New DJI Osmo Pocket 3 Firmware Released (05/15/2024)
51715 258 2023-10-26
Altero
Strangely, my Pocket 3 don't prompt me to update firmware. By itself or when I connect it to DJI MIMO app. I tried to reinstall the app, but it didn't help. Are there any other ways to update?
P.S> I got my prompt by now. All updated. I don't know why there was a delay.
2023-12-1
Steph Jant
Flight distance : 274062 ft
Hallmark007 Posted at 11-29 09:02
You might be right there about a bit of code. But I have found even using big brand cameras even like Leica you settings go back to default when introducing new firmware.
I think it depends on the camera. I also own the Lumix S5ii full frame mirrorless camera. There was a big FW update in October but all my settings and custom presets were preserved
2023-12-1
TooDeep
BruceLee Posted at 11-30 12:31
Same for me also.  Waiting to hear a solution for this
I did the same thing. However, in my case I realised I had not turned on the mic/transmitter. I expected this to be a problem of my own making but as soon as I reconnected the transmitter to my laptop, this time with the transmitter turned on, I got the red and green flashing lights for a few seconds and the .bin file disappeared. So the firmware updated even though I didn't follow the instructions for doing so to the letter. I'm not recommending it but if anyone who didn't get the red and green lights because the device was not on (even though a green light indicated it was communication with your computer). there may still be hope if you turn it on and reconnect).
2023-12-1
Hallmark007
Steph Jant Posted at 12-1 04:23
I’ve seen it done on many dji drones but sometimes it doesn’t hold present settings for some reason, I think if it was a simple code then it would be easily repeatable but that never seems to be the case and as I said I own a Leica Q3 and new FW removes all your previous settings and it is annoying particularly if you only realize when you’re ready to shoot. Let’s see if they can do something permanently.
2023-12-1
djiuser_ITbqYOIlCxmG
Flight distance : 162270 ft
In terms of the Mic2, the instructions state... "After the firmware update is complete, check the firmware version on a camera to ensure the firmware has been updated successfully". How do you navigate the cameras menu to find this information?
2023-12-1
ryguyMN
Flight distance : 17480 ft
BrianKushner Posted at 11-30 21:20
For those of us that didn't update the battery handle. I just attached my battery handle to my already updated pocket 3 and it said UPDATING BATTERY HANDLE and finished in about 20 seconds...simple as that.
Glad to hear you got it working. Did it take you one attempt to update the battery handle?
2023-12-1
IftiBashir
Previously I updated the P3 alone, then later when I connected the battery handle (offline) it just updates.
This time I updated with the battery handle connected - it did both at the same time.
DJI Mic 2 also updated quick and easy using the manual instructions in the first post.
All done and ready to go!
2023-12-1
IftiBashir
When updating the DJI Mic 2, bear in mind once placing the bin file into the root of the Mic you need to disconnect the mic and then manually power it on. as soon as it is powered it will begin the update. Upon completion it will automatically delete the bin update file and you're ready to go.
2023-12-1
fansfe82067d
My battery updated when I connected it after updating the camera on its own.  I suspect that battery updating will depend on how full it is, to avoid bricking.  Mine was at 100%, (no change since first charge after purchase!).
2023-12-1
nightlight
Czechia
I hope the next firmware update will bring the 4:3 aspect ratio recording mode, to get the most of the sensor area and be able to crop in post. It doesn't need to be full 4k by 3k (3840 x 3096) but even smaller resolution would still be great.
2023-12-1
racin06
IftiBashir Posted at 12-1 09:07
According to the instructions, the Mic 2 must be powered on prior to connecting to a PC.  You can't manually power it on if it's already on per the instructions below.
  • Make sure the transmitter is powered on. Connect the transmitter to a computer using the UCB-C cable.
2023-12-2
djiuser_wgumTjfy1sEl
Since the last firmware update the focus on webcam mode is going out of focus all the time. Try it out you'll see.
2023-12-2
djiuser_Sgr7TBoAusAc
Czechia
Nemá to CZ menu, nekoupím si to. Až bude. Zdar
2023-12-3
Steph Jant
The latest FW update adds D Log M and HLG to slow motion mode at  BOTH 100 and 120fps - not just 120fps as suggested in the description of the FW update. Thanks DJI
2023-12-3
TooDeep
racin06 Posted at 12-2 04:03
  • I made the mistake of not turning the Mic 2 on before copying the .bin file onto it since the green light comes on once connected irrespective of whether the Mic 2 is on or not. As you would expect, it didn't update but as soon as I turned it on to try again, the update initiated without any further action. Maybe I was just lucky but the message is follow the instructions but don't necessarily panic if you make the same mistake.
