Solid Magnetic/Clip Mount
1054 8 2023-12-7
skysailor64
In case anyone is hesitant to rely upon the DJI Magnetic/Clip mount for the Action 4, here are a couple of photos of my OA4 mounted on my wing strut subjected to wind speeds of 80 to 120 mph  (it's just a Cessna 150 after all )  I have made multiple flights using this system relying upon the DJI magnetic/Clip mount  and have not been disapointed...or lost my camera! Ha ha.
2023-12-7
Anonymous1
Flight distance : 602303 ft
Jamaica
I cringe, just looking at these photos.  I know the DJI mounting point is good.  I just don't trust that magnet with the wing and unexpected turbulence.
I'd have to tether it to the strut for peace of mind.
2023-12-9
osmonauta
Hungary
Well, let's hope you won't hit any bird with it! Cuz that will be the REAL test :-)
2023-12-9
skysailor64
Anonymous1 Posted at 12-9 12:32
Yes I thought of doing that by using the cage that comes with the camera and tethering it to the strut.  But after trying very hard to separate the camera from the mount I felt it was strong enough.  It's really not the magnet that is the primary holding method but the clasp.  Short of smashing the camera against something solid I could not make that system fail.  In the extremely rare event of a bird strike exactly at that point of my aircraft as suggested  by osmonauta, the other mounting hardware (ball and socket) will absorb a lot of that force so doubt it would result in the camera parting from its mount.  But I do admit to some concern when I first tried it and even now I understand there is some risk albeit extremely low in my opinion.
2023-12-10
stewebe
Flight distance : 518488 ft
I just bought my Action 4 and am not completely happy with the magnetic mount. I use the original DJI mount and also the Ulanzi. With both mounts and attaching them to the camera bottom directly or to the side of the DJI frame most of the time the magnetic mounts snap in place but one of the clasps does not fully engage. In that stage the camera can come off with little force. I always have to look closely and force one of the clasps into its correct position. Thats a bit annoying but then the grip is very strong.
What is your experience?
Does it automatically snap in place with both clasps locking correctly or do you have to check and correct?
4-10 00:48
osmonauta
Hungary
stewebe Posted at 4-10 00:48
It’s really very easy. First you lock one side in place then the other - as opposed to trying to lock both at the same time. Practice makes perfect.
4-10 02:29
Flight distance : 2354357 ft
Not really had this issue with mine, i do double and triple check it cause i use it on my helmet when kayaking, i also use a long tether just in case.
4-10 03:24
Fishycomics
WOW I got to get one  thanks  for sharing
question you have a 2nd  camera set up on the other side.,   could you not replace that bolt  with a  set up to secure down then have it removable, and  the What if it did fall off.  and guess Magnets are no longer an issue on a plane anymore?
4-10 03:25
skysailor64
Fishycomics Posted at 4-10 03:25
Hi Fish.  I have only one camera and it can be mounted on either wing but I only ran the USB-C cable for power and audio from the cockpit to the left wing.  The mount is removed from the tie-down ring after each flight.  This is all done without making any permanent modifications to the aircraft.  Making any modifications to a certificated aircraft is not allowed without FAA approval.  As far as the magnet being an issue on the aircraft the only thing I would need to take care of would be not to put the camera(magnet) too close to the magnetic compass.  Being more than a foot away usually suffices.  As far as falling off...well the magnetic mount is firmly attached/clipped in and checked prior to flight.  The mounting system attachment bolt & nut to the tie-down ring is securely tightened and then a Nylock wingnut put on that bolt to ensure that even if the system comes loose it can't completely come undone.  The only part of the mounting system that is not backed up is the ball and socket but it is very tight and have never had one come loose but I pay very close attention to that and make it very tight .
4-10 06:11
