DJI mic problem PLS FIX
10457 21 2023-5-23
Unixem
WTF HAPPENED?!?!
So I was using the mic normally and connected it to my pc with a USB-C, works fine everything is good, So, im happy that everyting works I tested it out on my camera and iphone before this so things are great and the product works!
Then I go to plug it in to use as a discord mic to see if this mic is better than the blue snowball mic and... nothing. No pop-ups, no sound, etc. It shows that it's working because it is getting charged, but why can't I use it on my pc now??? I think it would be great to have an extra mic, or use the better DJI mic for live streaming, but I can't any more. I've tried the 3.5mm jack and USB-c, neither worked for Autoplay, no notification , nothing
I've searched online for any fix, nothing works, I'm about to give up since its a week since I've purchased the DJI mic
My only guess is that I should have installed the files the first time(firmware for the reciver and transmiter), but why won't life give me a second chance after
I screwed up once, I now have knowledge, yet I can't use it.
Nothing I buy ever seems to work right ;(
2023-5-23
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know what computer you are using?
2023-5-23
Unixem
DJI Wanda Posted at 5-23 23:20
I'm using Windows 10 ( tried to update to 11 and every file got deleted in recovery, didn't fix the issue either unfortunately ) , Desktop Built by my dad here are the specs:
Device name        DESKTOP-MF83E7M
Processor        AMD Ryzen 7 3700X 8-Core Processor                3.59 GHz
Installed RAM        32.0 GB
Device ID        5F3BC01B-A48C-4A98-8575-87BB88313D48
Product ID        00325-91004-28935-AAOEM
System type        64-bit operating system, x64-based processor
Pen and touch        Pen support
and
Edition        Windows 10 Home
Version        22H2
Installed on        ‎5/‎25/‎2023
OS build        19045.3031
Experience        Windows Feature Experience Pack 1000.19041.1000.0
my main problem is that the autoconnection won't work still, So I can't download the files needed
2023-5-24
Unixem Posted at 5-24 20:16
You mean the problem is DJI Mic cannot be recognized after it is connected to a computer, right? You can try the troubleshooting below to see if it helps.
1. Reset the DJI Mic receiver to default settings.
2. Format the DJI Mic transmitter via the DJI Mic receiver.
* Ensure that there is no need to back up the internal data before formatting the internal storage. If the relevant data is needed, please skip this step.
3. Use another USB A to C cable.
4. Disable the disk/security tool software in the computer.
5. Use another computer and see if the issue still exists.
2023-5-25
Unixem
Yes, that's right,
I've tried all of the except for disabling the disk/security tool, because that is no where to be found on my computer, So I don't think I have it or its fully hidden somewhere that I don't know of.
I've even tried connecting it to my laptop and it did not work
both the cables didn't work, nor did the default setting or the format
I can send video footage to  show you more accurately what the problem is, but its been a few days and the only solution I found is sending it in for repair even though I bought it a week ago
2023-5-25
DJI Wanda
Unixem Posted at 5-25 06:26
Yes, that's right,
We are sorry for that. If all the troubleshooting steps can not resolve the issue, you are advised to send it back for further diagnosis. Here is the link:
https://repair.dji.com/us/repair/index
2023-5-25
djiuser_d5ynlJ4LkSpi
Having trouble with my dji mic holding a charge...is anyone else having this issue...
2023-10-29
DJI Wanda
djiuser_d5ynlJ4LkSpi Posted at 10-29 11:32
Hello, there. Do you mean DJI MIC can not be charged normally in the charging case?
May we know if you connect a charger to the USB-C port on the receiver or transmitter to charge the DJI MIC, will it be charged normally?
2023-10-30
BertTheDragon
Hi all, has anyone experienced the dji mic not internally storing the first section of a recording? When downloading recordings after an event, I am missing the first 31 minutes. Can anyone suggest a solution to this problem?
2023-11-25
BertTheDragon Posted at 11-25 09:55
Hi there, I am sorry to hear about the issue. May I confirm if it happens with every first recording of your usage? Did you perform formatting of the files previously?
