Battery level low. Return to home at 50% battery level.
611 17 2-9 09:35
_dji_user_
Flight distance : 2041585 ft
Estonia
Why aircraft DJI mini 4 says that 50% battery is low? Is it normal. Only some charge cycles.
Distance between aircraft and rc ~5 to 20 meters
Vehicle Active tracking mode
Home distance: 16278.4ft
Windless
AGL: ~10m
Error message:
Aircraft battery level low. Return to home promptly (Code: 800903).; Aircraft battery level low. Return to home promptly! (Code: 3203612).
Battery: 50%
Battery voltage: 7.128 V
Cell 1: 3.56 V
Cell 2: 3.57 V
Cell Deviation: 0.016 V
Battery currentCapacity [mAh]: 1272
Battery fullCapacity [mAh]: 2589
Battery temperature: 57.4 F
Battery minimum temperature: 53.6 F
Battery maximum temperature: 64.9F
2-9 09:35
Sean-bumble-bee
Flight distance : 15997 ft
The percentage normally depends on the distance from the home point PLUS the height of the drone.
Did you fly the outbound leg down wind or a very long way away from the home point ( 16,278ft would count as a long way away from the home point ) and only on one heading, was the drone high?
The percentage is based on the distance from the homepoint, the distance of the drone from the controller is irrelevant in this calculation.
2-9 10:39
JJB*
Flight distance : 12686732 ft
If you like share your flightlog for this issue/
use this link > https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here
cheers
JJB
2-9 10:44
_dji_user_
Estonia
Sean-bumble-bee Posted at 2-9 10:39
Did you fly the outbound leg down wind or a very long way away from the home point and only on one heading, was the drone high?
Windless
AGL: ~10m
It seems to be a matter of the proportions of distance and battery capacity.
2-9 10:44
Sean-bumble-bee
_dji_user_ Posted at 2-9 10:44
Windless
AGL: ~10m
I have edited my previous reply
2-9 10:47
_dji_user_
Estonia
JJB* Posted at 2-9 10:44
The flight log cannot be shared. The above information is information from the flight log. I would like to know what these error codes 800903 and 3203612 mean.
2-9 10:51
JJB*
_dji_user_ Posted at 2-9 10:51
oke, without a log not possible to analyse.
cheers
JJB
2-9 10:53
_dji_user_
Estonia
Thank you. The matter is a bit clearer, but hope to get more information about the error codes 800903 and 3203612.
2-9 10:59
Sean-bumble-bee
_dji_user_ Posted at 2-9 10:59
Have you tried googling DJI and the error code.
You can reset the home point to the controller's location but it can ONLY be done in stages, it DOES NOT continuously reset the home point.
2-9 11:05
_dji_user_
Estonia
Sean-bumble-bee Posted at 2-9 11:05
Google does not provide any matches for error code 3203612. Error code 800903 has a vague explanation.
Before asking on the forum, I still try to research elsewhere.
2-9 11:10
Sean-bumble-bee
_dji_user_ Posted at 2-9 11:10
Fair enough.
Unfortunately a lot of people do not think to do research.
2-9 11:13
Your problem is that you were 4900 metres away from where you launched the drone.
How close the drone is to the controller isn't relevant.
How far the drone is from the homepoint is what's relevant.
Where you launched is the homepoint.
The drone monitors it's distance from the homepoint and advises you when it has just enough power to get back to the homepoint.
If you had reset the homepoint during the flight, the drone wouldn't think it was 4900 metres from home.
Post your recorded flight data if you want help.
2-9 16:29
Sean-bumble-bee
Dirty Bird Posted at 2-9 16:21
I am confused.  You state : "Distance between aircraft & rc ~5 to 20 meters".
Next you state "Home distance 16278.4ft"
That got me too initially but I think they had the drone track them and did not reset the home point, so it ended up 3 miles from the homepoint but a few ft from the controller.
2-9 16:30
_dji_user_
Estonia
Sean-bumble-bee Posted at 2-9 16:30
Thats right, tracked. From log i see that battery indicators normal during flight. It looks like the battery notification is actually a "Last chance. With this battery charge, you can return to the starting point". The low battery warning could be worded differently to better understand.
2-9 18:24
Hi there. Thank you for reaching out and we do apologize for the trouble. The error codes 800903 and 3203612 mean that the unit has "Insufficient battery level. Please execute RTH now". Since you are tracking your vehicle, try to update the Home Point during the flight as the Home Point can be manually updated in Settings > Safety page in the DJI Fly app. Please note that to avoid unnecessary danger caused by insufficient power, the aircraft automatically calculates if the battery power is sufficient to return to the HOME POINT according to the current position, environment, and flight speed. A warning prompt will appear in the DJI Fly app when the unit calculates that the battery is low and only enough to complete an RTH flight back to the Home Point. For future reference, you may visit the DJI Mini 4 Pro user manual. Thank you for your valued support.
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
2-10 00:51
S-e-ven
Flight distance : 5922034 ft
You need to update your homepoint, the Mini thinks, it has to travel 16000 ft back to it!
2-10 11:38
S-e-ven
The bird flew 16.000 ft, but still has a not updated homepoint at the start!. Not important, where the RC is, the homepoint needs to be changed, the bird needs to know the new/actual one ;-)
2-10 11:42
_dji_user_
Estonia
Thanks everyone for the useful information.
2-10 11:51