    2023-12-4
    TooDeep
    Altero Posted at 12-1 03:58
    I had the same frustrating problem, Altero. The prompt finally came only after I used the MIMO app to watch some of the footage I had taken. So maybe review some of that great QoS and Mefa coverage if it happens again. If you know, you know!
    2023-12-4
    FIOFON
    After updating to latest release ny battery handle firmware had not been updated.
    I deleted the app off the phone and downloaded again on pc and copying to downloads folder on phone
    This resulted in the app showing there was an update cagain to the latest firmware.
    Hey presto battery was updated and even better Gimble Recentre now so far after overnight switch off works
    My main concern Op3 appears to be a battery guzzler.
    2023-12-4
    Altero
    TooDeep Posted at 12-4 05:19
    Haha! You got me! Actually, I don't use MIMO app at all. But I use Pocket 3 often. The latest firmware update was nice, but still nothing from my 'wish list'. I will be waiting!
    2023-12-6
    Tomdroid
    Flight distance : 22818 ft
    cobra65 Posted at 11-8 10:29
    Please fix the issue (in FPV mode) when flipping the camera around from selfie to front facing the camera head will auto-tilt to the horizon. This doesn't happen in the Pocket 2 for FPV (but it does in Follow mode). Seems this occurs in all modes on the Pocket 3.
    I also made a video of the issue that is maybe a bit more clear: https://youtu.be/g3rFAUseqcA[Image]
    Confirmed from DJI that they don't recognize this as a bug and it's actually expected behavior. Sorry, I know it's a huge pain in the ass
    2023-12-6
    misticjeff
    Flight distance : 73609 ft
    djiuser_ITbqYOIlCxmG Posted at 12-1 06:04
    You probably found this by now, but if not.. take a look at this video, scroll to 4:05 and you'll see where to check.
    https://www.youtube.com/watch?v=SsO4qZkr-zI
    2023-12-7
    manxphoto
    Flight distance : 3797825 ft
    Isle of Man
    This firmware update seems to have sorted a problem I had.  On startup the gimble often didn't rotate to the correct position and needed a 'nudge' from me to rotate and on shutdown didn't always return to the 'park' position.  Since the update it's worked perfectly.
    2023-12-8
    cobra65
    Tomdroid Posted at 12-6 03:11
    Ugh that is disappointing. I really hope this gets updated in a future release. It makes the camera super frustrating to use and nothing like the previous two models :-/
    2023-12-12
    Dante Vicenzo
    Flight distance : 2541473 ft
    There will be an update to fix corrupted files issue?
    2023-12-13
    djiuser_yi4PaNHGgr55
    In the next update, could you please consider allowing longer than 1 sec shutter speed for nighttime photography and time-lapses of stars?
    2023-12-13
    Ordep
    Portugal
    Hello, this is my second DjI product, I recently purchased the OP3, I am very pleased with the concept and what it offers to enjoy the OP3, there are things that really bother me about it, and I will mention a few:  1st - The Light Flickering control is the worst I have on all electronic video and photography devices, by far it all works well, it's really very bad, in my country it's 50Hz and not even in automatic mode or specifically selecting 50Hz can it work a clean, flicker-free image when the lights are on, especially at night. They must review this situation urgently. It's frustrating and negates the use of the video for more demanding situations.  2nd - When I turn the OP3 on vertically and switch to landscape mode, the adaptation to that mode on the display takes time to happen, with a considerable lag to adapt to the new format.  3rd - I would like and it would be logical and common sense if we could also change the exposure values manually (EV) before starting recording, which currently only allows after recording has started. Does not make sense.  4th - When doing PAN, the image drags at various times, even using the Gimbal in slower mode, this improves but does not eliminate the effect. I use a fast SanDisk card with 130Mb/s writing.  Thank you for your attention
    2023-12-14
    DaveSp
    Flight distance : 6562 ft
    Ordep Posted at 12-14 11:51
    Under Auto Exposure settings, you can manually set EV.
    2023-12-14
    Ordep
    Portugal
    DaveSp Posted at 12-14 14:18
    Yes, I know, and it is, by default, at EV -0.3, but that means having to go to the settings and having to change them. Another thing is having the possibility to change it even before you start recording, because the brightness often changes very quickly at the end of each clip. On other equipment, I can change on the fly in any situation. This situation has already been reported by several users who change the exposure compensation frequently to create a more homogeneous video, and have to change this detail each time. The image and timing is dynamic, and the ability to quickly change the compensation would be very useful. And what's worse, what I mentioned in my previous comment, is that OP3 only allows me to make this change during recording, and not before quickly. Which doesn't make sense, as the changes will be noticed and they will be recorded, and if we don't get the value right the first time, there is a risk that the same error will be recorded, which is not pleasant visually.
