iaw4
LV_Forestry Posted at 2-13 13:13
There will be no update for GSpro, it is a product that is no longer supported. For the Mavic it's the same, there is already little chance that there will be an update, and if there is one it will certainly not be compatible. Its a Remote ID story.
As I already wrote to you in another thread, as the mod wrote to you, you need to downgrade the drone to v01.00.0770 for it to work with GSpro.[view_image]
ok, understood now. I had hoped not to risk it. Hope dies last.
(there is a program confusingly named "DJI Assistant" in the iPad Appstore.)
there is an "Assistant 2" Mac app in the DJI Download Center, which installs and run just fine. It wants to install HornDIS for an Android phone, which fails on macos these days, but which isn't needed. At this point, I was able to run the "Assistant 2" on macos (M1), and it allowed me to downgrade the firmware after connecting the drone with a USB-C cable directly. Yeah! (now all I need to make sure that someone doesn't accidentally allow the upgrade again.)
in between, I got an "upgrade failed" message, but it then continued updating from 45% to completion.
and then it all worked. thank you susan and captain...
