osmo pocket 3 HD streaming
555 15 2-9 17:13
Superior Videos
This question is for the streamers.
Can someone explain to me the smooth setting when streaming in 1080.
When I set it to hd all the way, I am getting a lot of dropped frames and choppy video, so I went back to 720 and it was all good.
I couldn't cope with the fact that the pocket 3 could not stream in 1080 smoothly so I tried the smooth setting in 1080 and it is going well.
Why is this option there in the first place.
Is it a bitrate issue if the wifi isn't good enough.
Still getting my head around the changes between the pocket 2 and 3.
2-9 17:13
DJI Wanda
Hi there, sorry for replying late. Are you referring to the smoothness of the live broadcast? If so, the fluency is mainly affected by the upstream bandwidth of the network. If 720p is smooth while 1080p is not, could you please try increasing the upload speed and see if there is any improvement? Thank you.
2-15 00:46
Superior Videos
DJI Wanda Posted at 2-15 00:46
Wouldn't it be great to be able to increase the upload speed.
My life would be so much less stressful. I can very rarely get above 10mb/s upload.
I was just wondering what the reason for the setting was. It seems to go ok set to 1080 smooth otherwise 720 with the HD setting works.
It's only when I try 1080 and HD that I get stuttery streaming. I'm still trying to work out all the issues with the camera.
Doug
2-15 00:59
DJI Wanda
Superior Videos Posted at 2-15 00:59
The resolution of 720p is 1280*720, which is 921,600 pixels. The resolution of 1080 is 1920*1080, which is 2.0736 million pixels. The pixels are 2.25 times that of 720p, which means that the bandwidth required is higher than that of 720p. If 720p is smooth but the 1080p live broadcast is stuck, it can be caused by insufficient uplink bandwidth of its network, because the live broadcast mainly depends on the upload speed. Besides, it is also related to the server of the live broadcast platform in your area.
2-15 01:17
Superior Videos
Yes I am aware of how it works. Streaming is my livelihood and I have been doing it for a few years now.
Unfortunately in our country, we are stuck with poor mobile wifi speeds.
I pay a lot to the telco to get the highest speeds but as mentioned , rarely gets above 10mb/s up
Thanks for your response.
Doug
2-15 01:28
DJI Wanda
Superior Videos Posted at 2-15 01:28
Hi Doug, I understand what you mean, and I'm sorry that I couldn't provide you with a satisfactory solution. I've searched about how to solve the problem of slow Wi-fi speed. Maybe you can try changing to a faster network service provider, using network speed optimization tools, optimizing network settings, etc. However because these are commonly searched methods on the Internet, we are not sure whether they are effective. Still hope it could help you.
2-15 03:52
Superior Videos
Thanks Wanda.
I guess the confusion was to do with the update with the mimo app.
The previous version had 720/1080 with 3000 and 6000 bitrates.
The current version calls it HD and Smooth.
I don't know why they had the need to change it. We all knew what the settings were before.
So I guess my original question was. "What does smooth represent"
I just keep trialing until I get the right result.
2-15 17:29
Superior Videos Posted at 2-15 17:29
Thanks Wanda.
We understand your feedback. HD refers to a higher bitrate to get clearer during streaming, which may require a good and stable internet connection.
Smooth refers to a relatively lower bitrate, it will be able to get smoother images during streaming.
There is an Auto option as well, which means HD and Smooth will be switched automatically based on the current internet quality. Hope this is informative for you.
2-16 04:32
Superior Videos
DJI Susan Posted at 2-16 04:32
Thanks Susan.
I gathered that was the case.
I do a lot of remote streaming where the wifi is fairly ordinary so it's a case of try it and hope it goes well..
2-16 14:21
Superior Videos Posted at 2-16 14:21
Thanks Susan.
You are welcome and thank you for your understanding. Please feel free to ask if you have any further questions, we are glad to help.
2-16 22:13
Superior Videos
Hello again Susan.
Sorry to bring this up again.
I am at the point where I have had to go back to using my pocket 2 to get smooth streaming.
The pocket 3 is still freezing frames no matter what setting I use.
I never had any problems with the pocket 2 so I still think it is something for the engineers to look at.
I have got plenty of internet speed where I am testing so it is not a wifi issue.
I hope someone can look at this because it's too late for me to return the camera to dji.
Regards.
Doug
3-6 15:07
Superior Videos Posted at 3-6 15:07
Hello again Susan.
Hi there, may I confirm if you mean you've tested Pocket 2 and Pocket 3 with the same settings and under the same network, Pocket 2 is normal but Pocket 3 is frozen?
3-7 02:27
Superior Videos
Hi Mindy.
Yes, both are using the same settings.
When I say frozen, I mean the pocket 3 is dropping frames and short freezes in the video when there is a lot of movement.
I can set the pocket 2 to 1080  on both settings and it is always smooth video.
The pocket 3 even when set to 720 smooth is choppy.
I don't know if it's a hotspot issue because it sometimes improves when I change my hotspot but I can't rely on it which is why I have gone back to the pocket 2.
I will do some more testing in different locations with different hotspots.
3-7 02:42
Superior Videos Posted at 3-7 02:42
Hi Mindy.
To better rule out network problems, you can use the same Hotspot to test Pocket 2 and Pocket 3.
3-7 03:06
Superior Videos
The pocket 2 has always streamed with no problems with any of the hotspots so I know I can rely on that one so I will just keep testing the pocket 3 in different conditions.
I guess most people accept that live streaming isn't perfect but I was hoping the pocket 3 would be an improvement on the pocket 2. So far, it hasn't been that way.
I will keep you informed.
3-7 03:25
Superior Videos Posted at 3-7 03:25
Thanks for the detailed information. We will wait for your update.
3-8 02:57