    2023-12-14
    Richard Treherne
    djiuser_yi4PaNHGgr55 Posted at 12-13 11:36
    Absolutely :-) would be great, I bought the pocket 3 and sold my action 4, I took some great star/night lapses with the 4, as well as great photos with long shutter time and didn't realise the 3 didn't have that feature, here's hoping an update will put shutter  times to the same level as the 4.
    2023-12-15
    Irish Mafia
    StefanDjiMini2 Posted at 11-5 06:37
    Does the Pocket 3 have buzzing audio when an external mic is connected?
    I haven't noticed it.  What I have noticed is the USB-C mic audio is very muted and muttled sounding.  When I played back the .WAV file it was perfect.  So, the recording is fine, the audio encoded into the .mp4 is not.   I really hope this is something DJI can look at and fix in firmware.
    2023-12-15
    EnTuMente
    Please, I urgently need the old version of the Mic 2 firmware.
    I have version 04.02.01.13 and I need the version before that.
    DJI has done the current version wrong.
    Putting an auto off on the Mic 2 without being able to activate and deactivate this function does not seem correct to me and has ruined several videos for me.
    2023-12-18
    KIRILLNE
    1)Thank you for adding 60 fps for the webcam mode, BUT they do not work, the picture does not change smoothly.
    2) And in webcam mode, the camera gets terribly hot at the junction of the body and the gimbal, although in video recording mode it is usually not that hot even at 4k 60 frames, and as a webcam it works at 1080 30 frames per second. .. ,
    3) maybe you need to reduce the load on the camera in this mode! since my phone transmits video from the camera via ADB without heating for 10 hours h.265, is it still possible to make the picture go to the computer like on the camera screen without additional load on it, or is the problem in the long-term continuous operation of stabilization in one place, is there heating there (the place where the camera rotates from left to right)?
    Of course, I understand that this is not what your camera is for, but it would be cool to beat competitors like insta360 link, which on the same gimbal hardly gets warm when transferring video to a computer (
    4) and another question about Microphone Mik 2, when connected via Bluetooth to a laptop and phone it shakes at different times, which creates interference when recording, while there are no such problems when recording to the camera and to the microphone’s memory, will this be possible? will be fixed in its new firmware
    5) It would also be nice if it is impossible to remove this noise by connecting a microphone via Bluetooth - connect it via a USB cable directly to the computer as an external microphone, since now it is only visible as a flash drive
    2023-12-23
    skywalker1905
    Flight distance : 859160 ft
    I just got Pocket 3 today and found that when I go to the Gimbal Modes menu, if I'm in the Follow mode and try to use tilt Locked mode, when I swipe left and stop on the screen, it's very hard to stop in the middle one and it always skips it and chooses the FPV mode, if I use click instead swipe it works, the swipe left/right gesture is very hard to use, same issue when I swipe right when I'm in FPV mode, and also same issue in Rotational Speed selection etc.
    My firmware is 01.02.06.04
    2023-12-23
    ciyop35621
    Unboxing Osmo Pocket 3 Creator Combo & Standard https://youtu.be/Y76RPoCRws4
    <iframe width="560" height="315" src="https://www.youtube.com/embed/Y76RPoCRws4?si=7vpKWXFi6o_wzYXg&amp;controls=0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
    1-10 02:16
    ciyop35621
    https://youtu.be/Y76RPoCRws4?si=pxIYxwT2nA54AvBq
    1-10 02:18
    Przdnt
    Hi all! I think I have a bug. My Pocket 3 automatically exits the shooting mode selection menu. I hadn't noticed this before. Now, if you don’t touch the screen for 2 seconds, it exits the menu on its own. Am I the only one having this problem?
    https://drive.google.com/file/d/1Q16ccgKT1pBMObg1AoL8ae7m5ifrVz8A/view?usp=share_link
    1-11 03:24
    snoopx
    "...My Pocket 3 automatically exits the shooting mode selection menu..."
    That's normal behaviour. Mine's always done that. Got to make your selection quickly!
    1-11 11:20
    Przdnt Posted at 1-11 03:24
    Hello, there. Thank you for reaching out. Please allow us to confirm this phenomenon to our relevant team for further checking. Rest assured that the latest information will be forwarded here.
    1-14 00:03
    UweE
    Flight distance : 1016775 ft
    snoopx Posted at 1-11 11:20
    you are right, standard behaviour.
    But, 1 second more would be convenient
    1-14 03:18
    Update: Upon checking, we've verified that this is within the normal phenomenon of the DJI Pocket 3. Thank you for your patience.
    1-18 00:54
    UweE Posted at 1-14 03:18
    Hello, there. Thank you for sharing your input. Rest assured that your suggestion will be forwarded to our relevant team for reference. Thank you for your continued support.
    1-18 00:56
