New firmware: RemoteID with regular battery?
1636 21 2023-12-21
dji.blitzk
Flight distance : 1752986 ft
Is RemoteID ALWAYS on with the small battery?  Can we turn if on/off now for purly recreational flights?
2023-12-21
dji.blitzk
Dirty Bird Posted at 12-21 19:44
From the new Mini 4 Pro firmware release:
* Added support for automatically activating the US Remote ID only when the aircraft is used with an Intelligent Flight Battery Plus.
Right... because there will be a NEED to use RiD when using the regular battery too.   I was just wondering if there was a way to switch it on/off?
2023-12-21
DJI Wanda
dji.blitzk Posted at 12-21 19:57
Hello, there. Sorry for the inconvenience. In accordance with the Remote ID rule and compliance methods, manufacturers are prohibited for providing users with any method or tool in any form that can disable Remote ID.
2023-12-21
dji.blitzk
DJI Wanda Posted at 12-21 20:07
So with the new firmware update, what does it mean about remoteid with the smaller battery?
How does that work?
2023-12-21
DJI Wanda
dji.blitzk Posted at 12-21 20:10
How does that work?
Under the new firmware, with the smaller battery, the aircraft will not activate the RID functionality.
2023-12-22
dji.blitzk
DJI Wanda Posted at 12-22 02:08
Ok,  so now the Mini 4 pro, when using the smaller battery,  cannot be used for any commercial purpose and can only be used for recreational flying?
2023-12-22
Manitobahunter
I'm curious if if the updates let the goggles 2 and motion controller 2 function with ocusync 4, or if the Mini 4 Pro reverts to ocusync 3 with the motion controller 2 and goggles 2?
2023-12-22
DJI Wanda
dji.blitzk Posted at 12-22 05:32
If you are operating a drone with a take-off weight of 0.55 pounds or less than 250 grams for purely recreational purposes, you do not need to register your drone and comply with the Remote ID rule.
2023-12-23
dji.blitzk
DJI Wanda Posted at 12-23 01:45
Right.  So what you're saying is that if someone bought the mini4 pro and regular/small battery to use for commercial reasons,  they can no longer use it?
2023-12-23
DJI Wanda
dji.blitzk Posted at 12-23 05:52
We recommend users combine the DJI Mini 4 Pro Series Intelligent Flight Battery Plus with the DJI Mini 4 Pro for purpose of the commercial flights.
2023-12-25
Love n Color Productions
I’m new to drone flying and I’m confused. Is this new firmware update a bad thing? I have registered my drone with the FAA. Is there something else I have to do now? If I use a plus battery am I going to get fined or something?
1-5 13:52
dji.blitzk
Love n Color Productions Posted at 1-5 13:52
This firmware update is a great thing... for the most part.    It's only bad if you intend to use the drone for any commercial purposes.  In that case you cannot use the battery it comes with and you must purchase/use the bigger battery.
1-5 16:05
dji.blitzk
DJI Wanda Posted at 2023-12-21 20:07
Would you be prohibited for providing users with any method or tool in any form that can ENABLE Remote ID?
Currently DJI Is providing a "method" to DISABLE Remote ID.   That method is using the smaller battery.
Shouldn't there be a setting in the menus to ENABLE Remote ID when using the smaller battery... and if you don't enable it, it is OFF by default?   That seems ideal to me.
2-2 16:41
DJI Wanda
dji.blitzk Posted at 2-2 16:41
Hi there, the remote ID standards will apply to drone users that require registration. Simply speaking: Except for users that operate a drone that weighs 0.55 pounds or less (less than 250 grams) and for recreation purposes only, other users need to register their aircraft and comply with RID regulations.
2-3 03:06
dji.blitzk
DJI Wanda Posted at 2-3 03:06
Thanks for the reply... but that doesnt answer the question at all.
2-3 04:50
fans0c5750c4
Flight distance : 90361 ft
Yes, I firmly believe with smaller batteries, there should be an ability to toggle remote ID on.
2-9 11:13
dji.blitzk
fans0c5750c4 Posted at 2-9 11:13
Of course.  I just wish DJI would actually answer the question.
2-9 15:09
dji.blitzk
Still waiting for an actual answer for this...
2-15 18:20
PACMini4Pro
dji.blitzk Posted at 2-15 18:20
The answer I keep getting is to buy the bigger battery.   If you contact support they will offer you a discount on the new batteries, you are on your own selling the smaller ones if you wish too, unless you bought them directly from DJI, then they may allow you to return them.
2-18 13:04
TFJ_Scott
So the official answer is to buy a different manufacturer's drone instead of DJI because you're forcing users to purchase an additional accessory x5-6 to continue to use their already purchased drones commercially.
Mini 3 Pro Replacement from another company = $549 vs. x6 PLUS Batteries $579 ...
That's a really smart business decision said no one ever !!!  This is a perfect way to shun your customer base.
3-20 05:18
stepha
we get this problem fixed yet?
let turn on remote ID with the smaller batteries arleady and stop trying to milk more money out of your customers
4-26 17:54
djiuser_zKqJxLSDt0Ms
Flight distance : 23819 ft
Heres the problem.  If I fly the Mini pro 4 over an open air assembly, I need to have RID on and Prop Guards.  If I use the heavier battery with prop guards you have a disclaimer that the collision sensors are disabled and the weight of the aircraft cannot support the bigger battery with the prop guards.  If I put just the prop guards on then the weight of the aircraft is still over the 249 grams.
So just selling the accessory puts us over the regulations and requires us to use the RID.
2. DJI Mini 4 Pro does not support obstacle avoidance after installing the propeller guard and cannot actively detour or brake when it senses an obstacle. When using intelligent features, the aircraft will not have obstacle avoidance capability.
3. The aircraft will weigh more than 250 g after installing the propeller guard. Always carefully check and abide by local laws and regulations. If required, obtain the necessary approval and clearance from the related government agencies before flying.
4. Do not use the Intelligent Flight Battery Plus after installing the propeller guard. Otherwise, the weight will overload the drone’s capacity, and flight safety cannot be guaranteed.
5-23 09:58
