lightcut failed to load some files
1995 20 2023-12-24
-Panos-
Flight distance : 31949 ft
as the title, it connects fine, but the video files are blank, and when i try to do anything i get the failed to load some files error... photos on the other hand show ok...
mini4pro latest firmware and latest ios 17.2.1 and freshly installed lightcut... i tried the airplane mode but i get the same error... only with the video files, photos load fine...
2023-12-24
djiuser_ZflDziSYsVd7
Bulgaria
I have the same error, same IOS version, same drone. I can download video from drone via DJI Fly App album without any problem, but for some reason I can’t do it in LightCut
2023-12-24
Per Olsson
Same issue, newest IOS and can only download pictures and not movies so it is a bit hard now to edit movies
2023-12-24
Hi there. Thank you for reaching out and we do apologize for the trouble. Please upload a screen recording showing the issue so we can check it further. You may upload the video via Google Drive and then send the link here. Please keep us posted.
2023-12-25
-Panos-
DJI Paladin Posted at 12-25 02:08
Here is a screen recording showing the issue.
i also tried it on another iphone as well, same results.
https://share.icloud.com/photos/0461hhmE6v9EUdhJvsKMESpKg
2023-12-25
moe 1812
Flight distance : 69 ft
same issue talked to another user last night we went through everything we could think of he has 13 years' experience, and we couldn't figure out how to solve this pretty frustrating
2023-12-25
-Panos-
i also tried to record in all possible formats h264/h265 4k/1080 different framerates... nothing works... its not a video format problem.
2023-12-25
Bulgaria
It work again with the latest app update, thanks for the quick update!
2023-12-26
LightCut App
China
-Panos- Posted at 12-25 03:41
Hi Panos, team already fixed this issue, please update your app to the latest version 4.79.0 and try, apologize for the inconvenience
2023-12-27
-Panos-
LightCut App Posted at 12-27 03:12
yeap, i just updated the app, and it works as expected!
Thank you all for the super fast response! you are a great team!
2023-12-27
-Panos- Posted at 12-25 02:17
Thank you for the information provided. Please try to reinstall the Lightcut app on your mobile device then check if the issue persists. If yes, try the following solution below:
1) Try to change materials.
2) Check whether the device is connecting to a functioning data network. For a device without a SIM card, a connection to LightCut may occupy the Wi-Fi channel, preventing the templates from being downloaded.
If the issue persists, we highly recommend contacting our team by sending an email to lightcutapp@gmail.com . Thank you for your understanding.
2023-12-28
threadssky
I understand that you're having trouble with Lightcut failing to load some files. This can be frustrating, but there are a few things you can try to fix the issue:
General troubleshooting:
Restart your device and Lightcut: Sometimes a simple restart can resolve temporary glitches.
Check your internet connection: If you're using online templates or assets, make sure you have a stable internet connection.
Update Lightcut to the latest version: Updates often include bug fixes and compatibility improvements.
Reinstall Lightcut: If the issue persists, try uninstalling and reinstalling the app.
Specific to the files:
Identify the specific files: Try to identify which files Lightcut is failing to load.
Check file format and location: Make sure the files are in a format supported by Lightcut and are located in an accessible location.
Convert the files: If the files are in an unsupported format, try converting them to a compatible format using a media converter.
Check file permissions: Ensure that Lightcut has the necessary permissions to access the files.
Additional resources:
Lightcut forum: Check the Lightcut forum for similar issues and solutions: <invalid URL removed>
Lightcut Support: If you've tried all of the above and are still having trouble, contact Lightcut support for further assistance: <invalid URL removed>
I hope this helps! Let me know if you have any other questions.
2-4 21:19
-Panos-
threadssky Posted at 2-4 21:19
Thank you all for the replies, the issue has been fully resolved with the latest version of the app.
The response from the developers was super fast, everything works fine now.
2-5 07:15
djiuser_bKjrGiRufLqU
I have the same issue and I tried everything, updated iOS updated the app reset devices, removed and reinstalled the app but nothing works, files load blank and it show failed error.
Any advice?
3-16 18:31
Hi there. We do apologize for the inconvenience caused. Please confirm what specific mobile device are you using. Also, please upload a short video showing the issue so we can check it further. We will wait for your response. Thank you for your cooperation.
3-17 01:04
Hello I am having the same issue drone connects with the app but the files are blank and it shows failed error, tried everything updated ios reset phone, updated the app, remove and reinstall the app and nothing works it is still the same.
Any advise ?
3-19 16:32
Any advice?
3-20 15:16
Here are the pictures of the error,
Any help ?
3-21 19:56
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Please confirm what specific mobile device are you using. You may upload the video or screenshot showing the issue via Google Drive then send the link here for further investigation. We will wait for your response. Thank you for your cooperation.
3-22 22:07
thecesarj
Hi there! I've recently picked up the Action 4 and was also excited to try out the 1-Click AI edit feature in the Lightcut app. However, I came across the same issue as everyone here: I would connect my device to the Lightcut app, but all of the footage would show up blank (no previews whatsoever), and even if I tried to select a few and click the AI edit button the app would just crash with a "failed to import videos" error message. Super frustrating!
[MY TEMPORARY FIX]
You kind of have to toggle your cellular data ON and OFF during the process. Here's how I would do it: Open the Lightcut app > connect to device > then, turn cellular data OFF > Click "One-Tap Edit" and when you view your devices content they might now appear as you'd expect, with thumbnails and previews > select the ones you want > click "Continue". HERE is where you may have to turn cellular back on, as, in my case, the app needed network for AI to find a template and analyze the footage. So I turned cellular network back on, and kept it on for the rest of the process. However, I'd say if you find yourself stuck on one step (maybe the app fails to load past one step), it may help to turn off cellular and try it again. You'll pretty much have to play around with this. Not ideal at all, but doing this helped me successfully use the app to make one video. So, to summarize: keep cellular data OFF during any media selection process (this is the only time you'll absolutely need to have cellular data off); once you move past the media selection stage, toggle Cellular data back on to let the app's AI feature do it's work. If you get stuck in the middle of a step, try turning cellular data off and trying it that way; if it still fails, turn it back on and try again; rinse, repeat.
Q: How did I even know to mess with Cellular Data in the first place?
A: I searched everywhere for others having this same issue, and no one had any sort of fix. Seems like the app works fine for 95% of the users. But, I did find a video by @AirPhotography on YouTube where he quickly mentions that cell data bug in a Lightcut video. He doesn't go into much detail about it, but even just mentioning it was enough to get me to try it. Hope it helps! If it does, let me know!
As for DJI SUPPORT: Please look into this. One-Tap Edit is such a great feature, especially for trips when we don't want to spend hours editing a quick recap to show our family, or spend hours exporting footage to our phones as a workaround (defeating the value proposition of One-Tap Edit). Help us affected users be able to fix this, please and thank you!
5-21 06:05
LukeArh
I'm having the exact same issues.
Made some progress with the suggestion above by TheCesarj but was extremely buggy and couldn't finish it.
Extremely frustrating.
Please sort out!
FYI - iPhone 13 Pro
5-26 20:48
