Hello guys and Happy New Year, I have a particular question: I should inspect several solar fields with my drone, I have a DJI Mavic 3T RTK and the problem is:
- I need to inspect the panels not for thermal images, but to photograph (or video) the (very) small serial numbers on the panels. The problem: 1. - serial numbers are VERY tiny but.... flying manually at an altitude of 10m and with tele-lens (after 7x and above) the videos are very impressive and the serials are very well defined and usable but the manual flight at a very low speed is very very inefficient and basically walking along with a videocamera is faster.
2. - I would need a system or software where I would just create an "automated line mapping" for each line of the solar panel, at a very low altitude 8-10m with terrain following with RTK on BUT...
3. - the camera used would be the "tele" camera and not the "wide" camera as this one doesn't have the resolution to recognize the tiny numbers.
4. - or... having manual control of the camera WHILE the drone is automatically flying alone the "line" of solar panel. Now, I use the DJI Pilot 2 and of course there it's impossible to have this result (min. alt. is 25m, no manual control of tele-camera). Which solution or software do you think it's the best for this very different work? Does some PIX4d software allow this? To fly so low and to have manual control of the camera? Thank you so much for this! Best