If you did not perform formatting, and the issue happened frequently, please help to confirm the information below:
1. Please confirm whether the DJI Mic has been updated to V02.00.72.87. Please update if necessary;
2. Description regarding how the DJI Mic was used;
3. The basis for determining the missing of DJI Mic audio files;
Look forward to your reply.
2023-11-25
antonio83
DJI Wanda Posted at 10-30 01:22
non ho la custodia ho il cavo che collego ad un adattore usb c
2023-11-30
DJI Wanda
antonio83 Posted at 11-30 11:30
Hi, there. Do you mean DJI MIC? Then, can the TX be charged via USB-C?
2023-12-1
Zeyad Sameh
United Arab Emirates
DJI Wanda Posted at 12-1 04:14
Hello, my dji mic transmitter got a little splash of water, then it stopped working and flashing red and green. After that it's just dead, not charging not linking i tried to dry it out but didn't work, i was outside filming, after i cam home i put it in rice for a day and also nothing, what to do or how to fix or even how to assemble this thing? By
2023-12-27
Zeyad Sameh Posted at 12-27 22:24
Hi there, sorry about the incident. For your situation, it is suggested to send back for a comprehensive check to ensure your future use. Thanks.
2023-12-27
JohnnySid
Flight distance : 131804 ft
My DJI mic is only showing one file which was the final minutes of a long interview when I plug it in. I also have more than 20 files that are not showing up either. When I look at my mic info it is only showing 379mb available from the 8gb. Where are my files and why do they not show up?
1-16 15:09
Luis Borrero
Venezuela
Hi there, i've been using Dji mic since august 2023, when i purchased it. Now one of the TXs is not turning on, no light, no charging when put in the case. Never dropped, i had used it the day before it stopped working fine
1-16 16:34
JohnnySid Posted at 1-16 15:09
My DJI mic is only showing one file which was the final minutes of a long interview when I plug it in. I also have more than 20 files that are not showing up either. When I look at my mic info it is only showing 379mb available from the 8gb. Where are my files and why do they not show up?[view_image]
Hi there, thank you for reaching out. We would like to know more details about your operation.
May I know if you performed the on-board recording directly or recorded with mobile phone/camera?
1-17 00:26
Luis Borrero Posted at 1-16 16:34
Sorry to hear that. Please try to charge it for a while, like 1-2 hours to see if it works or not.
If the TX could not be turned on at all, it is recommended to send for diagnosis. Thanks.
1-17 00:37
djiuser_HqDVu6ZK9Cam
DJI Mic doesn't connect to either the phone or the computer. And I've only used it twice. I don't understand what's going on. Even factory reset and re-connect does not help.
1-21 14:23
djiuser_HqDVu6ZK9Cam Posted at 1-21 14:23
Hi there, may I know more details about your operation? If you could provide a video recording showing the issue, that would be better to check. Thanks.
1-22 00:51
ipisp
Am I doing something wrong?
Mic2 Receiver never activates 32-bit float recording to the transmitter. The transmitter records 32-bit float only by pressing the red rec button or when it is connected to action4 via BT.
5-7 11:34
DJI Natalia
ipisp Posted at 5-7 11:34
Thank you for contacting us. Please note that 32-bit float recording function feature is only supported and will be effective when internal recording is enabled. I'd like to provide you with further information on how to enable the internal recording feature. To enable the feature, follow these steps:
1. Swipe down on the receiver screen.
2. Select "Transmitter Settings."
3. Look for the option called "32-Bit Float Recording" and enable it.
If you are using the Osmo Action 4, please follow these additional steps:
1. After connecting the DJI Mic 2 transmitter to Action 4, swipe down on the home screen.
2. Tap on "System Settings."
3. Look for the option called "Wireless Microphone" and select it.
4. Finally, enable the "32-Bit Float Recording" option.
By following these instructions, you will be able to enable internal recording and take advantage of this feature. If you have any further questions or need additional assistance, feel free to ask.
5-7 23:16
