Pixel 8 Pro and I no longer can access the application for Mons.
Is there a development plan for the application so that it works with the Pixel 8 Pro?
2023-12-31
fplanglois1
RE: Osmo Mobile 6 and Google Pixel 8 Pro
Since I opened this thread, I finally bought the Osmo Mobile 6 on Amazon (so I could return it if I wasn't satisfied with it).
The DJI Mimo app works smoothly on my Pixel 8 Pro, but with the following limitations:
  • The Osmo Mobile Pro zoom only performs digital zoom, it does not use the optical zoom of the Pixel 8 Pro. This is, for me, the biggest limitation.
  • Limitation to 4K 30 fps in video
  • Loss of advanced AI settings.
We can of course use the DJI Osmo Mobile 6 without DJI Mimo, that is to say with the Pixel photo application to find all these settings, but then we lose:
  • Active Track.
  • Auto pan mode.
  • Firmware updates.
You must therefore use one mode or the other according to your needs.
DJI would benefit from exploiting, in DJI Mimo, the optical zoom of the Pixel Pro which is a reference in this field.
2023-12-31
