A popup screen every time I start to fly
1016 29 1-29 12:13
Levi34Davis
Flight distance : 1965266 ft
Ever since the last update to either the drone or the RC 2, I am getting this popup and I don't know what it means.
Popup
Popup
1-29 12:13
smbishop
Flight distance : 2454833 ft
There are a few threads about this.  It is normal, something new.  Just click Normal mode and proceed.
1-29 13:42
Levi34Davis
Yes, I have clicked that, but it happens EVERYTIME.  Isn't there somewhere that this can be set just ONCE?
1-29 15:02
smbishop
Not that I am aware of.  It comes up every time you try to launch your drone.
1-29 16:00
We understand the inconvenience. We have adjusted the UI design and prompts to take into account diverse user needs and sufficient safety guidance, therefore, a message will pop up to confirm before each flight.  You can select No Position Hold mode if you want manual control, however, the aircraft will not hover stably so it is recommended to use Normal mode. Thank you for understanding.
1-29 20:39
Levi34Davis
Please don't take this the wrong way, but Will this be fixed in future updates?
1-30 10:14
Mobilehomer
Flight distance : 18150351 ft
DJI Tony Posted at 1-29 20:39
This is absolutely false information!!! I have tried both settings on my Classic with ZERO difference in flight!!! Perfect position holding regardless of altitude. Either setting stops as soon as the stick is centered.
Tell the concerned department to GET RID OF THE POPUP!!!
1-30 11:23
Sean-bumble-bee
Flight distance : 15997 ft
Mobilehomer Posted at 1-30 11:23
Just curious, what does height have to do with this?
Could you explain what you mean by "Either setting stops as soon as the stick is centered" please ?
I wonder if DJI are thinking of reintroducing ATTI mode ?
1-30 14:42
Mobilehomer
Sean-bumble-bee Posted at 1-30 14:42
At low altitudes VPS does the position holding, at higher altitudes, GPS takes over.
With no position holding, the drone will not stop when sticks are released.
Not sure about ATTI.
1-30 17:11
Sean-bumble-bee
Mobilehomer Posted at 1-30 17:11
......thanks
1-30 17:31
Levi34Davis Posted at 1-30 10:14
I understand. We have no relevant information yet about the removal of the pop-up message but this will be submitted to the relevant department for evaluation. Thank you for your patience.
1-30 20:53
Sorry about the trouble. Let me check this with the relevant team. I will get back to this. Thank you for your patience.
1-31 01:25
CatBehemoth
Flight distance : 1014531 ft
DJI Tony Posted at 1-31 01:25
I do agree. I'm not sure what the intended purpose of this new "feature" is, but in my normal usage it just an annoyance. In fact, assuming it has any function at all, it is easy to inadvertently press "No Position Hold mode," which is probably not what most people want. Points (1) and (2) are plain silly, You may show them on the very first flight if your liability attorneys insist, but why subject your customers to this every time they attempt to use your product?
1-31 18:43
Hi. Mobilehomer. They have no response yet about this. I have submitted your feedback to the development team for evaluation. Sorry about the inconvenience.
2-3 02:14
CatBehemoth Posted at 1-31 18:43
Hi, CatBehemoth. It was intended for manual control. But rest assured, your feedback will reach the development team to consider. We appreciate your patience.
2-3 02:17
digibud
Flight distance : 8043855 ft
DJI Tony Posted at 1-30 20:53
This is nothing but an necessary irritation. PLEASE remove this stupid pop up.
2-5 14:04
digibud Posted at 2-5 14:04
I understand the inconvenience. I have been submitting your feedback to the development team to handle this. Have a nice day.
2-6 02:27
fansce917649
If No Position Hold Mode is actually ATTI mode and you take off, is there a quick way to return to Normal mode from the ATTI. Or do you have to land, shut down, and restart to get back to Normal mode?
2-6 06:50
BigAl07
Flight distance : 6127769 ft
This Pop-Up is absolutely ridiculous, annoying, and insanely REDUNDANT!
If I were in some "Atti Mode" scenario then I could understand the "Not so Gentle Reminder" but that's NOT the case. I am attempting to do my JOB as quickly, efficiently, and professionally as I can. This is a total annoyance and needs to be addressed.
My suggestions:
1) Make it ONLY pop up during the first 5-10 flights of a NEW aircraft. This might help the NEW operator to read and remember the tips noted on the screen.
2) Make a "Check Box" notification so that once the box is checked, it is turned OFF for all future flights.
3) Make it so it ONLY comes up if the aircraft is in some more other than NORMAL.
It seems like this would be a super QUICK and EASY solution.
Kind regards,
Allen in NC
2-6 07:18
digibud
I curse under my breath every time this pops up. I try to picture whoever made the decision to do this....
2-7 09:25
Monkieboy00
Flight distance : 101188 ft
Even a newbie or "diverse person", after being remined a few times should be capable of using the drone without it
Remove this annoying popup.
2-7 13:38
fansce917649 Posted at 2-6 06:50
Hi there. You can switch it anytime in the app by tapping "Switch" on the NPH message:
Have a nice day.
2-8 21:55
Monkieboy00 Posted at 2-7 13:38
Hi, Monkieboy00. This will be submitted to the relevant team. We value your feedback. Thank you for your patience.
2-8 21:58
fansf8db0d9c
Flight distance : 31801 ft
DJI Tony Posted at 2-8 21:58
This popup message is a huge nuisance and does nothing but create an opportunity to in advertently put the drone into ATTI mode. PLEASE get rid of this! It wastes a lot of time in my daily operations.
2-10 15:18
fansf8db0d9c Posted at 2-10 15:18
Thank you for your feedback. I will submit this to the relevant team. Have a nice day.
2-11 01:33
West End Drone
BigAl07 Posted at 2-6 07:18
I agree with BigAl's suggestions.  PLEASE... remove the pop up
4-10 09:00
kewlwhip
West End Drone Posted at 4-10 09:00
Just upgraded my RC-NC1 controller to the RC Pro and this warning screen is making me regret it. Give me a check box to remove this alert as it is amazingly annoying. DJI has always seemed to move forward in the industry but this is a huge step backward.
5-27 18:08
kewlwhip Posted at 5-27 18:08
Hi there. Thank you for the suggestion. Let me submit this to the relevant team to provide them with feedback. We appreciate your valued support.
5-27 19:47
MiniManiac
Flight distance : 1226368 ft
Is this on the RC2? I dont see this screen
yesterday 04:34
djiuser_VIwJR8ELSWT8
MiniManiac Posted at 5-28 04:34
I remember that in the beginning I always had this screen display. Then I discovered the option on this ad to disable this ad for the future.
yesterday 05:55
