Mavic 3 Pro Avoidance Sensors - Sensitivity Adjustment?
1516 7 2023-6-29
OlBigJon
Just upgraded from Air2S to M3 Pro - the obstacle avoidance sensors seem a lot more sensitive and space restrictive than the Air 2S.  Any way to loosen up sensitivity without completely disabling?
2023-6-29
Hi there. Thank you for reaching out. The DJI Mavic 3 Pro can detect obstacles in all directions with extreme precision. Multiple sensing cameras with a wider range of detection help Mavic 3 Pro respond to obstacles earlier. In a well-lit environment, Mavic 3 Pro can avoid obstacles faster and more smoothly, capturing stable footage safely even when flying laterally or backward. We don't have an option to lower the obstacle avoidance detection but we can set it as Bypass, Brake, or Off. Hope this helps. Thank you for your valued support.
2023-6-29
dreamtuner
Flight distance : 2092841 ft
Bangladesh
DJI Paladin Posted at 6-29 17:28
Your Facebook Official Group admins are racists. Get it checked if you can.
2023-6-30
Suren
Flight distance : 13498560 ft
Set the OA to bypass then select Nifty. This makes it less sensitive to things around it
2023-7-1
dreamtuner Posted at 6-30 01:22
Hello there, dreamtuner. We apologize if you feel that way. Kindly please provide us the transaction history via PM so we can check it further and provide you updates on this. Please keep us posted. Thank you.
2023-7-2
djiuser_9S036shSvhQX
Flight distance : 669636 ft
DJI Paladin Posted at 2023-6-29 17:28
Any way to increase it slightly? Or adjust at all? Twice it hasn't sensed trees without leaves. I live in wisconsin and in the winter our trees are bare so they are just branches. Twice I didn't get any kind of alert prior.
2-18 06:04
djiuser_9S036shSvhQX Posted at 2-18 06:04
Thank you for your feedback. We will record this concern of yours as a suggestion and will forward it to our relevant team for future consideration. We highly recommend flying the aircraft in an open area with less to no interference to ensure flight safety. Please don't hesitate to reach us if you have other inquiries. Have a good one.
2-19 02:10
Dirty Bird Posted at 2-18 06:51
You are expecting too much from the sensors.  There are plenty of videos online showing OA does not perform well against bares branches, wires, or in low-contrast situations.  You have to temper your expectations & fly within the limitations of the technology.
I am 100% sure that you are correct lol. I was a little hasty and excited for the upgrade. Definitely not a mistake I'll make again.
2-19 05:24
