JohnnyReb69
Controller and Aircraft firmware just updated:Aircraft Firmware 01.00.0700
RC Firmware 01.03.1000
My Mini 3 was not used since October. Just pulled it out a few days ago and noticed the firmware updates that were available. I went ahead and updated and now I have these problems.
1. Upon takeoff, the aircraft lurches slightly forward and to the right, almost causing it to ground.
2. The hover is not steady like it used to be, it seems like it is hunting to stay in a location.
3. First flight I took it up to about 70 feet without issue but the aircraft would not go forward, just backward. My side-to-side wanted to go forward, almost hitting some trees. The obstacle sensor said it was picking up something below, even in the clear at 70 feet. I moved it backward away from trees by about 30 feet and I was able to get it to come down. When I tried to land using the pull down method, it got close to the ground but never touched and remained in an unstable hover about 6 inches off the ground.
I then turned it off. Made sure the obstacle sensors were clean, which they were, reset all settings using the controller, recalibrated the compass and remote controller. Tried again. This time, I was able to increase the altitude and took it out over my pasture. Initial feeling was it was working properly until I tried to fly it back. Signal was great but I could not get the drone to respond to turn around. I went out to the point where I could see it and it was hit-and-miss for its response. Finally got it over me and lowered the altitude where I could grab it.
Any ideas on what I can try to get this thing working correctly again?
