Renovation update 25
890 76 1-5 12:39
I have been painting windows and window frames. Lots of sides and layers to that job, so it takes quite long.
(drying is also slow now)
And Marcel installed the internals of the sockets today.
The rest will be done after wallpaper + painting.
1-5 12:39
DowntownRDB
Flight distance : 1722 ft
Really nice update Peter.    No doubt all that detailed painting takes time as well as the wait for it to dry before a second coat if needed.  Good to see Marcel back doing a bit more electrical work.
1-5 15:06
Depp
Flight distance : 1868796 ft
Getting there!
1-5 22:34
Blériot53
Flight distance : 6297215 ft
Another step on the road to completion
1-5 23:14
Windows,   they look more like picture frames with the quality of the painting that good.
1-6 01:47
DowntownRDB Posted at 1-5 15:06
Yup. Today the final 'outdoor' coat that I will apply when they are still indoor.
Next job (Monday) will be some indoor paint.
1-6 02:10
And absolutely. Very glad the sockets got connected.
1-6 02:10
Slowgress
1-6 02:11
Blériot53 Posted at 1-5 23:14
Very true.
Long road it is, but I'll get there .
1-6 02:11
Blériot53
Montfrooij Posted at 1-6 02:11
Very true.
Your persistence is commendable
1-6 02:13
DAFlys Posted at 1-6 01:47
Thanks.
One more layer today and then I'm ready for the 'inside' part of the wood.
1-6 02:14
Montfrooij Posted at 1-6 02:14
Thanks.
Hopefully it's not turning cold there like here.
1-6 02:17
DAFlys Posted at 1-6 02:17
It is getting colder for sure.
But the glass will be installed next Friday or Monday. And I have decided to keep the plywood on the outside, so I don't have to worry about the sealing yet.
That will come when the temp gets above 5 at night for a longer period of time.
I will first focus on the inside jobs.
1-6 02:21
Blériot53 Posted at 1-6 02:13
I need to kick myself in the back part every now and then (like now.....)
1-6 02:21
Blériot53
Montfrooij Posted at 1-6 02:21
Get on with it then!
1-6 02:28
Does that mean you have to take the ply down to install the window and then re install the plywood?
1-6 02:51
DAFlys Posted at 1-6 02:51
Technically, we could install them from the inside and leave the plywood in place. But we want to cut the outside rods as well, so we need to measure the outside too. (which can only be done once the glass is installed).
But it's a 15 min job to remove the plywood and re-install it (with 2 man even less I think) so I will do that probably.
That way we can also judge if the windows are looking good from the outside (those seams will be most visible, inside they will be covered). So yeah, we will take it away briefly and replace the plywood when we are done.
I still have to paint the cuts from the rods, so we can't install those immediately.
Long story, but I hope it makes sense.
1-6 03:01
Blériot53 Posted at 1-6 02:28
I will soon.
First have lunch.
1-6 03:01
Blériot53
Montfrooij Posted at 1-6 03:01
I will soon.
First have lunch.
Eet smakelijk
1-6 03:03
Im not sure what you mean by rods?
1-6 03:03
DAFlys Posted at 1-6 03:03
Oh wait, that did not translate well.
It's I think it is called a 'grille' which is a piece of wood that mimics the old way they used to overcome the limit in glass size they could make when they wanted bigger windows.
So they had these wooden pieces that were creating smaller panes where pieces of glass would be fit in.
Nowadays it's usually one big piece of glass, sometimes with dividers 'inside' the double glass and you just stick the wooden grille on top.
We used to have real ones in the top windows, but now we made the fake ones.
But still with this divider in between, so you can't see through the grilles.
(not our window btw)
So the aluminium inside is just 'fake' (the glass is in one piece) but the wood outside mimics the old way.
1-6 05:05
Here you can see the old top windows with the original ones (that really divided the glass in 4 separate pieces.
1-6 05:11
Thanks.
Final layer on the outside of the windows is applied.
Now 2 days of drying and then the inside part of the windows
1-6 05:12
Blériot53
Montfrooij Posted at 1-6 05:12
Thanks.
I hate painting windows. We opted for UPVC last time.
1-6 05:42
DowntownRDB
Montfrooij Posted at 1-6 02:10
Woohoo, that's more progress.  You'll be a master at painting once you finish all those edges and detailed areas.
1-6 08:37
DowntownRDB
Getting the sockets in puts another check in the block for sure.  No doubt he'll be back once you get the wallpaper up to finish with the electrical stuff.
1-6 08:38
Blériot53 Posted at 1-6 05:42
Yeah, sometimes I think we should have gone that route.
1-6 08:59
DowntownRDB Posted at 1-6 08:37
Hahahahahahahaha.
Don't say that out loud.
They will ask me every time.
1-6 08:59
DowntownRDB Posted at 1-6 08:38
Yeah, some more work to do, but he had a party from his work he had to go to.
1-6 09:02
Blériot53
Montfrooij Posted at 1-6 08:59
In France we had 15 windows and 3 doors, so it was a no-brainer.
1-6 09:40
DowntownRDB
Montfrooij Posted at 1-6 09:02
No doubt lots of parties between Christmas and New Years.  You need to hang onto Marcel for electrical work as he seems to be a really good worker.
1-6 09:58
DowntownRDB
Hahahahahahahaha.
     Mum is the word.
1-6 09:59
Blériot53 Posted at 1-6 09:40
Knowing what I know now, I probably would have chosen that too.
1-6 10:01
DowntownRDB Posted at 1-6 09:58
I'm planning on doing just that. And he is a nice guy too.
1-6 10:02
Is that an expression?
1-6 10:02
DowntownRDB
Montfrooij Posted at 1-6 10:02
That makes it even better.  No doubt you can pick up some good tips off him also.
1-6 10:24
DowntownRDB
Yes.  "Mum's the word" means "keep quiet - say nothing".
1-6 10:27
Blériot53
Montfrooij Posted at 1-6 10:01
Mrs.B laid the law down at the time
1-6 10:27
Blériot53 Posted at 1-6 10:27
Same here.
1-6 13:44
DowntownRDB Posted at 1-6 10:27
Learning.......
1-6 13:45
