HGDC84
Finland
A small heads-up regarding this item combo (admittably old accessories).
Today, my Osmo Pocket 3,5mm audio adapter arrived by mail. I had been wondering if I could use this combination to get both an external microphone and a tripod connected to the Pocket 2. While I do know it is possible with the DIA Handle, I was thinking if I could save some battery of the Pocket 2 by not using it, as the wifi and bluetooth in the handle make the Pocket 2 consume battery power faster than without the handle and it can't be turned off separately from the handle even when no wireless connections are in use. Also, by the chance if it could have worked the way I planned, the Ulanzi's two USB-C ports could have, in theory, given the chance to connect both the audio adapter and a powerbank, allowing both an external microphone and charging battery at the same time. But, alas, seems like it doesn't work that way.
The audio adapter does NOT work with the Ulanzi. The only thing it does is that it removes all audio from the video. Useful if you want some muted video, but not exactly what you bought the adapter for, is it?
It certainly is the Ulanzi, as testing the audio adapter while directly plugged into the Pocket 2 did work when used with the DJI Mic (one weird thing though - with that setup, I only heard the audio from the left speaker of my headphones - I thought the adapter would split mono on both channels! Not sure if using a wired stereo microphone would result in a normal stereo or at least a mono split equally to both sides, will try it out in the nearby future.)
I'm not going to blame DJI on this, as it is a third-party accessory they have not tested. I just bring this out to give an answer to people who have pondered if this would work. A shame for Ulanzi, as having those possibilities would have made this add-on way more versatile and useful.
It still isn't an completely useless accessory however, as it does allow tripod and charging without the wireless tech eating up power in the meanwhile, and also, with a proper USB-C to USB-C cable (male connector on both ends and supporting proper specifications), it does allow remote control with a smart device without wireless connectivity. Just know it limitations forehand, so you won't be disappointed in expecting something it will not offer.
