Transmission Not Working with FX6 SDI
472 2 2023-9-25
Jon96
Flight distance : 3760 ft
I'm not able to get the DJI Transmission system to work with my FX6 whne using SDI to connect the transmitter to the camera. I have the SDI output set to 1080P and I've tried it at both Level A and Level B, but the transmitter never recognizes the video signal (I get the red indicator light and the no-video source icon on the screen).
HDMI works fine with the same output settings. I've also tried several SDI cables, so confident it isn't a cable issue.
I could be wrong, but I SWEAR this was working before the 4.0 firmware was released for the FX6. Does anyone else have SDI working?
2023-9-25
fans623fd501
Hi there, did you get it running. Facing the same problem here.
2-6 19:02
Jon96
Yes, I had to set the FX6 to output at 1080P, then it worked fine.
2-6 19:04
